Question about Intel Desktop Board D845WN Motherboard
Desktop won't start.
I have a desktop with Intel M/B type D845 WN and an AOpen power supply type ATX-250GT (P4). Problem is no start when front panel on/off switch operated. Fan in power supply not operating.
I have checked mains supply at 240V -OK, operation of on/off switch at M/B connector -OK, temporary short on M/B on/off pins - no start.
Removed all connection from power supply to M/B and etc., temporary link from pins 14 to 15 on 20 pin socket. Very brief mains on - fan starts and all power supply voltages present (measured with DVM and close to nominal value)
Reconnected only the 20 pin connector to M/B - fan starts without operation of on/off switch 5V and 12V measured at drive socket at nominal. If 4 pin (12) socket now also connected to M/B no fan - no voltages.
Have also tried operation with video card removed - no go!
These tests I have got from various web sites but now I am out of ideas and would appreciate help.
Thanks
  • 39 Answers
Try to replace the power supply with another known working power supply from another P4 desktop and then reconnect your wires from the front panel led lights, changing them around until they are in the correct position. I had an almost similar problem and I did the above, it is working now. All the best ! sirjohn
Posted on Nov 01, 2009
Power on issues
check this out https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+6+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DH61WW front panel download manual
Feb 09, 2013 | Intel Desktop Board DH61WW Classic Series...
No power coming on intel desktop motherboard d845
Check the power supply to the motherboard i.e the SMPS, if it is working the fan of the SMPS will rotate. If the SMPS is ATX you can check it without connecting it to the motherboard. Unplug all the SMPS power connectors from the motherboard and then short circuit the green and the black wire of the 20pin connector of the smps, if the SMPS is working the fan of the SMPS will rotate. If the SMPS is in good condition and working, than it might be a problem in the internal circuit of the motherboard.
Check the process here:-
http://www.jestineyong.com/?p=267
Jul 19, 2010 | Intel D845GVSR Motherboard
Put in new power supply. not sure of wiring diagram. now monitor says no input signal. what should it look like? did i miss something?
If my sources are correct, (Haven't worked on one in my shop yet), the eMachines T5212 desktop computer uses an Intel D101GGC2 motherboard.
The Intel D101GGC motherboard is Very similar,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
Motherboard Manual - left-click on English Product Guide [PDF], in blue.
Give a few seconds for the first page to come up, (Took 6 seconds for me), and for the PDF file to fully download, before looking through it. (Took 24 seconds for me)
1) Did you make sure the 24 -pin ATX main power cable, is plugged in tight?
Lock on the side is snapped in place?
Page 42.
Closer look at a 24-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Did you plug in the 4-pin ATX +12 Volt power cable?
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Page 42
That's power for the Intel Pentium D model 805 processor.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5212
Are the cables (Wires) from the Front Panel of the computer, plugged in correctly into the Front Panel header on the motherboard?
Page 37
Are you sure the DDR2 Sdram ram memory module/s (Stick/s) are plugged in tight?
The best method is to remove it, or them, and reinstall.
This way you are assured.
Most of the time a ram memory module, or more than one, will be bumped loose when installing a Power Supply.
Jun 22, 2010 | E-Machines T5212 PC Desktop
Hp pavilion a430n power supply is blinking
Look at this photo
(http://www.atxpowersupplies.com/images/300-watt-atx-power-supply-FSP-ATX-300GU-350w.gif)
Did you connect the p4 atx 12vx1 plug?
You may also need to connect the aux x1 plug on some models.
Mar 08, 2010 | HP Pavilion a430n PC Desktop
Power supply packed i n
Yes, you can safely put in equal or higher. Just make sure it is an ATX and that it is P4 compatible. Most new ones all meet to those specs. Higher is actually better. I would go with a 400w or higher.
Apr 07, 2009 | Intel Allied 450W Dual Fan Pentium 4 ATX...
I want intel desktop D845 EPI/ D845 GVSR DISPLAY DRIVERS
Greetings!
I cannot find the exact brand of your display driver, here's a link which I think give you an idea of what display driver you need, and download that driver.
http://nodevice.com/driver/category/Video_Card.html
Thanks.
Nov 05, 2008 | Computers & Internet
Front panel ceonnctor
Intel® Desktop Boards meet the ATX motherboard design guide specification using a 9-pin front chassis header. Special attention is required when attaching the front panel connector from the chassis to the Intel desktop board.
Front Panel Header
Description Pins Hard Drive LED 1 - 3 Power LED 2 - 4 Reset 5 - 7 Power ON (Power Switch) 6 - 8Lou
Aug 25, 2008 | Intel D845GVSR Motherboard
Front audio.
first you turn off system then do this .If it is not work then change 5=spk1
6=spk2
9=mic1
10=mic2
2f8a93f.jpghope this work if it not work then i am here
Mar 14, 2008 | Intel Desktop Board D845WN Motherboard
Intel Desktop Board D845WN Motherboard Logo
174 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
