Question about Iomega (32961),(35GB/90GB) External Magneto-Optical Disk Drive
Booting Vista from a Pen drive ..........
Hi, I want to boot my LAPTOP(Windows Vista) from a Pen drive. How to make a pen drive boot able? and i don't have a FDD. Please suggest .......
  • 81 Answers
Hi.
It is possible use this link for step by step procedure.
http://community.bartdesmet.net/blogs/bart/archive/2007/10/07/getting-started-with-windows-pe-2-0-for-windows-vista-boot-windows-from-a-usb-flash-drive.aspx
I think it will help you.
Regards
Faraz.
Posted on Oct 13, 2008
My hpv165w 4 gb pendrive shows empety
Format the usb key with HP USB Disk Format Tool.
Then download Universal USB Installer (Pendrive Linux) which has support for booting/installing Windows Vista, 7, and 8
Mar 29, 2013 | PNY HP P-FD4GBHP165-EF BLUE HPV165W USB...
Tip
Windows 7,Linux and other OS install from USB Pen drive, Flash Drive
To Install Windows 7 via USB Flash Drive (Pen Drive)
You need:
USB Flash Drive (Pen Drive) minimum 4 gb for windows 7
Windows 7 ISO image file.
UNetbootin software download from here UNetbootin
Download the Unetbootin software, and open the file and click "RUN".
below window will pop
You can aslo install other OS's like linux etc etc. for Windows 7, click "Diskimage" radio button, locate or browse the ISO file of your OS by clicking "..." button.
select Drive: (in my PC usb drive is "I:" and press OK.
Next window looks like below picture
Wait till Installation Compleate.
after compleation. Click "reboot" to install to the same PC, or remove the Flash drive(Pen drive) and plug it to another PC or Laptop USB
and boot that System by USB Flash drive.
To do this Select the USB boot option from the BIOS. Or to boot from USB go through your Motherboard User Manual.
This method works on most of Machines with USB booting option.
I personally installed 100's of PC's via this method
thank you. Keep smiling. aaarwind
for other OS setup's via USB drive refer to below Website:
UNetbootin - Homepage
on Jan 20, 2011 | Computers & Internet
When i am swiching on the laptop it shows os not found
Dear Friend,
As there is no primary drive in this vaio, it boots form Hard drive. If OS on hard drive is corrupt OR HDD is bad then you will get such massage. Go to set up. Enable external booting option. Try booting the system from USB pen drive ( You have to make a bootable pen drive ). If it boots then you have to replace HDD.
Dec 05, 2010 | Sony VAIO VGN-UX280P Notebook
How to set up windows xp to laptop without using cd rom
HELLO BROTHER ITS VERY EASY TO INSTALL XP THREW PEN DRIVE PLZ CONTINUE THESE STEPS TO INSTALL XP THREW PEN DRIVE
STEPS:-
1.
http://files.extremeoverclocking.com/file.php?f=197/</code>
CLICK ON PRIMARY DOWNLOAD SITE & DOWNLOAD USB DRIVE BOOTABLE TOOL
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON
http://files.extremeoverclocking.com/file.php?f=196/</code>
3. COPY XP FILES ON PEN DRIVE WITH FOLDER NAME(WINXP)
4. BOOT FROM USB
5. AFTER COMPLETE BOOTING U WILL SEE THE PROMP C:/>
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
9. C:/WINXP/I386>WINNT
10 NOW UR COMP START SOME FILES AFTER COMPLETING THIS UR COMP WILL RESTART
11. DOESN,T REMOVE UR PEN DRIVE BUT SELECT OPTION BOOT FROM HARD DISK
12. DONT FORMAT THE C: AND CONTINUE UR INSTALLATION AS A BOOTABLE CD
Thankyou
Amit Bhardwaj
May 08, 2010 | Microsoft Windows XP Home Edition
My laptop hangs on inserting any pen drive if it is inserted after booting; but if it is inserted before booting my laptop it works properly n without any problem.....
when you insert any pen drive generally it searches for the drivers and do some checking to see if it has to install drivers for the new hardware and it takes time...
Jul 07, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
For bootable pen drive
first of all:
the computer u want to boot with the usb-pen drive has to support booting from usb (BIOS setting)
use program drivekey by hp to make usb-stick bootable(format to FAT or FAT32
get usbdos + components or linux as operating system on stick, u cannot install windows on a stick!
good luck, many have tried, only pros worked out how...
Jun 12, 2009 | Microsoft Windows XP Professional With...
How to make bootable pen drive
A FEW THINGS BEFORE YOU DO THIS....
1. Your Laptop has to support booting from a PEN DRIVE. Some BIOS's may refer to your pen drive as a USB floppy or USB zip.
2. The USB flash(pen) drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. Below is a utility from HP that you can use to make your pen drive bootable.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=MTX-UNITY-I23839&jumpid=reg_R1002_USEN
Mar 26, 2009 | Computers & Internet
I'm Having problem with Vista, not detecting Pen Drive
Unplug the pen drive before booting (newer laptops support booting from a USB drive, and they restore your "healthy restore point".
Format the Pen drive from Disk Management (right click on computer, choose manage, select Disk Management) to 32 bit fat, this leaves it compatible with Windows 98 SE, but the 16 Bit seems to give Vista fits. Good luck.
Jul 30, 2008 | Microsoft Windows Vista Ultimate Edition
Iomega (32961),(35GB/90GB) External Magneto-Optical Disk Drive Logo
227 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
