Question about Nokia 3230
After formatting my 3230
After i re formatted my phone after it was saying ~phone start up failed contact retailer~ it did dtart back up wich was excellent thank heaps for the advice i was stoked!!
the only prob i have now after i reset the clock and date it asked me for memory card code? i never had i memory lock code on before now i cant acees or put any images or nothing to the memory card< i have heaps of vids and pics i want bak out of it??? is this normal after formatting phone??? someone plz help me!!!
  • frosty-75 Oct 21, 2008
    i had tried these, but in the end it was a password already set on the memory card from the existing owner, after formating my phone it then asked for this password was able to retreive it from the old owner, thanks heaps anyway.
  • 25 Answers
I asumme you have a Nokia Phone. Maybe changing: Configs > Phone > Security block
Or even try the generic code "1234" (without cuotes) or "12345"
Regards,
Posted on Oct 15, 2008
I'm not able to view any application on 3230 its giving msg software failed contact retailer Tel me how to reinstall nokia 3230 software without switching d mobile on.
Just format the phone by pressing * + 3 + greenbutton and power on the phone but remember the three button should not leave even if the phone has power on.
Jul 19, 2010 | Nokia 3230 Cellular Phone
My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the retailer." can...
My nokia 3230 failed to start up.... Answer Failed: retry My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which... (More) (More) My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the retailer." can you offer me solutions for this?
Apr 17, 2010 | Nokia 3230
Help please! My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the...
Try this, it might work for you. First remove any extra memory card and sim card inside your phone. After doing that, turn on your phone without those things. If there is message "Please insert sim card" then your good to go. Put your sim card back to your phone and then turn it on again. If it is successfully start then next thing to do is to insert the memory card back to your phone and then start up your phone again. But if in this stage your phone failed to start, then the memory card it causing the problem.
If all fails, then you need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be okay.
Please leave comments for further instructions. Thanks..
Mar 29, 2010 | Nokia 3230 Cellular Phone
I need solution for start up failed contact retailer
type code *#7780# on the display screen message appear restart your phone original settings then ask for code default code is 12345 .your phone restarted and all data on your phone erase
second method first of ur cell phone then press on button answer key or red button then 3 then * press these buttons at once for few seconds and then leave it and ur phone start formatting
Feb 23, 2009 | Nokia 3230
Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Aug 28, 2008 | Nokia 7610
3230 start up failed
u need to format it manually by pressing power on, call options, 3 & * simultainously tested and proven!
May 06, 2008 | Nokia 3230 Cellular Phone
Nokia 3230 format
1) when i switch on my phone it always tells me "phone start-up failed, please contact your retailer"..
2) how do you reprogram the nokia 3230 phone?
May 01, 2008 | Nokia 3230
Hi, Format the Mobile set, using 4 Keys combination : Press(1) *, (2)Dial Key, (3) 3 & hold it & press (4) power on switch.] bye sr99mobiles@yahoo.co.in
Sep 11, 2007 | Nokia 3230 Cellular Phone
Problem is""phone star-up failed. contact the retailer"
The best solution for this problem is to format the phone memory. U may think format will erase all applications but it is false . The essential softwares like mp3 player, camera, etc. are not erased.
The process for format of phone is :
1) turn off the mobile.
2) press and hold ( green dial button + 3 keypad + * ) and turn on the phone holding these 3 buttons(dial button + 3 + *) until formatting screen appears.
3) When formatting screen appears, just leave the keys. and ur phone is formatted now.
4) When finished, it asks for restart of phone.
5) Restart ur phone, and ur phone is ready.
Sep 09, 2007 | Nokia 3230
How can i format my nokia3230
Just to make the suggestion a bit clearer, 1. switch phone off, probably take out the battery if the power button doesn't work. 2. hold down call (green), 3 and * all at the same time. best with right hand. 3. turn phone on. with left hand. 4. wait a bit and phone will come up with formatting. does take a bit, so be patient.
Apr 13, 2007 | Nokia 3230
Nokia 3230 Logo
77 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
