I'm trying to use a D-Link wirless USB adapter to connect to a linksys wireless password protected network. For whatever reason it's not working. Before I password protected my network it was fine... now I cannot get them to talk!
    Master:
  • 505 Answers
Access the linksys router page from your computer and then enter the password for the network again and save it on the computer.
Thanks
Posted on Oct 13, 2008
Netgear wirless - installed on toshiba satellite a45 - S151 will not connect to internet router = comcast - linksys also causes conflict with connection of other wireless computer
Presumably, you have configured your wireless router:
* SSID (your "network name")
* encryption-level ('WPA' or higher security)
* password for your network
With that information, any wireless device (iPod Touch, iPhone, NetGear wireless adapter) should be able to connect to your wireless router.
Exactly what error-message are you getting?
Feb 21, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
Having trouble with initial connection to an existing wireless network wireless router is a cisco wireless-n broadband router and we have 2 laptops and a printer on a wirelss network already
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Nov 01, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys
Sound's like it got zapped,do you have a surge protector on all your equipment if not even a small surge can destroy the electronics in todays Pc equipment.more than likely you'll have to bay another one. Hope this helps,and good luck.
Jul 26, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Were would i find the wep key or the wpa for the WUSB54GSC Wireless -G USB Network Adapter/
The Wep Key is located in the wireless router settings and will not be found on the network adapter. The network adapter needs the wep or wpa key to connect to the wireless router. You will need to use a computer hooked up directly to the router and enter the router settings menu to find or change the wep or wpa key. Most routers use 192.168.0.1 or 192.168.1.1 to enter the router menu. When you input the IP address above a screen should come up asking for a username and password. Enter those and that will allow you to get into the router menu. If you do not know the username and password you can reset the router with the reset button and that will restore the default password which is usually no username and password is admin.
Oct 16, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Failed connection - Linksys Compact Wirless-G WUSB54GSC adapter
1.uninstall the driver
2.restart computer..
3.in the windows..run the cd driver of WUSB54GSC and install...next..next...after that..restart computer...
4.in the windows..insert your linksys usb wireless device...and start using your wireless..
Jan 04, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Wirless network problem
If you are able to go online even for 1 minute, then try to change the channel on the router, set it to 11 to minimiz wireless interference.
Aug 21, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Linksys Wirless Adapter not recognizing IP address
Make sure that your security password is correct.
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless zero client are started and set to startup type automatic.
Jan 11, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
