Question about Lexmark Office Equipment & Supplies
Lexmark X4270 won't communicate with computer - Windows 2000; tried disconnecting cables, power cord, then restarting, tried everything, still won't print, scan or copy or fax. HELP!
  • 101 Answers
Did you try re-installing the Lexmark drivers?
Posted on Oct 13, 2008
My lexmark x4270 can't connect message. what do I do?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
Printer say's "please load paper in auto
This could be a printer driver problem. Try to uninstall your existing Lexmark X4270 printer driver from your computer. On your computer, go to Start menu > Programs > Lexmark 4200 Series > Tools > Uninstall. After the process, reboot pc when prompted.
Check if your Windows 7 is running on 32-bit or 64-bit operating system. Go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the links below to re-install the printer driver on your computer: - Lexmark X4270 Driver for Microsoft Windows 7 for 32-bit - Lexmark X4270 Driver for Microsoft Windows 7 x64-bit
Jul 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
Computer wont communicate with printer
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
Disconnect your USB cable from your printer.
Uninstall all Lexmark printer drivers on your PC.
Download the correct Vista driver for your model.
Install the driver on your PC.
Important Notice -
Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
go to Lexmark website using this link: http://support.lexmark.com/perl/support/support.cgi enter your product number (X4270) and you will find your driver for Vista. Good luck.
Mar 30, 2009 | Lexmark X4270 All-in-One Multifunction...
Lexmark X4270 power light won't come on
Disconnected the printer from the computer...waited 30 minutes...reconnected and the power was restored. This was suggested by a tech friend who says that sometimes clears the memory.
Mar 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
No communications computer to printer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jan 21, 2009 | Lexmark X75 MF All-In-One InkJet Printer
Lexmark X4270......All in one....computer recognized it two days ago, but today it isn't doing anything. Can you help me?
The issue which u r facing is" Communication issue"
Make sure u have installed the lexmark printer software...or else download it from the lexmark website(lexmark.com)..choose the s\w for ur operation system( Xp or vista(32bit or 64bit))...
If s\w is installed...
Check the USB cable..try different port...
Clear all the docs in the printer folder...
Remove the power adaptor and replung..restart computer..
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?...If it doesnt..then (Check if USB printing support,USB composite device are present in the Device manager...i.e Right click on "my computer" ikon-go to PROPERTIES-Hardware-Device manager-Click the plus sing near and check in the list )
U can also try...
Uninstalling the s\w....disconnect the USB cable..reinstal the s\w and connect the cable when it prompts to...
Jun 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
LEXMARK 4200 SERIES
Hi anders2......
Check if u have downloaded the correct software from the website...there r tow versions for vista (64bit and 32 bit)...check if ur Vista is 64 or 32 bit and d\w the software.....
If u hvae downloaded correct printer then....
U can also try...
May 30, 2008 | Lexmark X4270 All-In-One InkJet Printer
Computer won't recognize printer
We know it isn't the printer or the USB cable. We know it isn't the software. You are running Windows XP on both the desktop and laptop, correct? On your desktop, you go to 'Start''Settings''Printers' and is the printer there ?? Try this; go to 'Start' 'Settings''Control Panel'. Double click the 'System' icon. Click on tab 'Hardware', click on 'Device Manager'. Do you see a yellow (!) on any Universal Serial Bus Controller. If not, were good. Check all USB ports with a USB mouse or device to make sure they're active.
Jul 03, 2007 | Lexmark X4270 All-In-One InkJet Printer
55 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
