A faint thin, line across my toshiba 32 inch. It was built in 1989, but I don't have idea what model it is. I replaced a few caps around the verticle IC, and the IC itself. I still get the same thing, any suggestions?
  • 4 more comments
  • oneholycow Oct 13, 2008
    No. It all began when it just shutdown. The screen would go completely black. We would turn it off, and in a couple of hours, we turn it back on and it was up and running again. We kept on using it, until I had time to look more into it. I found a video cable that came off from the jack. I replace this cable, and I thought it was fine. But, a then started to hear this pop, and the screen would go off again. We would turn it off again, and it would come on again for few hours when it would go off (screen black). A couple of days later, I turned it on again, and I would only see the thin line across on the middle of my screen. I check a couple of sites on the web, and said that it was my vertical IC and some caps around it, but I did that, nothing. It still the same. Is there something that I can do with the CRT?
    At the moment, I see a suspicious cap near the flyback transformer. I just noticed that it has a black chalky substance on the side. I'll replace this next. I have checked several resistors around the area, and they seem check okay. The fuses look good, at the moment I'm thinking of replacing the cap and see what happens. Do you guys think that would have cause the problem in the first place?
    The thin, line appears across the screen when I turn on the t.v. and it's about 1/8 of inch thick. I'm not familar with the convergence chip. Do you guys know what part number it would have or where it would be located?
    I'm sorry I can provide an exact model number cause the labels that were on the back of the set have fallen off. I just remember that it was built in 1989 because I check it the label once, and that's when I graduated from high school...
    I just noticed a number on the inside of the t.v. case. It's CF3254H, the letter "H" is pretty faint, but that's what I think it could be. Does that help for model number?
  • jason May 11, 2010
    whoops , if the line is from top to bottom vertical is ok if from left to right then vertical is not
    have you checked the fuses by the trans former that supply voltage to the convergence chip?
    also could you look to see what model it is?
    if the vertical line goes all the way across then its not the vertical deflection IC .
    have you first checked for any indications of a burnt component, resistors by convergence chip, flyback transformer voltages?
    have you looked at the CRT its self?
  • 905 Answers
The conversion chip is powered by seperate power from the transfomer + -- volts
here is I believe what your conversion chip # is stk392-110t and here is the NTE specs.
http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
you can use the specs. to check voltage pins, ect.. ,if that is the numbers.
to see if the chip is faulty then check resistors, caps , and voltage to the chip , a pr or fuse may have blown for the - and + voltage to the chip. if it is bad it would be wise to replace the vertical deflection chip as well ( hopefully yours is still ok) , because of the vertical control in the conversion chip.
you can also check for the power on the wires from the CRT board that comes from the flyback transformer ( NOT the HIGH VOLTAGE wire ).
also after you have unplugged the tv and dicharged the flyback to the chassi ground you should check the components on the crt ( cathode ray tube ) board for any bad measurements of the components.
Posted on Oct 14, 2008
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
Panasonic 27 inch TV Model CT-2701G built 9/2003
Hi-
Try removing and reinstalling the cables from the back of your TV.
Keep us posted, thanks for using Fixya!
Jul 14, 2008 | Televison & Video
Toshiba, 36A50 picture is a thin white line. Can this be repaired?
Yes...this TV may be repaired. The line you describe is in the center and is horizontal across the TV. You will need to resolder the vertical IC pins. This vertical IC is mounted on a large heatsink. Under the board you will see there are 5 or 7 pins that will have rings around them. Resolder these. And you should replace two or three capacitors that are next to this IC. A bad cap will overheat an IC and separate the solder grounds. If you can find my expertise page on this website, you will see the repair in more detail. Thanks for asking and show a few hands of support.
Dec 12, 2010 | Toshiba 36A50 36" TV
I have white horizontal lines about 2 inches at top of my tv
You have some bad grounds on the Vertical IC. In addition to this, in the immediate area of this Vertical IC, are a few bad capacitors. Look for this IC mounted on a large heatsink. It may have seven pins . I cannot remember for sure. I have not worked on this particular TV, so I cannot give you specific locations. But I assure the problem is in this area! If you have some electrical experience you can pull this board out. In this case only the caps need replaced and the IC resoldered. Good Luck and thank you for asking. If you have anymore questions, visit me...Thanks Again! Your south of the border tech!
Apr 27, 2010 | Toshiba 32A14 TV
Screen is black wiht a single 1/8 thick horizontal line across entire screen. Sound is ok. Other TVs are working.
cold solder in vertical ic and check caps around to..if you see resin around any cap, change.
Apr 22, 2010 | Toshiba CF32H40 32" TV
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Jul 13, 2008 | Toshiba 32A40 32" TV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
