Question about Pioneer GM-6300F Car Audio Amplifier
Pioneer 6300 F
I hooked up a sony sub and 2 6x9's to a Pioneer 6300F amp, it ran fine for a short while then stopped and the fuses burnt out. I realised the grounding cable was not connecting correctly. I replaced this and the fuses and the amp now turns on and stays on, however the speakers and sub do not have any sound. The 6x9s have a slight pulse coming through every few seconds, but that it.
Any ideas?
Ive checked all cables and wiring and it is all ok.
    Problem Solver:
  • 6 Answers
Still having problems? Let's try ruling out the RCA connections as a problem:
The amplifier (Pioneer 6300F) to head unit RCA connection may have been damaged as a result of the bad grounding of the amplifier. ie; If the amplifier cannot obtain a ground connection for its voltage rail through chassis grounding or negative votage connection point, the RCA negative signal path (outer connetion shield on RCA point) will become the only grounding point.
Normally the head unit has an internal fuse (about the size of a grain of rice) which blows at this point, requiring an internal repair. You can "temporarily" repair this by connecting a wire from the outer RCA (neg) connection to the head unit chassis, however if the same grounding problem occurs at a later stage, the connecting wire will become a "fire wire"!!!!... So it's not recommended to do this for anything other than fault finding.
In some instances the RCA cable itself will be damaged, resulting in the positive, or negative wire becoming an "open" circuit. If the inner wire (pos) becomes broken (open circuit) you will have no signal presented to the amplifier (no sound) . If you have an outer RCA wire (neg) broken, not only will you have "no sound" but you will also have an annoying "pop" which will occur every couple of seconds due to the negative preamp signal (inside your amplifier) eventually finding a ground internally. This can pop circuit breakers and fuses, as it is a rapid full blast of signal voltage being induced into the amplifiers preamp audio circuit.
Lastly, if your amplifier RCA input connection has a weak or broken (dry) solder joint internal of the amplifier it will present the same symptoms as an unserviceable RCA lead.
If you want to see if this is the problem, you can do a couple of tests which will tell you whether you have this symptom occurring:
1: connect the head unit to the amplifier using the "speaker inputs". (use the speaker outs on the h.u. for this, and disconnect the RCAs). If the system now works correctly, then continue fault finding the RCA circuit. If the same problem still occurs then the RCA connection is NOT the problem, and your amplifier has a problem with its preamp circuit.
2: If step 1 "passed", replace the RCA connection (and remove the h.u. speaker signal inputs to the amp) with a different RCA lead. If the problem is not apparrent then you've fixed it!! If the problem is still occuring then continue onto step 3
3. temporarily connect a thin wire from the metal chassis of the h.u. to the outer of the h.u. (head unit) rca connector. A simple wrapping of wire around the metal outer connection to the chassis should suffice for testing. (be ready to turn the system off if the temporary wire becomes slightly hot). Test the system and see if the problem has gone away.... If the problem has been resolved, then you will have to replace the h.u. internal RCA ground fuse (which requires soldering). If the problem is still there then continue to step 4
4 temporarily connect a thin wire from the RCA outer connection on the amplifier to the amplifier chassis and see if this fixes the problem. If the problem is now resolved, the amplifier needs to be replaced, or the preamp circuit needs repair. It could be as simple as resoldering the RCA connection inside the amp, or as complex as replacing a transistor... One thing to consider is that this fault finding technique cannot be used on "balanced line" RCA inputs... The 6300F uses "unbalanced" inputs so you should be o.k.
5... If you have done all of the above, then the problem isn't the RCA connection, so at least you have ruled that one out....
Posted on Oct 30, 2008
    Sergeant:
    Champion:
  • 341 Answers
Firstly, you might want to check if the resistance of your speakers (out-of-circuit) are in specs using an ohmmeter. If it's rated 4-ohms then it should be reading near 4-ohms resistance otherwise it is damaged.
secondly, if the amps can be powered 'on' make sure that it has no dc voltage in the outputs. If there is a signal source an AC voltage will dance the meter pointer which indicates that your amp is OK. Only then can you reconnect your speakers (not the damaged speakers duh!).
cheers!
Posted on Oct 17, 2008
Why does my spa 500 amp blow a fuse every time I hook up my 15" lanzar sub to it
Because it's drawing more power than the fuse can handle get a fuse with a higher rating. A 100 app fuse worked great for main power with my setup 760w amp a 15"sub 2 10"subs and a 12" sub. Also my amp had 2 30amp fuses on it one for each channel but I ran everything out of one channel.
Aug 02, 2016 | Lanzar Car Audio & Video
I have an ma audio hk2000d. A couple years ago I hooked it up to a set of subs an it played just fine underpowered then it popped a fuse on the amp. Now every time I Start playing music the fuse pops. I...
Have you tried different speakers? If a speaker has a short, it will draw too much current from the amp and pop the fuse. Also, does the amp pop a fuse on idle, or just under load. What is the gain set for?
Nov 04, 2013 | Car Audio & Video
Pyle PLA885 amplifier blows 25amp fuse. Ideas?
signs of a short, did any wires touch while you where hooking or un hooking the amp? if not then the internal power supply probably has a short in it and needs to be repaired. you can swap the fuse for a good one and hook it back up and make sure you don't touch any wires and if it blows it again then your issues is internal and will need repair if it doesn't and everything seems fine then wires could have touched or the amp was ran past it's limit and blew the fuse to protect it self. good luck and ask any more question you have
Sep 24, 2009 | Pyle PLA885 Car Audio Amplifier
Pioneer car audio amp GM 6300F (new)
Does your amplifier have a Channel swith which says 2/3/4 channel mode. If so and you are running the amplifier in Bridged mode, try changing the setting to 2 channel or Bridged mode.
Aug 20, 2009 | Pioneer GM-6300F Car Audio Amplifier
Car subwoofer problems
The cable should not cause the problem unless it is shorting out somewhere on the remote or positive cable. I would use a larger gauge wire first as this is the cheaper way to go, and if the same problem occurs you are having a short in the sub or box causing the protection mode. You will have to back trace to find possible cross connections.
Jun 21, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Blown amp possibly?
i have the same amp with the same problem.....your best bet is to do what i did get a better amp(audio pipe,spx,kicker,punch,etc) do not get pioneer amp or sony anything
Jun 20, 2009 | Kenwood KAC-X501F Car Audio Amplifier
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Hooking up a new 8" woofer speaker to my amplifier
If I'm reading the amp manual right, you should be able to connect the amp in 3 channel mode. To do this:
  • Connect both left door speakers in parallel to Ch A Left.
  • Connect both right door speakers in parallel to Ch A Right.
  • Bridge Ch B and connect it to the new 8" sub.
  • Set the Ch A LPF/HPF to HPF.
  • Set the Ch B LPF/HPF to LPF.
This should allow you to run all 4 door speakers and the sub from the amp. It will also automatically route non-bass to the door speakers and "only bass" to the sub.
Mar 22, 2008 | Pioneer GM-6300F Car Audio Amplifier
Protection light keeps coming on
Check the wiring between the sub and the amplifier. That's seems to be the only thing left that could cause a problem. If it's shorted to ground or pinched so the conductors are shorted together, it could cause the symptoms you listed.
Oct 01, 2007 | Sony XM-2002GTR Car Audio Amplifier
Pioneer GM-6300F Car Audio Amplifier Logo
337 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
