Question about Microsoft Windows XP Home Edition
Reinstalling operating system
I need to reinstall my OS I have a recovery disk but no seperate drivers disk,is it likely all needed drivers are on the recovery disk ?
If after using the recovery disk will the computer come back being able to run as it was when supplied?
  • bobtelecom69 Oct 14, 2008
    Well I put in the recovery disk but it failed after a short time because it couldn't find something called SISRaid drivers, on further investigation it seems these are hard drive drivers,thats why it couldnt proceed,Im pretty sure I have a floppy with these drivers supplied by the manufacturer from new with the computer,the only problem being there is no floppy disk drive fitted on the computer,so how on earth can I load them to proceed?
    After starting the recovery cd it stops after a few seconds and says it cannot continue as the SISRaid driivers are missing,these apparently are the drivers for the hard drive ...I do have them but they are on a floppy and of course computers these days usually come withhout floppy drives,mine included,so for the moment Im stuck ....apparantly they cannot be entered from a cd or I would have copied them onto one ...
    The problem is Im seeing it at the moment is that my hard drive is a Sata and Windows doesnt carry those drivers,so therefore the recovery cd cannot continue without the hard drive starting ....
I m the user of tally. if i want to give the printing.for giving the print i use any command yes or not.please solve this problem.
Posted on Oct 13, 2008
  • 71 Answers
Vista does have a very extensive driver database already, and should reinstall all of your drivers after you reinstall. If there is a driver that you need that you can not find, you can look on your computer manufacturers website or just post here what drivers you need. You will be OK :)
  • 3 more comments
  • compgeek09 Oct 13, 2008
    DONT FORGET TO BACK UP YOUR DATA!!!!
    Documents, Pictures, Music Etc....
  • compgeek09 Oct 14, 2008
    I cant believe it is asking for this but.... here we go:) Try this and let me know. Is it asking you to insert a cd?
    Go here, choose Vista> SATA&RAID>SATA&RAID> hit go> choose your download loaction (USA?) then you will need to copy to a cd or possibly a flash drive might work.
    http://www.sis.com/download/
    Keep me posted!
    Hey read these 2 articles. Sounds to me like step 14 is where you are getting stuck. Also, step 15 says that you can use floppy, CD, or USB flash drive. Give this a try and let me know what happens. Thaks for your patience, and I will get you going, If I have to come install it myself..lol Jk I hope this works for you!
    Re: Installing Vista Upgrade needing SATA RAID drivers
    Installing RAID/SATA Drivers
    Raid and/or SATA drivers are not installed by default by the Windows Operating system; therefore if your Raid or SATA drivers are not installed manually at the beginning of the Windows installation sequence, the chances are that you will not have access to your Raid or SATA disk drive(s).
    To remedy this the driver(s) need to be installed during the very early stages of installation of the Windows Operating system
    Clean Install
    1/ Turn your PC On
    2/ As the PC starts quickly insert the Windows Vista DVD into the DVD drive
    3/ If all goes well a black screen should appear with the legend 'Press any key to boot from CD or DVD.' If you miss this screen just reboot your machine again
    4/ At the 'Press any key to boot from CD or DVD' screen Press Enter or any other key to start the Windows Installation
    5/ Windows will now start loading files into memory
    6/ After files have been loaded the screen will change to a black screen with a green progress bar. Beneath the progress bar are the Microsoft copyright details
    7/ After a short while the language selection screen will appear. Select the desired language, and then click the Next button
    8/ The Install screen will now appear
    9/ On the Install screen Press the Install Now button
    10/ At the next screen Insert your Windows Product Code number and press Enter
    11/ Next you need to accept the EULA (End User Licence Agreement). Place a Tick in the Accept box and then Click the Next button
    12/ At the next screen you will need to Select your Installation type. As you are performing c Clean install only the Custom option will be available for selection
    13/ The next screen asks 'Where do you want to install Windows'
    14/ On this screen, bottom left hand corner, you will see an option marked Load Drivers. Click on this option
    15/ To install the device driver(s) you will need to insert the installation media that came with the RAID/SATA drives and which contains the relevant driver(s). This media can be floppy disk, CD/DVD or USB flash drive. Once you have inserted the media into the relevant drive, Click the OK button
    16/ The system will now search the media for the relevant driver(s)
    17/ After the search has been completed the driver(s) will appear in the 'Select the driver to be installed' Window
    18/ Select the relevant driver and then click Next
    19/ The driver will now be installed
    20/ If more than one driver requires to be installed, repeat steps 17 to 19 until the necessary drivers have been installed
    21/ After all drivers have been installed, click the Next button to continue installing Windows Vista........
    Well, after 3 weeks of seaching the internet for a way to install Vista I
    finally got it to work. Nothing I found out there in numerous forums helped.
    Intel only has the drivers that are a few years old already. Every time I
    tried to Install Vista it told me I needed updated drivers even though I have
    the "newest" ones available.
    Out of the two choices my Vista upgrade gives, If I choose the first, to
    upgrade saving my setting and such it never lets me past the SATA RAID driver
    warning and closes the install. I decided to back up all my **** and try the
    "clean" install which I find out doesn't wipe anything, it just puts all your
    old stuff in a folder called windows.old but you need to re-install many
    programs although some of mine do work run from there.
    Anyway, after selecting to do the "clean" install it still told me that my
    SATA RAID driver needed to be updated but here it gives me the opportunity to
    load the driver from a CD or Floppy or somewhere. I had the floppy with the
    most current driver from Intel that is used for the F6 install. So I figure
    what the heck I'll point it to that floppy. It sees the file as one it needs
    but it rejects it and still tells me I need to upgrade the driver.
    From here I'm just fuming and just playing around since the Vista install
    tells you to uninstall some programs before trying, so I'm mad at having to
    reload those (again) since this attempt failed (again). On a hunch I looked
    at the driver version on the floppy (3.4.6.6222) and compared it to the one
    already loaded on my system in the device manager/properties area. The one
    loaded on my system was version 5.5.0.1035 from the Intel Matrix Storage
    Manager. That driver is dated 10/12/2005.
    So just to do something while watching TV I restarted the Vista upgrade
    install, selected the "clean" install and when it said I needed to upgrade
    the driver again I selected "load driver" and pointed it to my Intel
    directory where luckily that higher driver was located. It found that driver
    and after a minute of pondering my selection Vista started loading.
    Even though that driver was already loaded on my system for some reason the
    Vista upgrade didn't recognize it as valid until I actually pointed it to the
    driver. Weird but it worked and now I'm running Vista 2 days with no
    problems (so far).
    -So, I selected the "clean" install,
    -when it came up with the error I selected "Load Driver"
    -then pointed it to my folder Intel/Intel Matrix Storage Manager/Driver
    -It found the iastor.sys
    -I told it to use that one and Vista loaded.
    It seems a simple fix now but I don't understand why it didn't use that
    drive since it was already installed. To me Vista was telling me that it
    didn't like that driver, so I don't know what the installation program was
    looking at until I told it exactly where to look. Plus, nobody out in
    cyberspace seemed to know how to fix that error. I just got mine working by
    sheer luck and dinking around. Maybe this will help others out there.
    Please note that after step 21 there begins a new article with a different solution, so try both if the first one does not work.
Ive lost a recovery disk and now i cant reinstall,is there any way i can download off the net and make new recovery disks?
Two seperate issues. You can order new disks on ebay for example but if your product key is unreadable you need to purchase a new key.
See this link to buy - http://www.amazon.co.uk/Microsoft-Windows-Home-Premium-inkl/dp/B008OT79T4/ref=sr_1_2?ie=UTF8&qid=1426423337&sr=8-2&keywords=windows+7+coa
Mar 14, 2015 | Acer Extensa 5635Z Drivers Recovery...
Ihave a Sony VGN-s120 Notebook,after running the system recovery disk.The computer crashes and will not boot.
Attempt to run it again or if you have a setup cd to install your windows again.
Let me know how it turns out - something may have gone wrong in the last recovery.
Jun 29, 2008 | Sony VAIO VGN-S460 Notebook
How do you reinstall the os
insert system disk, then select restart. or
install disk, hold power button down until machine shuts off. then hold down c key and push power button. Hold c key while machine boots from optical drive.
Jul 13, 2013 | Apple Mac OS X
My acer aspire will not boot can you help
I think the operation system is corrupted and the action to do is press the key specified on screen to get to the boot menu ..and select the recovery partition if you have one ..In this option select to total reinstall the operation system and will work after that .
To engage the recovery if it does not work with the boot menu ..try to see if F11 works ..usually this key is reserved for recovery procedure alone ..
If you do not have a recovery partition you will need a recovery disk and the same procedure Boot from disk and reinstall the system or ..a Boot-able disk with operation system on it to reinstall the system from scratch ..
let me know if you have other issues related with this ..
Dec 21, 2011 | Acer Aspire X3810U1802 (PTSC102005) PC...
How can I unlock my computer if someone change my password
This is about user password and there is no easy fix..but the procedure to get rid of it is not that complicated..Practically you have to reinstall the operation system or use the recovery partition to reinstall the OS ..and this will remove the password..reinstalling in either way will erase the C drive partition ..and if you have important data on this partition it is best to try to make a installation of the OS using the repair feature during and keep your data . or if you can not manage , just remove hard disk ..and add it to another computer running same OS..and browse for the folders in side and save them ..and reinstall after that ..
you will need either the recovery partition or recovery disk or boot-able disk with the OS or a boot-able usb tool with the OS ..and the drivers for the motherboard and devices..
Dec 17, 2011 | HEWLETT-PACKARD Compaq Presario CQ5302F...
Operating system not found
Ouch. So many possibilities here. Did you make a rescue disk at any point? Because you're going to need it.
Feb 28, 2011 | Dell Inspiron 9100 Notebook
Pc won't let me reformat it i've no disc because it's built in on the hard drive please help
If you want to reformat a harddrive on your current computer, you need to remove the drive and plug it in as a secondary drive on another computer. Then formatting is easy.
Alternatively, you can use your operating system installation disk and format before re-installing your OS.
Mar 09, 2010 | HP Computers & Internet
Hp Pavilion 6701 desktop with ME. Installed Xubuntu OS and removed ME. Want to reinstall ME but recovery disc won't work.
Hard disk needs to be reformatted--start machine and press correct key when "setup" appears in first dialog. Remove hard drive in first screen, then reinstall. Restart computer, should now say: "operating system not found". You need original Microsoft OS disk to reformat drive and reinstall ME. All previous information on hard disk will be lost with this procedure. Recovery disk is used with original OS before Ubuntu. If you don't have original MS disk, suggest going to XP.
Jul 06, 2009 | Computers & Internet
Drivers for HP Compaq Presario V2000 laptop
http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&query=Presario%20V2000%20&dest_page=softwareCategory&tool=softwareCategory
You will find the drivers you need there!
Just select one of the 3 V2000, the one YOU have, then select your OS, download all the drivers you need.
Good luck to you!
Please take a minute to vote
Nic
Jan 30, 2009 | HP Compaq Presario V2000 Notebook
Laptop System Recovery
Some way you have lost your operating system. The way to get your computer back up and running is locate your system restore disks. You can use these to reinstall your operating system. The first disk you will probably use is the OS disk itself. You can install your operating system with this disk. If you do not have the restore disks, you can either contact your computer manufacturer and request them, or you can just purchase the Operating System disk, which is kind of pricey, and reinstall the OS with that. Once you have gotten your hard drive reformatted, and your OS reinstalled, you will have to go to your manufacturer's website and download all the drivers that pertain to your specific computer.
Sep 04, 2008 | AMD Turion 64 X2 TL-56 CPU
Microsoft Windows XP Home Edition Logo
287 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
