Question about SMC Barricade g SMC2804WBR Wireless Router
Smc289wbr wireless could it be a cable problem
My Smc wireless Baracade 2804wbr does not connect to the internet, the act or activety light will not respond,
The wlan, wan flash and dram all pass the test.
When I access the baracade software a message appears dsl not connected. When I check network connections on the toolbar it states connected. I replaced one of the eithernet cables, and have checked the modem. If I bypasss the router and go directly to the modem all works well,
When I called customer support for SMC they advised that they no longer directly support the product.
Any suggestions would be greatly appreciated.
Could it be another defective ethernet cable?
Thank-you
  • 611 Answers
Re-configure the router properly and get the right details from your isp.(internet service provider)
Posted on Dec 13, 2008
Hi I have an SMC baracade g wireless router and want to connect my samsung galaxy 580 phone to it wirelessly. My computer connection is working. The phone detects it fine and can see that it has WPA/WPA2...
Hi
Try to unplug the power cable of your router for a minute or 2 to re-establish its connection to server. Then try reconnecting to your home network.
Hope this helps
Dec 09, 2010 | SMC Barricade 7004VWBR Wireless Router
I have a belkin vision N1 modem router connected to the Internet by ADSL and I wish to connect to it a SMC Barricade N with a 20Meter cat 6 cable to improve wireless reception on the other side of the...
Can you clarify the problem?
Consdier first that both devices are NAT firewalls and your ISP probably only allows one address. So you would need to put one behind the other. This may not work like you plan. PCs behind the second will not be seen on the LAN by PCs on the first.
The N1 is a very good router. Consider relocting it to a more central location.
Another trick is to locate it near a central wall if it is block. By adding 1 remote antenna and drilling through that wall witha short antenna cable you can get much better coverage on the other side.
It could also be an ethernet problm 1. Power down SMC, plug WAN of SMC to LAN of router and power up SMC. If both devices show link lights and activity the hardware is OK. If not you need a "crossover" cable.
Hope that helps.
Oct 07, 2010 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
Currently Connected to internet with to Telefonica through ethernet, and SMC Wireless router will not work. Router worked a few days ago, but now will not function either via ethernet or wireless. Our...
It appears the SMC router is faulty. The router is getting an IP address from the IPS because they can can PING your router and get a reply BUT the router's PPoE/DSL light is not on, it means it is not connecting with the ISP's WEB server and therefore you cannot get into the Internet.
Feb 25, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
Jul 07, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Two router home network problem
Can you still connect to the Internet with the Linksys router? I suggest that you go ahead and reset the SMC router to clear up your previously configured settings. Then before reconnecting it to the linksys router, make sure that you can access its web interface via 192.168.1.1. Don't disable DHCP as your computer won't be able to obtain an IP address from it automatically. Do not change other settings. Next, disconnect the ethernet cable and check if you can access the router interface wirelessly. Once done, connect SMC's WAN port to Linksys' numbered port. Make sure SMC's WAN light is on, as well as the light for the port you used on the Linksys router. Check if you can get online.
With this configuration, the linksys router is now acting like a modem, and the SMC as your router. As long as you're online when wired to the linksys, you should also be able to access the net on the SMC once you physically connect them.
Dec 22, 2008 | SMC2804WBR Wireless Cable/DSL Broadband...
SMC Barricade 2804WBR.
just hardwired a computer to the router and open a web browser. on the address bar of the web browser type http://192.168.2.1 (default ip address of the router) and you will be prompted with the login screen. by default you don't need to type anything on the password field. now you will prompted with the router's page and from there you can set it up.
click here for the manual.
hope this'll help you
ciao
Oct 07, 2008 | SMC Barricade g SMC2804WBR Wireless Router
Cannot get internet and WiFi when I connect to smc6624M
ok you do the reconfigure the linksys routerand give the wireless enable in the both smc and the linksys also .
Jun 01, 2008 | SMC (SMC7004AWBR) Router
Cannot connet to internet
Device communication issue! This sometimes occurs fro many reasons mainly FIREWALLS~ In order to keep this from happeninig you should probably setup a static address on your laptop or if your network has a SSID, it needs to be manually set into your adapter because it is not picking up your network. This often happens when you use your laptop in or on other networks. Easy fix, but need answers to these questions!
Nov 25, 2007 | SMC Barricade g SMC2804WBR Wireless Router
Open Questions:
SMC Barricade g SMC2804WBR Wireless Router Logo
126 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
