Question about Bosch Washing Machines
Washing machine not completing cycle
Washing machine started a cycle normally (filled with water and went through the wash cycle) but the machine and display freezes when it comes to the drain or spin. Basically when i switch it off and back on again no matter which cycle option i choose it still remains in the wash cycle so the same water is in there and the clothes are permanently being washed again stopping at drain or spin. (i can remove the water no problem with the in built hose) but when i try to start a wash again it will not fill or anything the machine still thinks its in the same wash cycle
Jimster
  • 240 Answers
SOURCE: hotpoint wma10 washing machine wont stop filling up
You may have a problem with the pressure dome hose (has a cut or kink in it) or it may be a problem with the main control board. Sometimes that small hose inside the machine can get a cut or come loose. That sends pressure to the board and its valve to let the machine know that it has the right amount of water in it. If it has a hole or is blocked, that signal wont ever come on, and you have overfilling.
Posted on Sep 07, 2007
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
localwonder
  • 6784 Answers
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Posted on Jun 18, 2009
dblred
  • 68 Answers
SOURCE: Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Posted on Sep 12, 2009
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
My idesit IWB5113 just keeps filling after starting the wash cycle, normal it inject some water then starts washing, my machine just keeps filling and doesn't seem to start the wash cycle, please help
It is possible that the water level sensor has failed and so does not detect to stop the inlet valve from filling.You can remove and check this level sensor normally it can be a damaged diaphragm and replace the same so that the program proceeds to the next stage to start the machinetips to see working of the machine;http://www.espares.co.uk/advice/washing-machines/a/7/1392/how-a-washing-machine-works.html
Mar 14, 2012 | Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 plus won't fill on regular orpermanent press cycle.
OK, Duh..... I guess there is about a 2 to 3 min. delay for the liquid soap dispenser to fill up and disperse the soap into the washer tub. After that short cycle is complete the fill cycle engages and fills at normal speed.
Mar 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Sep 01, 2008 | Washing Machines
    Water inlet not filling
    check it has drained completely after the last cycle.
    if that is ok, take top off and check continuity thro the inlet valve coils
    Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
    I have a Roper washing machine that will fill with water, agitate, and stops. I replaced the lid switch assembly and tried it again. Same thing, but one step farther. It went past the agitate and...
    The black dust is from the motor coupler. It is normal to have some under the unit. If it stops completly and you chaged the switch check the lid adjustment if the lid is loose it might not make the switch all the time.
    Apr 24, 2008 | Washing Machines
    Water
    It fills while it is washing you will see a slow build up of water but it will start the wash cycle before all the water is in
    Apr 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    103 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Craig Butler
    Craig Butler
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
