Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote's menu and input buttons, and television Input button not responding
On my sharp aquos lc42d62u just a few minutes ago the input button on the remote became unresponsive. This is the same on the actual television as well. I read the manual and unplugged it for two minutes then it was fine. After a minute of it being on the same problem returned only this time the menu button, and right arrow button joined the input button in becoming unresponsive and making the television turn off. After the TV turns off it will either automatically turn back on or it will have the power and opc light flash a number of times...
  • 5 more comments
  • devilmanex Oct 13, 2008
    Could it be some sort of interference from my satellite which is connected to the hdmi port ( and only input available so it seems )?
  • devilmanex Oct 14, 2008
    I left the ac plug disconnected the whole night and the same thing occurred. The input button on both television set and remote worked for two minutes then it would shut off. The menu button worked for about 5 minutes. Prior to plugging the ac cord in I disconnected the HDMI, and changed the batteries. So when the input worked for the 2 minutes it was with the HDMI unplugged and fresh batteries. The new observation I made was the blink code. The tv just shuts off when i push menu and then comes back on after about 2 seconds with no code. When I push either input button it shuts off and there is a series of three blinks that continuse indefinitely. BTW Thanks for your help so far! As of now I'm just unplugging it and replugging it to change the input setting
  • devilmanex Nov 10, 2008
    The problem did get worse. Now the tv won't even turn on. I unplug then replug it and the power light comes on but there is nothing on the screen. Do I need to call repair man?
  • devilmanex Jan 29, 2009
    i called the repair man and it was exactly what you said. The warranty covered it, thanks for the help!
  • Anonymous Jan 29, 2009
    some of my programs are block and can't seem to get them back. HELP PLEASE
  • jason May 11, 2010
    have you tried to unplug the HDMI and check to see if it does it with the tv?
    did you count the blinking code?
    also are the batterys new in the remote?
    because the remote can give bad signal and the IR sensors (tv and remote)could be dirty or worse , you mght have an internal problem which is impossible to fix on the internet unless you have electronic expierence. so I will help you if you need that kind of assistance, but otherwise I will go thru any steps you think you can do. Does any of those checks work or do you need further assistance?
  • Anonymous Mar 18, 2014
    menu buttons including the remote are not responding on my goldi 21" television
  • 905 Answers
Well the problem sounds like it could be the IR sensor on the tv or somthing in that circut that is failing or the EPROM chip that controls : Vol up/down , Channel up/down , Power on/off ,Menu , Input selection , ect... is failing, thus this will trigger the protection circut to shut the tv down. this kind of a problem only gets worse and can dammage other components if not repaired soon so it will need testing to determine the exact cause
Posted on Oct 14, 2008
  • jason Nov 10, 2008
    yes! I tried to tell you it would get worse , so please unplug it from the wall and call a electronic repair shop , from it still being plugged in the chip still has acess to the power circuit and can cause other problems
    they will have to come and get the tv , they may be able to fix it there , but you should call them soon and if you have a warranty let them know
    sorry about your tv
Look for any jammed buttons on the remote. Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 04, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Unlocking the remote and panel for Sharp Aquos LC-46LE832U 46 in. HDTV LCD TELEVISION
When all else fails read the owner manual page 35:
"• To unlock the buttons on the remote control by using the
touch sensor panel of the main unit (see page 25):
1 Press MENU to display the MENU screen, and then
press VOLl/k to select "System Options".
2 Press CHs/r to select "Operation Lock Out", and
then press INPUT.
3 Press CHs/r to select "Off", and then press INPUT.
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Took 5 minutes to find the manual for this unit. GOOGLE
Apr 05, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do I stop the CC on my Sharp Aquos
Sharp Aquos LC-37G4U
Try the remote.
On the remote is a button labeled CC near the bottom.
Press the button to access a menu to switch off. Each time you press the button it will toggle among the choices.
If the tv has problems, try turning it off and unplugging for a few minutes to reset the EPROMs.
Plug in and turn on. Repeat the above.
If you want to change the size/color of the font you can get into menu mode by pressing the menu botton in the center of remote.
Next use the and > arrows to get to OPTION menu.
Use the ^ and v arrows to get to the Caption Setup menu and press Enter.
Feb 22, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
How to enable the input of lcd
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
( An image from the selected source automatically
Each time INPUT is pressed, the input source
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
Dec 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How are you connecting it to cable tv?
If you are using a coaxial cable to a cable box you have to turn to channel 3.0 with a Sharp remote by pressing 3.0 enter the dot (.) is down by the 0. There is a way around this if you don't have a Sharp remote. You can go into the menu and complete a channel scan. If the model you own is the one pictured then you should have the coax cable connected where it says analog if you are connecting to a cable box this way.
If you are using composite, component, or hdmi cables you press the input button on the television and pick the right input. It is recommended that you do not use the coax cable anyway unless you do not have a cable box. There is an input button on the television and on the remote.
Dec 15, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Lost manual
LC42D62U Manual.pdf
reading your manual (link above) , you have a A/V button on your remote , you will use this button to toggle thru TV , INPUT 1 , INPUT 2 , INPUT 3 , and etc. modes . depending what input ports you plugged your DVD into is what you will need to select . pretty nice TV ya got there . you might want to download and save this manual .
Thank You for using FIX YA !
Jan 25, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Jul 31, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lc42d62u green blinking light
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
Feb 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HDTV Sharp- Input select to watch Cable tv
On the sharp remote you will find an input button. You depress the input button and a menu will appear and highlight the input you are presently on. Hit the input button again to select the next input. If you wait to long to depress the input button it will not work and you have to begin again. This unit will only hightlight inputs have a component hooked to that input.
Feb 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
1,274 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
