Question about iLO V27DMBX Television
Ilo 27 inch tv
My tv has the red light on in the front.but when you turn the power button on to turn it on manualy or with the remote you hear a click but it does not turn green to turn on ?
  • 2 more comments
  • pjoh244880 Nov 01, 2008
    I have an ILO 27", Red light on front but won't turn on. I tried unplugging it but that doesn't work anymore.
  • sherryripa Nov 26, 2008
    tv wont turn on
    size 27 inch
  • Turniton Dec 07, 2008
    Mine did the same thing, wouldn't turn on... I tried the unplugging for a few weeks now it won't turn on at all. The red light blinks once but nothing happens. The tv is barely over a year old.
  • jason May 11, 2010
    have you tried unplugging the tv for a while?
I too have the same problem. We've had the ilo27 for almost 2 years and it suddenly decided to not turn on anymore. Red light-itus.
I did find a little trick if you are not so mechanical like me and don't want to risk opening the back. I know this isn't a cure, but you CAN get around this by simply pulling the plug from the wall and plugging it back in. It comes on with remote or manually every time!!!
A little inconvenient, but a way around it temporarily!
Posted on Oct 13, 2008
My tv wont turn on when i press the power button on the tv ?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 03, 2014 | Philips Televison & Video
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv wont turn on
Ur high voltage is dead,the FBT,the flyback transformer is dead.The big black block of plastic with a red wire with a cap hook to the CRT(tv tube).
Mar 19, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
ILO 27" LCD don't start up.
check batteries in remote, does it click back into stand by when u press power button?
Dec 11, 2008 | iLO 3200 32 in. LCD Television
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
chris
Mar 21, 2008 | Sony KV-27V40 27" TV
ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
May 23, 2007 | iLO 3200 32 in. LCD Television
iLO V27DMBX Television Logo
427 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
