Question about Minolta 2430DL Color Laser Printer
Small dent in paper
I am having a problem with a small dent appearing about half way across the page and it repeats about every 4.5 inches vertically down the page. The dent is small, about 1/8 inch diameter and about 1/64 deep. Your help is appreciated
    Champion:
  • 214 Answers
Check pc drum or fusing unit roller
Posted on Oct 14, 2009
Thin vertical line on copies
Tara, if the ink levels are ok, try clean and allignment functions from the tool menu. Use CLEAN UNUSED PAPER.
Mar 24, 2014 | Canon PC-940 Black and White Copier
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
I am getting a blue line on my scans when utilizing the feeder
The feeder sends the original across a small piece of glass. The scanner stays in one position as the paper runs across it rather than the scanner moving and paper staying still. The little piece of glass is probably a 1/2 inch by 12 inch glass. just clean that strip of glass. use alcohol. there is probably some whiteout on the glass. It will appear as a dot. When the paper runs across it, the dot is run across the whole page causing the line. if you cant find the strip of glass, run a scan and try to see where the scan light sits while it's running. Clean everywhere where the light sits.
Jan 15, 2011 | Office Equipment & Supplies
Clp-500. toner streaking the paper.
I have the same streaks problem. Any solutions?
Nov 14, 2009 | Samsung CLP-500 Laser Printer
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Oce 7051 plain copier has dust or something on one of the rollers - prints have a trail of marks across sheet, repeating every 10 inches from top to bottom of page. Probably need to remove or access...
If the drum has marks on it, you might have to replace it.  Sometimes the fuser rollers can leave marks on them as well.
Check for lines on the drum first.  If they are there, it could need a drum replacement.
Sep 17, 2008 | Office Equipment & Supplies
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Black Smear
go to page13-9 routine maintenance section, where it says to clean the glass strip on top of it there is a white plate (shown) does that plate have ANY dirt or spots etc......?
It MUST be completely WHITE or it will give you black streaks. if it cannot be cleaned then use white out to cover. ( makesure it is completely dry before using).
Oct 08, 2007 | Brother IntelliFAX 885MC Plain Paper...
Minolta 2430DL Color Laser Printer Logo
79 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
