Question about D-Link DI-704P Router
Connection computers in network says in internet network connection is LIMITED CONNECTION or NO CONNECTIVITY. pLS. Give me a solution ASAP thanks very much...
    Novelist:
  • 143 Answers
Try to do a power cycle. turn off everything. then turn on the modem first the the router (if you're using one) then the computers.
check if the cables are properly connected, try to use another cable for hardwired computers. for wireless computers, make sure that it's connecting to the correct wireless network and you are using the correct wireless password (wpa/wep)
if you want to check your wireless settings, just log in to your router's page by typing http://192.168.0.1 on the address bar of your web browser. by default the username is admin and there's no password. you will be prompted by the router's page, go to the wireless section and check the router settings are the same with what the wireless computers are using
hope this'll help you but if you still have a problem, just give me your network setup (i.e. brand of the modem, router, number of computers and if PCs are hardwired or wireless)
cioa!
Posted on Oct 13, 2008
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Cannot connect to the internet
Limited or noi connectivity means your connection is not setup properly. The best method is to let the computer set it up for you (by DHCP). Right click on the connection you are using, in "network connections" Click "Repair". This command asks the computer to reset your ip by DHCP. Your connection should now have full connectivity.
Mar 19, 2010 | AT&T Computers & Internet
My Intel(R) PRO/Wireless 3945BG Network Connection , has a limited connectivity to the internet
Sometime when you switch on the computer and the wireless router (if you turn it off after using it) the computer does not get an IP address from the router in time when the computer finishes booting up. This problem may not occur all the time.
When you get the limited connectivity error, then right click on the wireless connection icon on the Task Bar and click REPAIR. This will get the wireless router to issue the wireless card an IP address.
Then you will have proper Internet connection.
Mar 09, 2010 | Intel PRO/Wireless 3945ABG Network...
Hello :), One day I turned on my computer and my network connection shows up limited connectivity now every time I turn on my computer it my internet connection shows up limited connectivity. I've tried...
if you are getting limited connectivity.. double click on network icon on task bar and go to support tab and click on repair..it will work.. if its not working give the ip and dns and default gateway manually.. not DHCP
Dec 31, 2009 | Microsoft Windows? Vista Home Premium...
hi,
welcome sir,
what i can suggest u is that just reset the router and then install the wireless driver into ur computer and then try and connect to wireless network and hope u will be connected......good luck....
pls rate this solution..........pls...thanks
Feb 12, 2009 | Adapters.com PLANET USB WLAN...
Having Limited Connectivity On My Vista Laptop When I Use Dial Up Connection
It may be the speed of your connection....dial up...
Try connecting somewhere else and see what you get...
If that does not work, check your dial up settings....
Jul 20, 2008 | HP Pavilion dv6000z Notebook
Limit or no conectivity problem
I understand that you are using the Windows Internet Connection Sharing to share your internet connection to your other computer.
If you don't have a router to share the connection then you are using Windows ICS connection.
When you enable ICS, the network adapter connected to the local area network is assigned a static IP address of 192.168.0.1.
You can check this site for more information
http://www.annoyances.org/exec/show/ics_xp
You can try to connect the two computers first without the internet connection.
Example : PC A 192.168.0.2
You can set the IP addresses manually, just set the tcp/ip properties and from that area you can set the IP address manually.
And for PC B 192.168.0.3
You dont need to set the ip address for the gateway and dns since you are just testing the connection of the two computer.
They should belong to the same workgroup example HOME and set the computer name to PC1 and PC2.
You can right click MY COMPUTER then select PROPERTIES then you will able to see the computer name.
To start the wizard
1.
Choose Control Panel from the Start menu.
2.
Click Network and Internet Connections, and then click Set up or change your home or small office network.
http://www.smallbusinesscomputing.com/webmaster/article.php/3293481
http://www.homenethelp.com/connection-sharing.asp
http://practicallynetworked.com/sharing/xp_ics/
Mar 05, 2008 | Computers & Internet
No wireless
you have to renew the ip address.the easiest way to do this is restart the computer then try entering your net key.ALSO if you use a standard ethernet cable the computer may be trying to connect to the internet through that.what you want to do is disable the LAN connection in your network connections window and right click on the wireless connection icon and click REPAIR,this will renew your IP address also.If you do not know how to get to these settings go to START/ CONTROL PANEL/NETWORK CONNECTIONS then right click on your wireless connection then click repair.While your in that same window you can right click the LAN connection and disable it.To enable it simply right click the icon again and click enable.
Nov 14, 2007 | HP Compaq nc6000 Notebook
D-Link DI-704P Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
