I want to make my laptop faster, how can i make it faster?
  • compgeek09 May 11, 2010
    What kind of laptop is it? The model and number? Also, how much memory do you currently have in it?
I am not given you a proper chart of that methods who can be make so faster your computer.
I am given you one method to make more then faster your computer by present posiition.
METHOD IS:
Go to start menu & Go to Run command & Type (msconfig)press Enter.
a window has appear you see many tabs on uper bar you click on (start up) tab.
you look many component in it. you just click on (Disable all) & press OK & restart your
computer after restarting you see your computer is much beter by previos position.
GOOD LUCK!
Posted on Oct 13, 2008
How can I make Panasonic cf-18 laptop faster
Easiest way to make your laptop faster is to turn off all of the programs that are starting from a cold bootup. Clean out the registry of unnecessary items and defrag it as well. And to further speed up your browsing add an ad block to your browser. And tweak your OS to get rid of items not necessary or specific to your needs.
Mar 04, 2016 | Panasonic Computers & Internet
Tip
Tips to Make A Laptop Faster
Run a good<b> registry cleaner</b>: Registration of a <b>laptop</b> is absolutely intrinsic to its functioning and, therefore, any corruption or errors in the registry can take your<b> laptop</b> running slow. To keep your registry clean and make sure it is not damaged, run a <b>registry cleaner</b> regularly in your <b>laptop</b>.<br /> <br /> Delete all Temporary Internet Files: When surfing the Internet and visit various Web sites, an imprint of the Web page or a temporary file is stored on your <b>laptop</b>. Contrary to its name, these temporary Internet files on your <b>laptop</b> are more than usual and therefore slow performance. Therefore, you must delete all temporary Internet files regularly for your <b>laptop faster</b>.<br /> <br /> Defragmenting the <b>laptop</b>: Most of the time when the registration information or data on the <b>laptop</b> is placed anywhere in the system. This results in a lot of processing time and therefore slows down the laptop. Therefore, to make your laptop faster, to be defragmented regularly. By obtaining the defragmentation is complete, ensure that all data and information stored on the laptop is simplified. This allows easy access to information, saving time, and therefore helps your laptop run faster.<br /> <br />
on Jan 17, 2011 | Computers & Internet
Why would I not be able to listen to music. starting 1 jan. i get the Pandora page but the artist does not and music
Minimum Specifications to Run Pandora
Most modern computers will play Pandora just fine, without any modification.
Minimum browser requirements:
Internet Explorer 7
Safari 4
Firefox 4
Chrome 7
Minimum hardware requirements:
PC desktop: Intel Pentium 4 2.33 Ghz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM, or
AMD Athlon 64 2800 or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
PC laptop: Intel Atom 1.6 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Mac laptop: Intel Core Duo 1.5 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Mac desktop: PowerPC G5 1.8 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Minimum internet requirements:
Consistent bandwidth of at least 150 kbps
If you upgraded to Pandora One and want to use High Quality audio, we recommend having at least 300 kbps of bandwidth.
If you're not sure of the speed of your internet connection, you can test your connection speed at any of these sites:
http://www.speedtest.net
http://www.dslreports.com/stest
Cookies Turned Off
Jan 02, 2015 | pandora.com Computers & Internet
Laptop runs super slow and I just bought it 3 days ago
STEP 1: Make Computer Faster by Upgrading RAM
Step 2: Make Computer Faster by Removing Computer Viruses, malwares
Step 3: Make Computer Faster by fixing registry errors
(Use PC Fresher)
Step 4: Make Computer Faster by Minimizing Startup Programs
Go to Run.
Type msconfig and press Enter.
The General tab helps diagnose if the problems encountered are with drivers, services, or startup items by unchecking the appropriate boxes and restarting. The Startup tab allows you to individual disable or re-enable startup items.
Oct 08, 2013 | Computers & Internet
Its verry slow
Step 1: Make Computer Faster by Upgrading RAM
Also try to use computer optimization tool PCFresher to speed up windows.
Feb 18, 2013 | Computers & Internet
USB Port can preform faster error message
This is because you are plugging in a USB 2 device to a standard USB port, or a USB 3 device into a USB 2 port. The computer is just telling you that if you upgrade the hardware, the device will work faster. Its more of an information message than an error. Your device should still function fine.
Jun 28, 2012 | Dell XPS M1530 Laptop
I have an IBM Thinkpad 1200 and its running slow, i need to change the CPU to a faster one. What CPU is available for it?
I think cpu changing is not wise in budgetry if really you need to make your device faster .
if really you want to make it faster just change the motherboard and cpu to gether but still its not resionable.
better to try and increese the ram and the use faster hard drive .
and run only the programs only required by disabling application on startup.
Dec 13, 2010 | IBM ThinkPad i1200 1161 Notebook
Ei systems laptop memory upgrade?????!!!
1gb ram will speed up your access memory you will notice it a little faster when going from web site to web site but to really speed it up you need a faster prossesor or / and better broadband
Apr 01, 2009 | Computers & Internet
Toshiba satellite
#1 answer; add RAM. What's your system specs?
Feb 26, 2009 | Toshiba Satellite 1805-S274 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
