Question about BenQ FP731 17" LCD Monitor
Half my laptop lcd has gone out
Either it had three verital stipes running top to bottom on the left side
or it is solid dark blue from left side
or solid black and flickers right side
exactlyg 50% of the screen
I pluged in a 17 lcd into the laptop and it works fine
is it the lcd in the laptop or something else like the inverter?
thanks
  • 489 Answers
Hi
The inverter board regulates the power to the LCD backlight, it doesn't affect the display, just the light.
From my experience I would say that either your LCD cable is damaged or maybe partially unplugged, or the LCD itself is damaged.
The first step would be to unplug the LCD ribbon cable and then plug it back in making sure that it is properly aligned and well seated. Does the LCD now work? If not, try getting another cable off... you know, that auction website (I don't give them free ads) and see if that works.
If it's not the cable then you can be pretty sure that it's the LCD as you have already said that it works on an external monitor so it's not the video card.
Hope this helps.
Thomas
Posted on Oct 13, 2008
Cause of dark spot on 1/4 of & vertical streaked shadows on the rest of screen?
Sounds like panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2015 | Televison & Video
Phillips flat screen has a vertical blue line, about 2inches wide, running from from the top to about a third down the 52 inch screen. What causes this
Take ur hand and pushes all around the tv frame bazel see if the veritical blue line react like flashes or lighter or darker,than this tv can not be repair at all because the LCD screen itself it is the caused,the LCD screen cost same as a new tv if it is require to be replace.If there are no reaction of the blue line at all than ur tv have a circuit board problem.The T-CON board is dying,this board sit in the middle bottom of the LCD screen,must be replaced will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-Con board for the replacement.
Aug 04, 2013 | Vizio Gallevia GV42LF 42 in. LCD...
I turned on my tv and it has solid black grey and colored lines on left half of screen.
It sound that the T'Con board has damaged. Your TV need a thorough check up. Contact any expereinced service technician.
Jul 13, 2012 | Insignia 42" LCD Flat-Panel HDTV
The auto print head alignment prints ok. The Nozzle check from top to bottom prints as follows: 3eBK ok; 6C top half light blue - bottom half darker blue; 6C ok; 6M top half light pink - bottom half darker...
It sounds like your black (K) or Black/Yellow (KY) head needs to be replaced.
The problem appears to be in the top half of the black head.
Without knowing more (like what make/model the printer is) I can't help more than that.
Mar 09, 2011 | Office Equipment & Supplies
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
Nozzle check wrong, but no clogged printhead
on an i960 canon the magenta does not come through/thank you,Leo
Feb 17, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
BenQ FP731 17" LCD Monitor Logo
137 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
