VAIO VGN-A190 works great with XP, but is very slow with VISTA! The CPU is 100% utilized with VISTA every time there is a disk access or screen update (unsure which one)!
  • naz-s Oct 13, 2008
    I upgraded the RAM to 2-GB and 4-GB for the Memory Stick for the Vista "booster" (used for the Page file / Virtual disk file)?.
    Naz-s
The reason is your machine is too slow for VISTA. Your machine need better vidio hardware and more ram.
Vista is more graphic intensive.
Posted on Oct 13, 2008
Sony vaio vgn-fw290
Did the Restore complete? If not try it again.
If the Restore completed and when you boot the machine all you are getting is a black screen with a blink cursor try the steps below:
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 16, 2012 | Sony VAIO FW Series Notebook PC...
I would like to disable the touch pad and use an external mouse. Sony Vaio VGN A190
Please follow the steps to disable the Touchpad under XP environment:
First, click the Start button, then click VAIO Support Central .
In the VAIO Support Central window, in the left pane , click System Maintenance .
In the right pane , click VAIO Central .
In the VAIO Central window, click the System Information tab.
On the System Information tab, click the Plus symbol next to Keyboard and Mouse .
Under Keyboard and Mouse , double-click Built-in Pointing Device .
In the Built-in Pointing Device window, click to clear the Enable box.
Click the OK button.
In the Built-in Pointing Device dialog box, click the Yes button.
Thanks!!!!
Dec 24, 2010 | Sony VGN-A190 Notebook
I need VAIO® VGN-FJ170/B Restore Disks
You can create your own disc from the Vaio recovery center.
If the computer is no longer booting up and the Vaio Recovery center is no longer accessible, you can call sony parts center to check if you can buy a recovery disc for your unit
parts center 8004887669
Sep 23, 2009 | Sony VAIO VGN-FJ170/B Notebook
VAIO VGN-AR630E Drivers for Vista Ultimate
Vista Home premium drivers will work perfectly with Windows Vista Ultimate. When installing Vaio event service and Vaio Control center make sure that you run setup file as administrator. Right-click the setup file and select option "run as administrator". By reinstalling utilities this way they will work perfectly well
May 17, 2009 | Sony VAIO VGN-AR630E Notebook
Hard disk access terribly slow - Sony VAIO VGN CR490
Often times, when a PC has be used for a long period of time, information becomes fragmented on the disk, causing read errors and various problems similar to what your experiencing.
To rectify this issue:
Start > All Programs > Accessories > System Tools > "Disk Defragmenter"
I would also suggest using a free tool called Ccleaner. This is a wonderful maintenance tool.
Please visit this site for the download:
http://www.ccleaner.com/download
This utility coupled with a defrag should solve your issue.
Please let us know if you have any more issues, as it may be related to Malware.
If you found this information helpful, and it solved your problem, please take a moment to rate the solution. Thank you.
Apr 22, 2009 | Computers & Internet
Backup for Sony vaio
If you got the recovery disk along with the Vaio laptop, good enough.Insert the disk and reboot, follow instruction displayed on the screen to restore.
If you dont have a disk, can try this :--
Reboot and press F11 to try and enter the system recovery mode, if you can then you're good, simply follow the prompts to perform a system recovery.
Let me know the status please.
Thanks
Mar 30, 2009 | Sony VAIO PCV-RS710GX PC Desktop
Fn key is not wokring after installing xp on vgnfe880e laptop
You will have a tough time, but there is a Sony XP utility driver out there that will take care of your problem. I do not have it, but know it is available. Here are some that I have found for you.
Hot Keys
ftp://ftp.vaio-link.com/pub/Vaio/Hotkey/
Memorysticks
ftp://ftp.vaio-link.com/pub/Vaio/MemStick/MSD_Sny_1020.zip
other driver for other model memory stick
ftp://ftp.vaio-link.com/pub/Vaio/MemStick/MSD_52217.zip
Others
ftp://ftp.vaio-link.com/pub/Vaio/PowerPanel/
I hope you can find what you are looking for in one of these.
Mar 18, 2009 | Sony VAIO VGN-FE880E/H Notebook
Which windows is suitable for vaio vgn-nr280e
Windows XP
You can run the Vista utility to check if you can run vista on that machine, but I don't think you'll be able to.
XP is your way to go!
Hope this helps muhammad_far.
Jan 17, 2009 | Sony VAIO VGN-NR280E/W 15.4" Notebook PC...
How can Isettle to operatethe built in camera of VGN S210P -VISTA
You need to re-install the Camera Driver after installing the Vista Operating System in the Computer. Please try installing the WIndows XP Camera Driver and the Vista Camera Application in the Computer to resolve the issue.
You can download the Camera Driver here.
Please download and save the file in a folder in the Computer. Then, please open the folder where the file is saved and double click on it to begin the installation. After installation of the Driver, please restart the Computer for the settings to take the effect.
Then, please download and install the Vista Camera Application and Updates in the Computer.
Download the VAIO Camera Capture Utility
Download the VAIO Camera Capture Utility Update
Sony Camera Filter Driver Update
Please install the VAIO Camera Capture Utility and Updates in the same order. Please restart the Compuer after each installation for the settings to take the effect.
This should fix it..
Good luck..
Dec 08, 2008 | Sony VAIO VGN-SZ210P/B PC Notebook
Formating problem
hi i have sony vaio VGN-NR-220E i want to know how i can format this system there vista operating i want Windows xp
Aug 22, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
