Replaced my hard drive on my hp lap top and i cannot load the restore disk it is hp ze4800 i dont know how to get it load error code pxe e61
  • 39 Answers
HP and Compaq Desktop PCs - Error: PXE-E61: Media Test Failure replaced my hard drive on - s.gif s.gif
This document pertains to HP or Compaq desktop computers with Windows XP. The following error message appears: PXE-E61: Media Test Failure This error is probably occurring because the main bootable hard drive is no longer "connected" to the computer and the next usable bootable device in the boot path is the network card. Use the following steps to resolve the error: NOTE: If the computer was recently moved or bumped, make sure the hard drive cables are firmly attached to the motherboard and the hard drive before using the steps in this document. Step 1: Remove all removable storage devices Remove connected devices, remove power, and restart the computer:
  1. Disconnect any, personal media drives, pocket media drives, USB or 1394 (Firewire) devices that are attached to the computer, especially USB thumb drives.
  2. Remove any CD and DVD discs from their drives.
  3. If the computer has a floppy disk drive, remove any floppy disks from the drive.
  4. Press and hold the Power button for 5 Seconds to turn off the computer.
  5. Disconnect the power cable to the computer.
  6. With the power cable disconnected, press the power button again for five seconds. This may reset the firmware for the hard drive to its defaults .
  7. Plug in the power cable only and turn on the computer.
  8. If the error persists, go to the next step. If the computer starts without the error, one of the removable storage volumes may be preventing the computer from starting or the hard drive was not reponding. Do not leave the removable device in the computer when shutting the computer off. You are done.
Step 2: Make sure a network device is not selected as the first boot device in BIOS The computer may be attempting to boot from the network device.
  1. Turn on the computer by pressing the power button on the PC and press the F1 key repeatedly when the first screen opens.
  2. Use the arrow keys to select the BOOT screen (from the menu at the top of the screen).
  3. Use the arrow keys to select the BOOT Device Priority (or similar).
  4. Press Enter .
  5. Read the instructions on the page to move any reference to a netwrok device to the bottom of the list. You should also move the optical drive (ODD) to the top of the list.
  6. Once the selections have been made, press F10 to Save settings and exit.
Step 3: Test the Hard Drive Test the hard drive using the SMART hard drive test:
  1. Press and hold the Power button for 5 Seconds to turn off the computer.
  2. Press the F1 key repeatedly after the computer is turned on. A BIOS setup utility should appear.
  3. After the BIOS Setup Utility is displayed, use the Down Arrow key to select the hard disk drive name and press Enter .
  4. Select SMART Extended Self-Test , press Enter , and wait for the test to complete.
  5. If the test fails, the hard drive should be replaced. If the test passes, go to the next step to update the BIOS.
Step 4: Update the BIOS Download and install the latest BIOS for your computer . If, after updating the BIOS and restarting the computer, the error goes away, you are done. If the error persists or a BIOS update is unavailable, go to the next step to recover the computer. Step 5: Recover the operating system To reinstall the Windows XP operating system, perform a system recovery (or reinstall Windows if the computer was upgraded to XP). You may need to start the computer from a set of recovery discs (or from a Windows Installation disc if Windows was upgraded to XP). For more information about how to recover the computer, refer to the HP support article Performing a System Recovery in Windows XP . Step 6: Repair the computer If the preceding steps do not resolve the error, the hard drive or BIOS may have failed and the computer should be serviced. if this service info does not work contact me.
Posted on Oct 13, 2008
Error message on dv 1000 pxe-mof and pxe-e61
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 17, 2013 | HP Pavilion dv1000 Notebook
Tip
PXE-E61 ERROR The error PXE-E61: Media test failure usually means the hard disk...
PXE-E61 ERROR
First - re-seat the hard disk and reboot the computer. If this does not work then reboot and go to the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Next - to determine if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device (external hard drive) and you cannot open the various folders and files, this confirms the hard drive is faulty.
The hard drive needs to be replaced in the laptop or desktop computer and Windows installed including the laptop or computer's device drivers plus your programs etc. to get a functioning laptop or desktop computer again.
on Mar 20, 2010 | Computers & Internet
I have a fiujitsu hard drive in my acer aspire 5315 my keyboard has no keys just some rubber tips and when i turn on its says broadcom UNDI PXE-2.1 v10. 0. 9 copyright yada yada and then it says: PXE-E61:...
The keyboard needs replacing. Replacement keyboard for your laptop maybe available from this WEB site.
PXE-E61 ERROR
Dec 18, 2012 | Computers & Internet
Display PXE-E61: Media Failure, Check Cable PXE-MOF: Exiting Intel Boot Agent Will not boot to windows. I boot from the hard drive and still get an error
Sep 25, 2012 | Gateway MX8741 Notebook
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
What is pxe-e61 and pxe-m0f
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Apr 22, 2012 | Dell Computers & Internet
I have a fujitsu mhu2100at, ca06499-b11000c1. my hp laptop quit working and gave this error : PXE-E61: media test failure PXE-M0F: exiting PXE ROM. i removed the hard drive and tried hooking it up to...
The PXE error is not from your harddrive. the computer has failed to reccognise the HDD and so moved to the next bootable option being network, the PXE error is telling you that it cannot boot from network
I would only replace the board on the hard disk with another (same model) if you realy need the data on there. it is possible that the drive is failing because the heads have locked and so replacing the board will not fix, but if you have access to an identical drive its worth a try.
if you dont realy need the data, replace with another compatible drive and reinstall.
Mar 28, 2011 | Fujitsu Computers & Internet
I have a nc6000 and the the message PXE-E61: Media test failure, check cable PXE-M0F: Exiting Intel PXE ROM. comes up I can not boot my computer it states a disk read error occured can you help me. I have...
The PXE-E61 is the error code for No Network Bootable Device Found. Which means the computer cannot find your hard drive and is looking for a network drive to boot from. Either your internal hard drive has failed, or it is not seated or operating properly. Troubleshoot the hard drive, either it is dead or there is an interface problem between the drive and the motherboard or BIOS setting.
Oct 16, 2009 | Computers & Internet
PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Mar 09, 2009 | Acer Aspire 4720 Notebook
Hard drive clicks + error appears on screen when turned on
I would check to make sure the hard drive is in secure and if it is I hate to say it sounds like your hard drive needs replaced.
Aug 04, 2008 | Toshiba A75-S125 Satellite Notebook
Computers & Internet Logo
369 people viewed this question
David Payne
David Payne
