Question about Sansui Televison & Video
Need manual/connections for model SAN0950 DVD Recorder
SOURCE: EMERSON DVD RECORDER MODEL EWR20V5
here's a link to the manual emersonaudiovideo.com/pdf/om/EWR20V5.pdf hope it helps
Posted on Feb 12, 2007
SOURCE: I need a owners manual
You can download the manual from www.retrevo.com. If you are unsuccessful, I can email it to you.
Posted on Dec 01, 2008
welcomejee
  • 10594 Answers
SOURCE: lost manual for Pioneer DVD DVR-231 recorder and Sound System
you can download user manual from retrevo by clicking it.
Posted on Jan 03, 2009
SOURCE: I need a manual for Magnavox dvd/ recorder for MWR10D6
Although this is a Magnavox DVR, it is made by Funai. The manual for it can be found at:
http://www.funai-corp.com/6pdf/om/MWR10D6.pdf
Hope this helps!
Posted on Jan 15, 2009
SOURCE: I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Posted on Feb 10, 2009
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
Don't have an owner's manual for Emerson dvd/vcr duo DVD recorder model ewr20v4 Need diagram for connections to Onkyo A/V TX-SR600 Receiver
Hi
You can download your manual (free) direct from here:
http://www.funai-corp.com/6pdf/om/EWR20V4.pdf
Click the link and the file will open. You can then view save and/or print the manual. If you are unable to open the file, you may also need to download Adobe Reader:
http://get.adobe.com/reader/
Please rate this solution if you find it helpful. Thanks!
Oct 31, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
Is third time a charm. Again several years ago I
Here is the owner's manual for your DVD machine. This is a VHS recorder but not a DVD recorder. To record VHS tapes to DVDs, you will need a DVD recorder.
You will plug the yellow video out connector on the VHS to the yellow 'Video in' connector on the DVD Recorder. Do the same for the red and white audio connections, out on the VHS, IN on the DVD Recorder. Connect your TV to the DVD recorder so you can see the picture you are recording.
Mar 31, 2010 | Televison & Video
Can i hook up a hdmi cable from computer to dvd recorder and record stuff from computer to dvd recorder
The HDMI port on your pc is an output device. That said, if your dvd recorder has an HDMI input or another input device then you can record from your pc to your dvd recorder. To do this, you will need the HDMI to A/V or anyother cable that your dvd recorder accepts as an input device. Another roundabout method would be to connect your computer to the TV which is probably already connected to your DVR for recording and record via that.
If you send your DVD recorder's model no. i can help you with exact instructions
Oct 27, 2009 | Dell XPS M1330 Notebook
Can i get a driver
There is no driver for this unit. Also I don't believe this unit is hooked up to the computer. I have reviewed the entire user manual and it doesnt reference that anywhere. You can download the updated firmware from their website though:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-ES46VS.D#ts
Thank you,
Lee
Sep 08, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
I need a user manual for a Toshiba RD XS 25 DVD Recorder
Go to tesc.toshiba.co.uk select "customer access" on bottom left, then select what model, etc and there you go.
Mar 12, 2009 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
Questions about dvd recorder
Yes. You need to connect the vcr to your dvd player as you would if you were connecting to a tv. The vcr out to the dvd in.
My guess is you need a S-video cable or better to get a good solid connection. There should be info in the dvd manual. If you do not have one, post your make and model and we'll try to track one down for you.
Dec 17, 2008 | Computers & Internet
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
Jan 19, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
