Question about HP Photosmart D7160 InkJet Printer
Picture Quality The color in my picture didn't match the color on the memory card.
    Genius:
  • 1,847 Answers
Check the ink level in the cartridge, performe the cleaning wizard. that should fix the issue.
Posted on Oct 13, 2008
I dont have a memory card can I still take pictures an unload to computer with just camera
Yes, you can take pictures without a memory card, but not very many of them. At the camera's best resolution it will hold only five pictures. No, you will need a USB cable to connect the camera to a computer so you can download pictures without using a memory card.
Unless you're only going to take five pictures at a time or reduce picture quality (in which case why didn't you buy a less expensive camera in the first place?), you're going to want to invest in at least one memory card and perhaps a card reader.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 25, 2011 | HP Photosmart M417 Digital Camera
Trutech Digital Photo Frame
Image quality using default factory settings is awful. Colors are over-blown, faces are washed-out, and highlights are cropped. People on the internet compained that there is no brightness control -- there is..but its hidden in a menu. Press the Setup button on the remote and move to the "System" settings. I've found these settings produce a fairly correct balance of color, detail, and brightness:
* Brightness=5
* Contrast=1
* Saturation=2
Mar 31, 2008 | Electronics - Others
WHAT IS THE EXPANDABLE MEMORY CAPICITY OF EX-Z550?
Theoretically unlimited. You can shoot until you fill an SD/SDHC card, then swap it for another card, and so on.
As for how many pictures will fit on a single card, that depends on the size of the card, image size and image quality settings, and the subject of the picture (a picture of a blank wall will take less memory than a picture of a field of colorful flowers). You'll find some guidelines on page 175 of the manual.
Aug 24, 2010 | Cameras
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
Yellow lines appear in picture after taken. Picture color is way off even when lines are not very apparent. Does not do this all the time! Picture quality is excellent when all is well!! Whats up??????
Ok dont worry about that, first thing you need to do is to remove the memory card., Turn On cmaera wothout memory card, now press menu button and go to setup menu and under setup menu please look for format then press Ok, under format please for mat the internal memory.
Now if you already reformat the internal memory, take atleast 3 pictures on a same subject., then hit review if the lines appeared on both pictures on same location, it means camera needs of service please call Kodak toll free 1 800 235 6325., For U.S and canada support. Gudluck!
Nov 03, 2009 | Kodak EasyShare Z612 Digital Camera
My Canon Powershot SD950 IS only allows me to take 8 photos at a time before it tells me that the memory is full. It is the original memory card it came with (32 mb) and it has done this since I first got...
There is nothing wrong with your camera. When you set the resolution to Large and compression to Fine, each picture needs about 3M space. So for a 32M SD card, you can take about 9 pictures. To take more pictures, you can set to low resolution and high compression which means that you’ll lost the picture quality; or use bigger size memory card. I would like to suggest you to buy a bigger card to keep the picture quality.
A chat on page 219 of user manual shows the estimated capacities of memory cards.
Jun 06, 2009 | Canon PowerShot SD950 IS Digital Camera
My hp photosmart M547 will not give me the 2000 pictures it can hold. It says that the memory is full after 10 pictures.
hi there
if it only holds 10 pics it is probably working off the 16meg internal memory and not your card which if it is a 6 gig will hold about 2000 medium res pics
hope this helps
beergut707
Oct 20, 2008 | Cameras
After taking 20 photos says memory card is full
You did not mention the make or model of the camera. Your symptoms seem to indicate you are using internal memory rather than the card. Card typically hold from 200-2,000 high quality photos (depending on the size of the card and the camera).
Another possibility is that you have a high end camera and are shooting in the RAW format. RAW is only for the more experienced users who post process their work. If this is the case switch to JPG.
Note reducing the picture size only makes the pictures lower quality and is only useful if you only post them on the web.
Jun 19, 2008 | Cameras
Internal memory
Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card SHQ 2288 x 1712 4 images 5 images 178 images HQ 2288 x 1712 14 images 16 images 523 images SQ1 1600 x 1200 27 images 32 images 1030 images SQ2 640 x 480 144 images 165 images 5324 images Storable movie length and resolution (approximate figures). The number of movies saved is based upon the storage capacity of the xD-Picture Card and length of each movie. Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 30 fps movie 20 sec. max movie 24 sec. max movie 12 min. 54 sec. movie SQ 320 x 240 15 fps movie 41 sec. max movie 48 sec. max movie 25 min. 48 sec. movie
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
HP Photosmart D7160 InkJet Printer Logo
41 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
