Question about Microsoft Windows XP Professional for PC
Will not boot to XP
I have a compact presaroi and now when it starts the compact logo appears and in the left corner theres two memory errors.then sometimes it says starting win98,,,down from that,xtended memory manger not present,,xms not installed,,,no high memory,,bla bla thnks David.
    Sergeant:
  • 213 Answers
These are some following procedure
do it carefully
XP Repair install Please read carefully and make sure you followed the warning links before initiating the Repair Install. You can print a text version for reference. repair.txt
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. Will not boot to XP - note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" width="15" height="21" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. If you get files not found during the copying stage.
    Blaster worm warning: Do not immediately activate over the internet when asked, enable the XP firewall before connecting to the internet. You can activate after the firewall is enabled. Control Panel - Network Connections. Right click the connection you use, Properties and there is a check box on the Advanced page.
    KB 833330u Blaster removal
    What You Should Know About the Sasser Worm and Its Variants
    Microsoft Security Bulletin MS04-011
  7. Reapply updates or service packs applied since initial Windows XP installation. Please note that a Repair Install using an Original pre service pack 1 or 2 XP CD used as the install media will remove SP1/SP2 respectively and service packs plus updates issued after the service packs will need to be reapplied.
Posted on Oct 13, 2008
Problems to obtain a complete system boot at first try.
See if you can boot to safe mode. Run check disk on the hard drive. Make sure the BIOS battery is ok.
Oct 29, 2017 | Dell Computers & Internet
Acer is going straight to a black screen after the acer logo in startup....it just shows a tiny blinking line. It goes no farther. I need help fast
Apparently your Acer cannot find the operating system. As soon as the Acer logo comes up, there should appear in one of the bottom corners "F" & a number should appear. Immediately start pressing that F number (top row of keyboard). This should take you to a boot screen. Scroll down to boot sequence. Hit enter. Make sure boot-up sequence is CD or floppy drive first, second should be HDD, then escape. Restart computer. Should then boot off CD drive. I am assuming you have an operating system (XP, windows, etc.). Let me know if this doesn't work.
Apr 07, 2013 | Acer Aspire 5734Z4386 Notebook
Start the pc after boot massage microsoft xp serious error please contact microsoft xp.
Did you try to boot in safe mode? if not, boot your PC, and press f8 after the logo of your unit appears but before the windows xp bootscreen..then comment you can boot
Apr 27, 2011 | Computers & Internet
I have an HP dv6700 that won't boot windows. It's running vista 32 bit with Phoenix bios on there. I have tried a recovery disk but there seem to be no startup errors nor did it find memory nor hard drive...
BIOS diags do not test RAM's Windows functionality. Download Microsoft's Memory diagnostic too and burn to a cd. then test your memory.
To run Windows Memory Diagnostic, you must reboot your computer with the disk or CD-ROM on which you installed Windows Memory Diagnostic in the drive. After the reboot, Windows Memory Diagnostic will load and its interface will appear. After loading, the first test pass will begin, using the default standard test suite, and continue until complete, unless Windows Memory Diagnostic is either paused or exited. Once the first test pass is complete, Windows Memory Diagnostic will begin a second test pass using the same settings as before. Windows Memory Diagnostic will continue to run test passes until you exit.
http://oca.microsoft.com/en/windiag.asp
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 21, 2011 | HP Pavilion DV6700T Notebook
I upgraded my laptop's (hp compact cq40-336 tu) RAM from 1 GB to 3BG. I bought a 2GB RAM w/ Kinsengton model from our local store. TO find out the said RAM is not working properly. How can I fix this...
This model laptop requires DDR RAM. Sometimes different brand of RAM do not work together or not the memory upgrade was not compatible with the laptop.
To check the amount of installed memory, go into the BIOS configuration to view the RAM.
The other way is to open Control Panel and click on System, this will also show the total RAM installed.
Oct 17, 2009 | Compaq Computers & Internet
Startup logo appears then it goes to a black screen and blinks
You should try booting into safe mode. Press the F8 key before the windows logo and choose safe mode without network support. If windows loads run a checkdisk by right clicking on the c drive, left click on properties and then select the tools tab. From there you can run a disk test to check for errors. If you get that far then reboot and see if it starts normally. If not try F8 again and try selecting restore the last known working condition. This will restore your settings from the last time it worked. If you can’t get to the F8 screen get back with me and I will try a few more drastic solutions. Good Luck
Jul 22, 2009 | Computers & Internet
My computer cannot boot up
The boot partion is damaged,You will either need to get the install disk and run the recovery or get a tool disk with fixboot,scandisk,etc...Or if you can tap F8 while rebooting and start in safe with command prompt,You can try a few things,
  1. SFC/scannow
  2. fixboot c:
  3. Chkdsk
  4. fixmbr
#1 is the system file check
#2 is for fixing the boot partion
#3 Checks the hard disk
#4 Fixes the Master boot record
Please take time to rate this fixya
May 13, 2009 | HP Pavilion A610n (PC106A#ABA) PC Desktop
My acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
Mar 02, 2009 | Acer Aspire 4315 Notebook
Reboots at different times, some times windows logo is grayed out and hangs
its is possible that you have some bad memory search & download a program called memcheck 1.70 or later, and either put it on a formated floppy or burn onto a cd ,make sure that the boot sequence in the bios is set to go to that drive first
the pc will boot into this program and will keep running untill you stop it,if their are any errors it will show up ,you will need to establish what memory chip it is, if you have more than one chip.
it could also be a power supply, supplying iregular voltage.
also xp requires at LEAST 256 mbs to run badly, more is better.so if you are using less than 256 mbs it will be the problem.
good luch
Terry
Mar 10, 2008 | ASUS P5P800-MX Motherboard
MY IBM WILL NOT BOOT
bro just one good thing you should do... if you got no important files in the hard disk just clean format the drive and reinstall a good tested OS probably windows xp pro... make sure you low level format your drive before installing the OS... also you may try updating your BIOS.
rank me if this help ok...
Jan 19, 2008 | IBM NetVista PC Desktop
Microsoft Windows XP Professional for PC Logo
101 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
