Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
My maxtor 200GB drive is not recognized by my CPU anymore!
I have had this drive for a couple of years now and I have had no problems with it. Now my CPU will not recognize the drive. I have switched USB ports I cannot see anything in the admin tools icon under CPU management. please help me out there is years of family photos on this external drive!
  • crkinard101 Oct 14, 2008
    After I took the harddrive to a friends house. We discovered that the housing for the harddrive was shot and needed to be replaced. after we took the actual hard drive out and replaced the housing it worked fine. hope this helps others.
  • grandepapi1 Oct 25, 2008
    i have the same problem, it just stopped working. I have tried connecting it to another computer but it is not working.
Hey, a question to the OP,
did your hard drive make any strange or unusual noises or sounds when it wasnt working?
Mine is also not recognised but it makes strange noises that it didnt make before, im really hoping this isnt a head crash
Posted on Jul 13, 2009
I have had 2 Maxtor 3200's for a couple of years, and this seemed to happen periodically. After enough fiddling around and plugging and unplugging I've always managed to get both my PC's to recognize them eventually.
I have now started doing the opposite of what is recommended, namely, powering up the drive and then making the USB connection. Now I make the USB connection and then plug in the drive. This has worked reliably for at least 10 times.
Posted on Nov 05, 2008
Remove the hard drive from the casing and connect directly as a slave drive to your PC. If it is not recognized then the problem lies with the hard drive. Use Seagate's "seatools" to check the hard drive.
If the hard disk is recognized then the problem lies with the USB convertor circuit of the maxtor box or it could be a power supply problem aswell.
If you have upgraded windows xp to SP3 the drive may sometime go unrecognized. To solve this,
by default the jumper setting of the hard disk is set to cable select by maxtor. Reset the jumper as master drive and put the hard disk back in the casing and connect through the USB port. It should work now.
Good Luck
Posted on Oct 29, 2008
  • 23 Answers
Hi Crkinard.. i think you shuld first find out whether the problem is with the external device or your computer... so check if the device is recognised by another system... as you have been using the device dor couple of years i think yours computer's drive for external devices should have been corupted.. so check out the device with some other computer.. if it is recognised in that computert then you can easily reinstalled the software for your device again..
Posted on Oct 13, 2008
I have an external hardware maxtor 200GB, previously for mac., how to use it for PC?
FORMAT AND CONNECT TO PC IF NOT RECOGNIZED MAY BE BAD HARD DRIVE . OR NOT COMPATIBLE
Nov 23, 2010 | Maxtor OneTouch II external hard drive...
Tip
Utilizing all 200Gb of my Maxtor 200GB HD
My name is Robert Bostick Sr.
I installed the above listed (200GB) Maxtor hard drive without any problems. However, this is where I discovered that all HD's will only recognize approximatly. 135GB.and that an Adapter PCI PC board would have to be installed to be able to recognize all 200GB. The remainder is not lost, but is installed like a second hard drive, but can only be used as a over flow space or for my music or photos. So, its not entirely bad. However, I want all 200. I have a new WD 80GB I could use for either my music or photos.
I read somewhere that I need a PCI Adapter for the computer to recognize all of the 200GBs. This is what I purchased on line. I purchased a "Rosewill" ATA-133 2-port Adapter with RAID.Part Number RC-200. Will this adapter solve my problem. Looking through all of your people questions Ion your Web Site I''m surprised I did not see a question like this. I guess I'm the only stupid old man out there.
If possible could someone give me a hand with this inherent situation. Also, will the Adapter PCI board I purchased work for this HD,
thanks so much for your time,
Best Regards,
Robert W. Bostick Sr.
bostickr@bellsouth.net
on Mar 13, 2008 | Maxtor DiamondMax 10 200 GB Hard Drive
Maxtor 3100 200GB hard drive clicks rythmically but not recognized by computer and cannot be accessed. About 3 -4 years old
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 27, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Need to locate a working identical Maxtor 3200 200GB
Well this is not how I like to answer questions on this forum, but here is a place to start looking for your drive. I hope this helps, there are some listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=+Maxtor+3200&_sacat=See-All-Categories
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor One Touch III 200GB Drive stopped spinning. Light is on. OS doesn't recognize it (Win 2000 Pro).
first you ensure that it is detected or not in BIOS. if it is not detected then cable may be faulty otherwise HDD is faulty.
Aug 21, 2009 | Computers & Internet
Maxtor blocks computer from processing - locks up
disable maxtor before shutting down the PC to narrow down the problem.
Jul 05, 2009 | Computers & Internet
My maxtor 750GB external drive is not recognized by my CPU anymore!
It's probably either WinXP and a hub fighting over drive IDs, special drivers you installed but haven't been upgrading, or the thing isn't powered up properly.  Go to.  Oh, and your CPU (Intel, ARM, AMD, whatever) never recognizes hard drives; it's up to the OS.  What OS?  That's how you present a problem properly, in the right category.
Nov 16, 2008 | Computers & Internet
Old Maxtor/New Maxtor
If files you are trying to restore are encrypted you will have to use same software to retrieve them.. If not, any file in the external hard drive should be viewable with your windows explorer.
And U do not need drivers for external hard drives. They just plug into your usb port and work with modern OS after the unit is recognized.
Apr 15, 2017 | Maxtor OneTouch II external hard drive...
Not recognizing password
hi, im sure i can help, what software did you to put the password on, like was it just normal windows xp or was it a unique software that came with the external drive.
Let me know
Happy New Year
John
Dec 24, 2007 | Maxtor OneTouch II external hard drive...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
865 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
