The battery does not charge. Charger light is not on.
    Sergeant:
  • 196 Answers
Check fuse in the charger plug if it is ok then your charger has malfunctioned and you will need a new one... check the manufactures page for your laptop for a replacement
Posted on Oct 13, 2008
    Genius:
  • 1,250 Answers
How old is your UPS if your ups is more than 2 years old then it may be the problem of your battery replace it
or check the out put of your ups card take it to the technician
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Yellow and green light are on but wont charge battery?
If both lights are on and both are flashing the charger is reading the battery as defective and the charger won't charge the battery. If the Red light (yellow if plastic is faded) is on and the green is flashing the charger is trying to charge the battery. If the battery won't charge replace it.
Dec 21, 2010 | Ryobi Multi-Volt Battery Charger
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Battery not charging
the charger light detect the battery level charge, shows red when charging and green when fully charged.when the charger light is not lit,may be the battery dosnt hold any charge that means its likely that the battery is defective
Dec 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
Jun 26, 2009 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
