Question about Kitchen Ranges
I have frigidaire stove and the plates and oven does not heat up yet the lights come on. The main breaker on the panel box is ok. I am not sure if fuse on the stove is blown.
    Scholar:
  • 136 Answers
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
and check out for this diagram chart to know what is the problem
just click on this link
http://www.applianceaid.com/image/microflowchart.JPG
thanks
Posted on Oct 13, 2008
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Kenmore model 970-506021 no power to burners or oven but display works
Did you reset the house circuit breaker to the oven. If the stove is only getting 120 volts instead of 240 the display will light but no heat. A remote possiblity could be a burned wire at the power connector where the main powewr comes in to the stove of a bad comnnection in the junction box.
Feb 06, 2014 | Kenmore Ovens
Stovetop & Oven not heating but clock, lights, & vent fan are working
It sounds like you are getting only one side of the power to your stove. the lights will work but no heat. your power breaker has two sides for an electric stove. It may be one side isn't reset properly. make sure that you snap the breaker completely off and then completely back on. if that doesn't work perhaps an electrician is in order or one side of your power cord has burned off at the terminal block. I have had this happen.
Apr 28, 2013 | Kitchen Ranges
Clock works fine, but surface elements do not light up or heat.
it sounds like you are only getting 110 volts to the stove.
have someone that knows a little about your breaker box. check the breakers
you may only need to wire it right or may need to add another breaker.
should be an relatively cheap fix.
good luck remember electricity bites!
Sep 13, 2012 | Frigidaire FPES3085KF Stainless Steel...
I own FRIGIDAIRE ES100/105 (electric stove and oven). Yesterday I was using the oven and suddenly I heard a loud sound. I went to check it I found out the both the oven and stove were off. And not working....
HI. The actual issue will be with the main logic board, which is where the main element control relays are mounted. These very important relays are damaged. The main board will need to be replaced, asap.
With that said, if you could be so kind; Please post the entire model number so that i may pull up all necessary part numbers needed, as well as, service manual links and diagrams to help with your repair.
Dec 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
Left front plate dead. Cant seem to find the fuses
there are no fuses on the unit it self -- the stove is protected by the circuit breaker at your main fuse box. if your front plate is not heating up I would say that you need a new heating element.
c...
Dec 31, 2010 | Ovens
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
Frigidaire ES400 range - oven will not opperate, range will
Me too. Oven was on, big "pop" and breaker went. After re-setting the breaker (and setting the clock on the range), the stove top works fine, and the controller for the oven seems fine, just that neither the top or bottm elements will heat up in the oven. 240 V is getting to the control module, but it is not sending out any juice to the oven elements.
Any fixes out there?
Mar 30, 2009 | Kitchen Ranges
My RCCD unit sometimes trips when I turn my main oven on
I'm assuming you are speaking of the line circuit breaker to the stove. If that is the case and there are ** other problems that you k**w of, it is possible that the breaker has gone bad....they do. Get the same brand and rating as you had originally installed. Cut your main feed and open the terminal panel and remove and replace the unit. Restart main feed and set breaker on. If you continue to have issues, check all wiring to your stove...a loose wire or corroded contact point may be a second issue.
Mar 09, 2008 | Ovens
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Kitchen Ranges Logo
103 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
