Hd52w59 no sound
I can get eternal sound from a reciever but when i unplug it i cant get any sound from tv .I tried to change it to internal but nothing happens.Email me please at kuggy@charter.net
  • 4 more comments
  • kuggy Oct 13, 2008
    been un plugged for about 3 weeks.And i want the tv speakers to work.
    well i dont ave a remote it broke 6 months after i got the tv.but the speakers worked then.I first had the speakers disabled through a stand alone sony reciever.When i bought a new tv i unplugged it and i couldnt get any sound from tv.Um little bit 4yrs ago i worked for sony tv so i do have a little xp.
  • kuggy Oct 17, 2008
    Sorry it took so long for response but was waiting for a remote for it to be shipped.Ill have to find the board with the speakers plugged into but i think there ia a patition that divides it.Ill try to figure it out.Just called a service company they want 65.00 just to come see it.And more to fix it.lol hell with that.
  • jason May 11, 2010
    If the menu setup is good then its probably the sound amplifier inside the set maybe. Did the speakers just go out or did you have them disable? When did you notice them not working or not working after you disabled them? it could also be the remote switch circut has failed but then I cannot help you fix the problem unless you have electronic experience , do you?
    if you have no sound it could be the speaker or the amplifier , and have you tried to unplug the tv for a little while?
    what are you trying to get to work on your tv?
  • 905 Answers
Ok
the problem is probably the amp inside , but try unplugging the speakers from the board inside, then turn on the tv and tune in a station then plug the speakers in and listen for any conection sound or the tv station sound if nothing at all then the audio amplifier chip will need to be replaced.
if you can solder you will also need to get the numbers from the chip and see if an electronic component supply store has that or can get it
Posted on Oct 14, 2008
My samsung eternity is acting like the internal memory is full but it is not. when i try to take take a picture and save to internal memory i get the message unable to save. when i try to download a file i...
I'm having the same problem. I called ATT and they are going to replace it via the insurance (I thought they only replaced lost phones). I've had it about 1 1/2 years. It says the memory is full but I did a master reset and even deleted some games.
Aug 29, 2010 | Samsung Eternity Cell Phone
Sound went out unplugged it and plugged it back in but still no sound
RCA is notorious for jacks going out.....check connections, unplug, plug back in, turn them, try diff, jacks....look in menu sound settings see if you turnd off tv spkrs or something along these lines
Jun 27, 2010 | RCA HD52W59 HDTV Projection Television
When i power up the reciever and watch tv the reciever turns off and the power button blinks red. I unpluged the reciever for 1 hour and put it back on. nothing changed. i even unpluged the speaker wires...
You have an internal short in your receiver could be power supply or most likely a output transister. There is a code to the blinking red light check your manual it may list the number of blinks with problem. However its not a simple fix. plus make sure HDMI cable is unplugged when reseting receiver if this cable has a short it may cause it to. Sorry to hear the bad news, nice receiver
GOOD LUCK....
May 24, 2010 | Denon AVR-1508 Receiver
Television will not powwer on
Hello al1895,
This model of TV uses the ITC222A chassis. This is a common problem in this unit. The problem is usually centered around 4 capacitors (CP140, CP150, CP110, and CP114) They usually vent (becom bloated or puffy) and develop an internal short which causes the TV to shut down. This is usually caused by power surges (even when connected to a surge protector). The repair for this problem does not cost much, and I would suggest that you have a TV repair technician examine this TV due to the other problems that can happen with this chassis (ITC222A).
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
Hooking a Wii to Dish Network reciever(not a hd tv)
It sounds like you have a pretty new TV. This means that there should be multiple AV jacks in the back for setting up your many components. Plug in the receiver into #1, the Wii into #2, and any other equipment you may have (DVD, VCR etc.) in the same way. You should then use the original TV remote to switch between Video 1, 2, 3 and so one for each compnent you want to use. The button on the remote will be labeled video, tv/video, input select, or input, something like that.
Hope this helps!!
Dec 29, 2008 | RCA HD52W59 HDTV Projection Television
Tv wont come on
first of all you may unplug about 2 hours and try again as symptom shows some internal overheating or power failure going on
Mar 01, 2008 | RCA HD52W59 HDTV Projection Television
No Sound
bring up the menu and activate the skeakers on/off feature ,also look in rear for internal/external switch .
Nov 27, 2007 | Toshiba 55H70 55" Rear Projection...
Video input not recognized for LD and DVD
By coaxial, do you mean the composite (yellow)? Either way you have to use the same style no matter what the cable. I mean, if you have s-video's IN to the reciever then you need S-videos OUT to the TV. ....Component IN to the reciever? then Component OUT to the TV. And so on. You cant have composite cords going into the reciever and use a component cord out to the TV (with the exception of a few models).
Sep 10, 2007 | Pioneer VSX-D912 Receiver
No sound coming from reciever from tv
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Jan 24, 2007 | Yamaha HTR-5440 Receiver
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
