Philips DVP596K/75 DVD Player Two disks loaded and now stuck.
SOURCE: Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
moz-screenshot.jpgmoz-screenshot-1.jpgRegion
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
Posted on Mar 04, 2009
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
stonephoenix
  • 563 Answers
SOURCE: dvd player won't load disk
The only troubleshooting you can try is to unplug the unit for 30 minutes. If the problem persists, the unit needs to be repaired. If you're under warranty, the manufacturer will repair or replace the unit. If you're out of warranty, they may have an out of warranty exchange or repair program.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
  • 4 Answers
SOURCE: Hi, my Philips DVDR3455H/75 DVD/Hard disk doesnt
THE DVDR3455H HAS A COMMON PROBLEM AFTER A FEW YEARS THE HARD DRIVE GO BAD, IT WONT BOOT UP
99% OF THE PROBLEM WITH THE PHILIPS DVDR3455 IS THE HARD DRIVE.
IT WILL KEEPING REEBOOT OR IT WILL HANG ON THE PHILIPS LOGO.
IT IS NOT A FIRMWARE PROBLEM IT AHARD DRIVE PROBLEM.
ONE THING YOU SHOULD KNOW, IF THE HARD DRIVE IS BAD YOU WILL NOT BE ABLE TO UPGRADE THE FIRMWARE IT WILL NOT READ THE CD OR DVD DISK.
AT THIS POINT IT NOT LOOKING FOR A FIRMWARW DISK BUT IT LOOKING FOR THE BOOT UP SOFTWARE.
OR THE LOAD CD WHAT PHILIPS CALL IT.
SOLUTION REPLACE THE HARD DRIVE WITH THE LOAD SOFTWARE INSTALL ON IT.
THE HARD DRIVE IS SOLD ON EBAY JUST LOOK FOR DVDR3455H YOU WILL FIN NEW DRIVE READY TO INSTALL THAT WILL FIX YOUR PROBLEM.
Posted on Dec 11, 2009
  • 5603 Answers
SOURCE: My DVD player stays stuck on loading. How can I
If all DVD's you try act the same, I would clean the read head. If that doesn't work, then drive needs to be serviced. Hopefully nobody smked cigarettes near the unit as that coats the optics. Clean the read head VERY carefully with a Q tip and 99% isoprophyl alcohol. Ensure that no fibers get stuck around the read head... it is VERY fragile.
If only one disk won't finish loading, then the disk itself is probably bad and the drive is OK.
Posted on Jan 03, 2010
Testimonial: "Very helpful. We had a small kitchen fire that put out a lot of smoke, so that was probably the problem"
Fix a stuck disk compartment door on a Philips DVD player
Hope this helps: https://www.youtube.com/watch?v=sa96VVH8z4I
Jan 01, 2015 | Philips Bdp3380/05 3D Blu-Ray Disc And Dvd...
Error sign
Try using a cleaning disk to remove dirt etc from the laser eye These disks cost about $20 and are invaluable to keep the player in good condition. If you use a lot of hire dvd's they often have a lot of dirt and residue on them from other peoples dirt units. 99% of errors lo0ading or insert disk into player are from a dirty iris.
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Philips Televison & Video
When i tryt to play a dvd in my philips DVP3144 it keeps flashing load and wont play
Try a cleaning disk in the player to remove accumulated dirt from the laser eye. This accounts for 99% of load error and insert disk in player errors
Feb 27, 2010 | Philips Magnavox DVD/VCR Dual Player
Nov 03, 2009 | Philips DVDR3455H/37B
Codes to make philips soundbar hts 8140/75 mulitzone
I followed another post which is a generic code for all philips dvd players. open the dvd drawer, push 9.9.9.0, close drawer. done! terrific
Jun 05, 2009 | Philips DVP5990 DVD Player
Dvd stuck in recorder
Power of and some players got small hole next to draw for hairpin to open manual some disk is from diffrent regions code 1 or 2
Mar 20, 2009 | NexxTech EDP3110
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
