Question about Lands Phones
Lg vx8350 Using external antenna port. Phone now refuses to switch back to internal antenna when external antenna is unplugged. No signal now without external antenna. Plug external antenna back in, full signal. Any ideas? Verizon is stumped as usual. They want to blame everything but their phone. Normal
  • Anonymous Mar 04, 2009
    Plugged Wilson 359915 adapter into phone and when removed, can no longer get a signal except in the very best service areas. Seems internal antenna is no longer functioning-either switched off or broken.
The Wilson adapter damaged your internal antenna. I talked to Wilson today to get a part number to buy the adapter and the told me they did not recommend using it as it has damaged a number of phones. They also said that LG might have corrected the problem in the newest production models.
Posted on Jan 08, 2009
HG8245A VS HG8245: The same Wifi Signal Strength?
Probably not...... With an External Antenna, there is nothing to stop the signal, whereas with the Internal, the Signal has to penetrate the case, before it goes to wherever...... I suggest using the External for the extra distance.... With 2 way radio the clearer the area yo have the Antenna, the greater the distance.... same here.... just using different Frequencies.
May 08, 2014 | Computers & Internet
Poor signal with lg vx8500
LG VX8500 Signal Boosters and Antennas. Keep your cell phone signal strong with these LG VX8500 Antennas for use in your car, office, home, or boat. Get even more from your LG VX8500 cell phone with an external antenna and 3 Watt Signal Booster. Don't get stuck without cell service at a time when you really need it. Add an antenna and booster compatible with your LG VX8500 cell phone.
Nov 26, 2013 | LG VX8550 Cellular Phone
Simply....The phone refuses to turn on
first thing i would try is some kind of electrical contact cleaner. spray a little on a tooth brush, and clean the charging port. do this with the phone off and battery out.
Apr 17, 2010 | Verizon Communications LG VX8350 Cell...
LG VX8350 can't transfer mp3's to removable storage any more
Make sure you format the card in the phone and not using an external card reader.
Also make sure you are not using a card that is beyond the capability of the phone. The phone is limited to 4GB cards.Use only cards that are 4GB and lower capacity.
If you still have problems I would try getting another brand of card, Kingston and Sandisk have worked well for me.
Nov 13, 2009 | LG VX8350 Cellular Phone
I lost the little plastic cover that keps dust and debris out of the port that the charger plugs into on my LG VX8350 portable phone. Can I buy a replacement?
I've had my phone for over 1 yr without that little thing. Never had a problem. Call local Verizon store they can tell you.
Jan 28, 2009 | LG VX8350 Cellular Phone
Cell phone reception dead after using amplifier
I had this same problem with a motorola razr some time back. Some cell phones have a built in switch (such as the Razr) inside the external antenna connection. In the case with my razr, I
evidently pushed the adapter into the phone too far. I later had to jump out the switch inside the
phone to make it work with it's internal antenna again. Unfortunately, I could'nt use that same phone with my amp again. Just a thought on your problem.
Dec 01, 2008 | Wilson Electronics 811102 Direct Connect...
Audiovox SMT5600 Searching most of the time
Not necessarily. If you very carefully open up the upper dark portion of the back of the phone (where the antenna extension is), you'll see that the antenna of the phone is actually a metal track which winds around the back of the headplate.
Check to make sure the two prongs which touch this headplate can do so without any problems. If the internal antenna is corroded, it may need to be replaced.
Most cellphones have varying antenna power, so you can expect to see differences when comparing two cellphones side by side. If you find your phone has no signal mostly when driving, check out this link: http://www.cellantenna.com/Boosters/cellphone_signal_boosters.htm
I hope this helps.
Take care,
Rob Kendrick
Nov 06, 2008 | Audiovox SMT5600
V3xx signal loss
take the phone to a mobile service shop and have them replaced the antenna that is located on the phone's main-board.
May 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Razr V# lost service after using external antenna
I have the same problem. Contacted 3rd party tech, take sharp pick or equal and there is supposedly a button in the very center of the antenna port of the phone. gently push the pick in the center of the jack and it will trip the switch. I tried it on my second damaged phone and it worked, so far.
Nov 24, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
376 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
