Question about Microsoft Office Standard for PC
Outlook Express doesn't open attachments on first try
Outlook Express gives the message: "Outlook Express has encountered a problem and needs to close" when I try to open an attachment. It works on the second try.
AppName: msimn.exe
AppVer: 6.0.2900.5512
ModName: officeeav.dll
Modver:15.0.058
Offset:00005606
  • Abel Martin
    Abel Martin Sep 10, 2014
    I found new utility on Internet called MS Outlook Express recovery utility. This utility can help you recover all deleted DBX files. For more details:http://recoverydatatools.com/outlook-exp...
I downloaded Norton 2009
Posted on Oct 19, 2008
I have an EMail with 16 photos attached - it will not "go" nor can I delete it. How can I get rid of it?
Disconnect the network-cable from your computer, to block Internet access.
Start Outlook Express.
Instead of selecting the "Inbox" mail-folder,
select the "Outbox" folder.
Click once to select the E-mail message.
Use your mouse to "drag-and-drop" the message to your "Inbox" folder.
Close Outlook Express.
Reconnect the network-cable.
Open Outlook Express.
Check your "Inbox" for that "undeliverable" message.
Open the message, or delete the message.
Nov 05, 2009 | Microsoft Outlook Express
Outlook express is trying to send a message with a lot of photos attached. It is unable to do this. How can I delete this message.
If your Email is trying to send as soon as you start Outlook Express, you might try this:
Open Outlook Express and go to the top menu, click TOOLS then under that menu, OPTIONS. Under the GENERAL tab, uncheck the box for "Send and receive messages at startup", then click OK.
Close Outlook Express and start it up again. Hopefully this will allow you to delete the Email. Good luck!
Sep 15, 2009 | Computers & Internet
Message: Outlook Express has encountered an
Most likely there is a email with a virus in one of your outlook express folders. Download a 30 day trial of Kaspersky internet security and run a full scan on your computer.
Alternatively, you could try creating a new Identity in outlook express, only problem is you wont be able to access your old emails. But you can always switch back and forth. To do this Click on File – Identities – Manage Identities. Here you can create a new one and configure your email settings. Though this may work, this may only be a temporary solution.
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 05, 2009 | Microsoft Windows XP Home Edition
Outlook Express Not Receiving Attachments From One Sender
  1. Open Outlook Express
  2. Click on Tools->Message Rules->Mail
  3. Check the Mail Rules and Blocked Senders tabs
This is just a preliminary check for anything that may be modified that could be causing your problem. Since the issue is with a specific sender, I would check there first.
Feb 27, 2009 | Microsoft Outlook Express
I'm unable to open .eml attachment in Windows Vista.
Here's some info: E-mail message saved by Microsoft Outlook or other e-mail program; may also contain an e-mail attachment, or file sent with the message. Note: If EML files will not open in Outlook Express, try the following:
  1. Open My Computer.
  2. Select Folder Options from the Tools menu.
  3. Click the File Types tab.
  4. Under Registered file types, select EML Outlook Express Mail Message, then click Advanced.
  5. Click Open, then click Edit.
  6. Type the following line in the "Application used to perform action" box:
    "C:\Program Files\Outlook Express\MSIMN.EXE" /eml:%1
  7. Click OK twice, then close the window.
EML files may also be opened in Internet Explorer since they are formatted the same as .MHT files; changing the file extension from ".eml" to ".mht" should cause the file to open directly in Internet Explorer.
Hope this helps.
Dec 25, 2008 | Computers & Internet
Can't Open Attachments In Outlook Express
If you cannot open attachments while using the Outlook Express e-mail client, your security settings may be too high. When you try to open attachments, you may see the following message: “OE removed access to the following unsafe attachments in your mail.”
To check your e-mail security settings:
1. Open Outlook Express.
2. Click on Tools in the menu, and scroll down to Options.
3. Click on the Security tab.
4. Make sure “Do not allow attachments to be saved or opened that could potentially be a virus” is UNCHECKED.
5. Click on the Apply button. Click on OK.
You should now be able to open attachments.
Sep 30, 2008 | Computers & Internet
Attachments to E-mail won't come up
Turn Off Attachment Blocking in Outlook Express 6.1 SP1 Introduction Many viruses are transmitted through files attached to e-mail messages. For this reason, blocking of attachments is now a standard feature of many e-mail programs, including Outlook Express 6.1 SP1. Attachment blocking has been available in Outlook Express for some time, but it is now turned on by default.
When using Outlook Express to read your e-mail, you may notice a yellow message stating: “OE removed access to the following unsafe attachments in your mail: filename(s).” Please note that the attachment is still included in the message, you simply cannot access it because of a security restriction that can be turned off. These instructions explain how to turn off this restriction.
Procedure
  1. In Outlook Express, select the Tools menu, and click Options.
  2. Select the Security tab, clear the Do not allow attachments to be saved or opened that could potentially be a virus check box, and click OK.
  3. You should now have access to all attachments in your e-mail messages. Remember, you should never open an attachment unless you are certain it does not contain a virus. It is recommended that you save the file first, and then open it from the saved location.
Jul 26, 2008 | Gateway Computers & Internet
Can't open attachments in Outlook
what error messages are you getting. If any.
Apr 20, 2008 | HP PAVILION A6230N DESKTOP PC
Outlook express file recovery tool
Have a look at this follow the instructions it should make it all better.
MailNavigator can cope with the task of restoring out-of-order dbx files when Outlook Express itself cannot read them and when a range of other programs are not capable of restoring the information contained in these files. These situations can happen because of viruses, computer breakdown, power interruptions and many other reasons, leading to errors in the file system.
If your computer crashed, first of all you should make sure you have backup copies of your dbx files as well as of all other important data. It's good if you make backup copies of your data on a regular basis. But, unfortunately, in our experience situations are often encountered where there is already nothing to restore.
The process of data recovery from dbx files includes two stages:
If your Outlook Express program is properly installed and tuned, MailNavigator will automatically find the dbx files from the information in the systems register. In this case you can load the dbx files from the Information Retrieval page by double clicking on each of them. Or search for messages in these files using the search system.
If MailNavigator cannot automatically determine the location of the dbx files (for example if these files are on a CD), first you have to find them using search tools, and then load them into MailNavigator using the menu command:
File | Load External Mailbox...
eudora1.gif Once you've read the messages, select the ones that should be exported back into Outlook Express. You can use various filters to select the messages. If you want to export all the messages browsable in the Navigator at once, use the menu command:
Message | Select All
Having selected the messages, export them using the menu command:
Message | Save as...
eudora2.gif In the opened dialogue box, indicate the file and export path, and choose the file type: Eudora mailbox.
When the command is executed, there will be files in the export directory with extensions .toc and .mbx, and also a file descmap.pce. If there are attached files in the exported messages they will be saved in the subdirectory Attach.
Once the mailbox in Eudora format is created, open the program Outlook Express and use the menu command:
File | Import | Messages...
In the opened dialogue box, as the program from which the message is imported, select: Eudora Pro or Light:
In the next dialogue box indicate the directory in which you put the messages from MailNavigator at the export stage:
Further, if Outlook Express finds mailboxes in this directory, it will suggest you select one of them for import:
All that remains to do is to press the Finish button, and a folder containing the imported messages is created in Outlook Express. hope this helps
Jan 04, 2008 | Microsoft Windows Server Standard 2003 for...
Winmail to Outlook express 6
Outlook Express does not display any message attachments if TNEF-encoded file (winmail.dat) was received. If you are expecting some attachment, but do not see any, it still can be there.
To decode such a message perform the following steps:
  1. Save the whole e-mail message to an *.EML file via File, Save As, or Drag-and-drop.
  2. Open the *.EML file in a text editor such as Wordpad or Notepad.
  3. Locate the line Content-Type: application/ms-tnef;, and change the Content subtype to something else, such as Content-Type: application/zzz;
  4. Locate the line name="winmail.dat" and change to name="winmail.tnf". You may change the winmail part as well, if desired.
  5. Save the *.EML file from the text editor.
  6. Double click the *.EML file from the Windows File Explorer. This will open the message in a mail window and the TNEF attachment should now be available for saving.
  7. Drag the saved attachment into the Winmail Opener program. Decoded attachments will then be there and can be dragged or opened.
Dec 07, 2007 | Microsoft Office Outlook 2003 for PC
Microsoft Office Standard for PC Logo
82 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
