Question about E-Machines M5309 Notebook
Emachines m5309 turns on, but will just keep trying to restart over and over
My laptop will turn on, and it will show the screen explaining that the windows had not been shut down properly and to retart ... well i have tried every way to restart and it keeps doing the same thing. please let me know if you can help
  • charliex Oct 13, 2008
    ttried to start in safe mode...just kept trying to restart and came back to the same page as before.
I had the same problem. The processor is overheating during start up. At first, it would quit while I was watching a DVD, but it got worse until it wouldn't even boot. I thought it was software but I stuck in a fresh hard disk and tried to install the recovery CD's, but it would do the same thing. I disassembled the laptop, blew out the cooling fins, and applied new heat-sink grease to the processor. That got it to boot on the old HDD, but while I was transferring files it would do the same thing. I finally removed the bottom cover and set it upright in the deep freezer. It worked long enough that I could recover my files. I ended up replacing the processor and RAM, used the recovery CD, and installed the XP-SP3 package. I kind-of eased into using it and it worked great until I tried to install HP printer software. After I did, I noticed a system slow-down and that the cooling fan would kick on more often at idle. I uninstalled the printer and now it works fine for surfing, photos, etc. I just print through a networked printer and don't install anything I don't need.
Posted on Mar 18, 2009
    Problem Solver:
  • 12 Answers
Try starting in safe mode once in safe mode go to control panel click on system than device manager and if you recently installed any new hardware uninstall it that should get you to boot up correctly
Posted on Oct 13, 2008
  • richard reyes Oct 13, 2008
    what o/s do you have?
My emachine laptop wont work i turn it on and it comes up with a blue screen then truns off now it only turn on to a black screen and a mouse pointer is there any way to just reset it to what it was when i...
try rebooting the computer and as soon as it turns on tap on the "F8" key until a new boot menu appears, choose "safe mode" if the computer starts successfully in safe mode. restart it and allow to boot normally. If this fails comment back as to whether it started in safe mode or not and I will attempt to help you further,
Mar 02, 2013 | eMachines Computers & Internet
When i turn it on it shows logo screen real quick then it goes to a screen saying something about boot mode
MAKE SURE YOU HAVE USB DEVICES UNPLUGGED THAN RESTART AGAIN IF IT GIVE YOU THE SAME OPTION RESTART PRESSING F12 IT SHOULD GIVE YOU OPTION LIKE 1 HARD DRIVE 2 CD ROM ETC CHOOSE HARD DRIVE (HHDD) THAN ENTER. OTHERWISE THE CABLE THAT GOES TO THE HARD DRIVE NEEDS TO BE RECONNECTED OR SIMPLY YOU NEED A NEW HD....TEKGODS.COM
Jul 27, 2012 | eMachines eM250-1915 Netbook
When i push the power button on my emachine the e screen flashes and it wont turn on what do i do to fix this?
If you just did a memory upgrade then the new chip is either not seated properly or the wrong type or even bad. Since it won't boot the problem is the ram in memory slot one. You need to rock it a bit to make sure it is seated before snapping it in. If it is the wrong speed or type you need to exchange it. It can also be bad but that usually means a counterfeit these days or you gave it a static shock and burned it out..
If you put your old ram back in you should be able to work again until you get the ram replaced.
Sep 02, 2011 | E-Machines 128mb memory upgrade for...
My sons laptop crashed and says that I need to re-install windows. I have the disk and whenever I put it in, the prompt comes up to restart the laptop to continue with the install. How and what do I...
Hi Welcome to FixYa!
You could follow the steps on the manual for your E-Machine for you to be able to restore your computer back to defaults. But just to remind you, it will delete everything on the computer and restore it back to factory defaults.
The manual can be found on this link:
http://www.manualowl.com/m/eMachines/M5309/Manual/119648
refer to page 63 for the instructions on the recovery process.
Hope this could help you a lot!
Jun 30, 2011 | E-Machines M5309 Notebook
I installed a drawing tablet on my emachines netbook 250, after the installation the setup program asked if i wanted to restart, i said yes. It began shutting down some programs but then nothing happend so...
This blue screen is commonly referred to as a BSOD - Blue Screen of Death. Unfortunately, if your computer is looping a BSOD your options are greatly limited and you will most likely need to do a complete wipe of your computer and start over. Getting your data before this happens though should still be possible! Assuming you've a flash drive or external drive with the necessary space, you'll need to boot your computer into Safe Mode. I'd say there's a decent chance you'll be able to get into Safe Mode without a BSOD just so you can get your files. Note that a lot of things will be disabled in Safe Mode, so chances are you won't be able to do your work in it. To do this, turn your computer off and then back on. Right as your computer turns on, hold down the F8 key. Since every computer is different it's difficult for me to describe what you'll see, but if you see anything related to Safe Mode, you want to select that.
Mar 12, 2011 | eMachines eM250-1915 Netbook
How to fix emachines netbook , model 250-1162 the 10.1 LED LCD screen will not turn on
Is it the screen or the laptop?
Have you plugged an external monitor to see if its booting?
If it is booting with an external monitor, you may need a replacement screen (google your model and replacement screen)
If its not booting, you could try this.....
http://www.fixya.com/support/r5335055-unable_start_windows
Jul 18, 2010 | Acer eMachines eM2501162 Netbook
Emachines m5309 won't boot
If you have a Install Cd for your version of windows, run it and select repair. If you are running vista, press F8 when the computer is booting and select System Restore (first one on list). If all else fails, re-install windows. You may or may not loose data based on the severity of the error.
good luck
Jun 25, 2009 | eMachines eMD620-5133 Notebook
Computer comes on, shows a blue screen, and restarts on it's own.
Try to boot into Safe Mode.
If you're able to, let me know and we'll go from there.
Jun 17, 2009 | HP Compaq Presario 2223US Notebook
E-Machines M5309 Notebook Logo
197 people viewed this question
Top E-Machines Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
