Question about Nokia 3100
Master code i want to know unlock code of nokia 3110 my imei is 010700-00-783592-2 give me the master code ? based on my imei. my phone is restricted .give me the code
  • agar53 Oct 14, 2008
    ı dont know security code. ı need master security code my phone is nokia3100
  • 3 Answers
You can find the master code from unlock free @ free of cost for this model.
Posted on Sep 16, 2009
  • samfrank00 Sep 27, 2010
    nice sharing..........
Here is your master security code 4360133244
Posted on Nov 07, 2008
  • Antonio Diaz
    Antonio Diaz Aug 11, 2014
    k do I click what im playing on as old device ore new
Restriction code
You can get the restriction/unlock code for Nokia 3110 from Unlock-Zone.com . There you have to give your Country and current network name along with your IMEI number to get the restriction/unlock code.
May 05, 2013 | Nokia 3110 Cellular Phone
Nokia 3110 undo restricted code
SIR MY PHONE USED IN NOKIA 3110 C .PLZ SIR RESTRICTED CODE NUMBER
Dec 17, 2011 | Nokia 3110 Cellular Phone
Nokia 3110
I AM DIPAK,MY HANDSAT IS NOKIA 3110,WHEN I ENTER SIM CIRD THEN WANT RERTRICTION CODE, IMEI:356833027500978
Dec 06, 2011 | Nokia 3110 Cellular Phone
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
PZL TRY THE FOLLOWING
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#92702689# [*#war0anty#]
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
3110 phone restricted
Restriction is nothing but the unlocking for your mobile,
unlocking means in your phone just removes the SIM card restriction on your phone so that you can use any other network's SIM card.
To get the restriction code for your Nokia 3110 model mobile, just visit this site www.wickedunlock.com/nokia-3110/rs11wp9 , in this site just give your IMEI number , country & network lock
after that within a short period you can get the restriction code for your nokia mobile............I hope this may helpful to you.........
Sep 10, 2011 | Nokia 3110 Cellular Phone
My phone is asking for the restriction code?
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
OR:
You Go to:
or visit http://www.unlockme.co.uk/master.php
unlocking free download here unlock.nokiafree.org
Thanks
Aug 30, 2010 | Nokia 3110 Cellular Phone
I forgot my 3110 reset code
First try it:
Default 4 Digit user code: 1234 or 0000
If Problem not Solved So
Secend Option:
I will be able to get you the master code to turn off the security code and reset to what it was when it was new (0000) it will remove the security code and won't ask for the code.
The code will only work if it is asking for the security code when you switch the phone on.
The code won't work if the wrong code has been entered more than 5 times, if it has the phone is hard locked and can only be unlocked using flashlead and unlocking software. Shops will not do this anymore as it is illegal!! You might be able to buy the software of the net.
If the phone is not hard locked i will be able to give you the master code that will reset the security code giving you access to your phone.
I will need your IMEI number, which is on the back of the phone under the battery and looks like 123456/12/123456/1 it is 15 digits long.
I will need this information as every phone has a different master code based on the IMEI number.
Let me know and i will be able to assist you
Aug 23, 2010 | Nokia 3110 Cellular Phone
Nokia 3110C phone restricted - enter restriction code.. How I know the restriction code to unlock the phone?
hello
the code which you ask for to unlock your nokia phone 3110C is 12345 this code will work out the problem of restriction enter it on your phone then your phone will be free to your operation
Good luck and thanks for using fixya.
May 28, 2010 | Nokia 3110 Cellular Phone
My nokia 3110C phone restricted. and ask restricted code wat to do
my phone model=3110c
imem no=353081028517343
i want master code or security code
thx
Jan 30, 2010 | Nokia 3110 Cellular Phone
Please help me unlock the security code of 3110
hi is it the security code you need when you switch the phone on if it is this code give me your imei number its on the back of phone under battery and looks like 123456/12/123456 give me this code then i can give you the master security code but need your imei number as every phone has different code let me know what you want to do ok
Jan 10, 2008 | Nokia 3110 Cellular Phone
Nokia 3100 Logo
156 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
