Computers & Internet Logo
Posted on Oct 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Device Management Device Mgmt. SonyEricsion communication interrupted
Anonymous
Level 2:
Sergeant:
  • Expert 213 Answers
  • Posted on Oct 13, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
213
Questions
Helped
79371
Points
516
If it indicates that it hasn't actually sent anything to us yet.
The common sync phases for Sony Ericsson devices are:
  • Synchronising
  • Sending
  • Receiving
  • Sync Complete
you would have to double check all of the connection settings in use on the device and also ensure they are correctly linked to the sync application (some devices require that the settings are enabled for the sync application).
Original setting mgmt
renew his software from mobile shop
How to config to work wireless
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid cisco
vlan 1
authentication open
wpa-psk ascii 0 cisco123
authentication key-management wpa
ssid ciscowep
vlan 2
authentication open
ssid ciscowpa
vlan 3
authentication open
Step 5 bridge-group number
Example:
Router(config-subif)# bridge-group 1
Assigns a bridge group to the subinterface.
Note When the bridge-group command is
enabled, the following commands are
automatically enabled, and cannot be
disabled. If you disable these commands
you may experience an interruption in
wireless device communication.
bridge-group 1
subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1
block-unknown-source
My filemate wireless adaptor keeps disconnecting from the router
Try these:
  • Open Device Manager, open the Network Adapters, double-click the wireless adapter to open its Properties, click the Power Management tab, and deselect "Allow the computer to turn off this device to save power".
  • Some internal wireless adapters will have conflicts with your sound card, using the same interrupt. If either of the devices will let you change the interrupt under Properties, Resources, that would be a good think to test. USB wireless dongles are cheap, and there are no interrupt problems.
Driver
In computing, a device driver is a computer program allowing higher-level computer programs to interact with a hardware device.
A driver typically communicates with the device through the computer bus or communications subsystem to which the hardware connects. When a calling program invokes a routine in the driver, the driver issues commands to the device. Once the device sends data back to the driver, the driver may invoke routines in the original calling program. Drivers are hardware-dependent and operating-system-specific. They usually provide the interrupt handling required for any necessary asynchronous time-dependent hardware interface.
My SUMMIT 48Si will not work in console mode. The MGMT light is on constant Any thoughts?
Sounds like the management port is active. I'm sure there is a command to disable that. Not sure what it is by memory.
2helpful
Acer eLock Mgmt has my devices locked out.
This is a Quoye straight from the Acer knowledge base for the elock software...
If you forget your password, you will need to
take your notebook PC to an Acer Customer Service Center.
1helpful
Software up dates for k800i
download the Sony Ericcson Update service from http://www.sonyericsson.com/cws/download/1/110/61/1211192682/Update_Service_Setup-2.8.5.12.exe
then install it, then follow the on screen prompts
Oct 05, 2008 • Cell Phones
Fax interrupts phone call
1. Make sure your [RINGS TO ANSWER] settings are more than the same settings for your answering machine.
2. If someone tries to make a copy while the phone line is in use, they need to press number 1, as if telling the unit that they want one copy. If not, the unit will think you are trying to receive a fax and will interrupt the communication.
Be blessed.
Format new seagate sata hard drive
In XP, click on my computer, right click disk and select format.
In VISTA
control panel
admin tools
computer mgmt
storage
disk management
rightclick the drive you want to format and select format
if the disk is not visible in my computer or disk management, post back your OS for more assistance
Grand Canyon Tech
Grand Canyon Tech
