Question about Brother DCP-7020 All-In-One Laser Printer
Won't scan 8.5 X 14
I am trying to scan a sheet of legal paper 8.5 X14.
I have configured the settings to show the correct dimensions, yeteverytime the jpeg comes out as a 8.5x11, cutting off some of the page.
I have tried it on custom thru software on my PC, and using the scan button on the machine. Same result - 3 inches cutoff.
  • darsk47 Nov 26, 2008
    Perfect ! That did it. Thank-you
Go to the "Brother" folder in the Start Menu (Start > All Programs > Brother > 7020) and select the "Scanner Utility." Choose "8.5 x 14", and then reboot the computer. You'll be good to go.
Posted on Nov 22, 2008
How to copy legal to letter on copystar CS 4005i
Make sure your default settings are for AUTO paper selection and 100% magnification to start. That is the most common default settings. Then, under "Zoom" change to AUTO magnification and under PAPER SELECTION specify Letter (either landscape or portrait). Now when you copy a legal original (8.5" x 14") it will be reduced at 78% to fit it on an 11" sheet. An alternative is to use "X-Y" zoom. Now you can stipulate 78% for the "X" dimension and leave the "Y" dimension at 100%. You will want letter size paper to be feeding lengthwise (portrait). Now you can copy legals and the image is reduced top-to-bottom only, leaving it much more readable.
Mar 16, 2015 | Copystar Office Equipment & Supplies
Im trying to make legal size copies
Check your owners manual to see what the acceptable paper sizes are. Legal paper is 8.5"x14". If legal paper is listed in the acceptable paper sizes there should be a tray to handfeed this size paper. Look for the term "single sheet manual bypass" in the owners manual. I beleive this tray or slot is on the left hand side of the printer.
Dec 06, 2010 | Brother MFC-7340 All-In-One Laser Printer
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
Sharp AL-1551CS Scan Problem
hi do u have set tha adf limet for 8"x14" just set the corect size of origlan from adf
thanks
May 11, 2010 | Sharp AL-1551CS Copier
I have a Biz hub C450. Tray 2 I have legal paper
go to service mode > system 1> marketing area
then choose europe button to fix that
Feb 04, 2010 | Minolta Office Equipment & Supplies
Cannt make 8.5 x14 booklets
Not sure you can with legal paper (8.5x14). But certainly with tabloid (11x17) or letter (8.5x11) you should.
If you are trying to do it via printing, check on the machine itself. If you try to select the legal paper tray, I would think it will tell you if you can or can't, but I am not 100% sure since it's been a while since I have worked on an iR8500.
Dec 07, 2009 | Canon imageRUNNER 8500 Copier
Samsung Scx-4216f wont pick paper out of drawer
Below would be the suggested solution regarding paper feeding problems;
If Paper does not feed into the machine.
• Remove any obstructions inside the machine.
• Paper has not been loaded correctly. Remove paper from the
tray and reload it correctly.
• There is too much paper in the paper tray. Remove excess
paper from the tray.
• The paper is too thick. Use only paper that meets the
specifications required by the machine.
Below is the suggested paper specifications;
Supported Sizes of Paper
Paper Dimensions* Weight Capacity**
Letter 8.5 X 11 in. (216 X 279mm)
• 60 to 105 g/m2 bond (16 to 28 lb) for the paper tray
• 60 to 120 g/m2 bond (16 to 32 lb) for the Bypass tray
• 250 sheets of 75 g/ m2 bond (20 lb) paper for the paper tray
• 1 sheet of paper for the Bypass tray A4 210 X 297 mm (8.3 X 11.7 in.)
Executive 7.25 X 10.5 in. (191 X 267 mm)
Legal 8.5 X 14 in. (216 X 356 mm)
Folio 216 X 330 mm (8.5 X 13 in.)
Hope this helps!
Sep 10, 2009 | Samsung Office Equipment & Supplies
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Legal paper
Legal size paper must be loaded into the automatic sheet feeder (ASF) in the rear, and the Feed Switch used to set Auto Sheet Feeder.
For printing, in the Printer Properties (or Printing Preferences) dialog box, select the Page Setup tab, and set the Paper Size to Legal.
May 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Brother DCP-7020 All-In-One Laser Printer Logo
634 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
