Question about Kodak Easyshare M753 Digital Camera
Red light i've used my m753 for a few weeks. but recently i connected it to pc to charge but a red light started blinking for a few seconds and then- blank. it doesnt get charged, it cant be switched on. any solutions??
  • 1 more comment
  • Anonymous Oct 19, 2008
    Same problem. I tried a new battery and it did not help. I tried using the AC charger and could not charge it with that either
    same here, the paying for that camera was not one of the smarter thing i've done recently. i changed the battery, same problem, something is wrong with the recharging circuit. i guess i'll have to see what type of warranty i have, otherwise its ready for trash. unless in perfect light, my cell phone took better pictures. waste.
  • BobMatWhatNe Oct 26, 2008
    I have the same problem when I connect my camera to the PC. But charges fine when I connect to the laptop USB. Is it something to do with USB hub and USB port mentioned in the manual. It explicitly says to connect to a USB port, not to a hub.
  • 74 Answers
Unless you have a spare battery and/or external charger it will be hard to tell if the charging circuit is defective or the battery is bad. I have seen posts in other forums with the same issue. I assume the camera is under warranty but you may want to purchase a spare battery and charger anyway as a backup if you are going to keep it.
Posted on Oct 13, 2008
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Camera wont charge. green light comes on for a second then a red light flashes and then goes out
This normally indicates a battery problem. Remove the battery and wipe the contacts (battery and camera) firmly with a dry cloth to remove any corrosion that may have built up on them. Heavy corrosion may require cleaning with a fine wire brush, steel wool, or sandpaper. After cleaning, remove any debris that may have fallen into the battery compartment, then insert the battery and connect the camera to the charger. If the green light stays on, the problem is gone and you can charge the battery for several hours and then use the camera. If the red light comes on, it's likely time to replace the battery - especially if it's more than a year old.
HINT: Always remove the battery if you don't plan to use the camera for a week or more. This will prevent corrosion buildup and extend both battery life and camera life.
Bill B
Apr 25, 2010 | Kodak Easyshare M753 Digital Camera
What does it mean when the red light blinks?
when the red light blinks, there will be electric/electrinc circuit failure so get it to a repairer/kodak service.
Mar 07, 2010 | Kodak Easyshare M753 Digital Camera
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Blinking Red Light-50" Sony Grand Wega
It sounds like Lamp is broken in TV and requires replacement.
How old is this TV and did you replaced lamp recently?
Oct 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My jabra BT160 won't charge
i had the same problem with mine. the problem is with the completely empty battery.
solution is to disassemble it and force charge the battery inside.
you have to cut any usb cable leaving the side which connects to pc and remove the insolation from red and black wires. connect them for few seconds to battery soldering points on jabra board (red to red, black to black, sometimes you have to scratch the solder a bit if it oxidized a bit). once you see the light you can start charging it normally.
Sep 23, 2009 | Jabra BT160 Wireless Headset
Wont turn on
Well to be3 a 100% about the battery I would replace it with one that you know or is guaranteed to work. Camera batteries can look OK from outside and be completely collapsed inside.
No Charge lights can indicate NO battery and if there is one inside then it is dead and registers as a no battery ( no charge light)
The red light blinks in very low state, but totally discharged it will not blink and wont blink again until loeft on chareger for about 3-4 hrs to overcome the low state.
Jul 25, 2009 | Kodak Easyshare M753 Slim Digital Camera
Camera wont turn on
Clean battery contacts. Use "small" flat had screw driver, and pry up "GENTLY" on battery contacts. Replace battery. Hit a few times with knuckle "NOT HARD" next to lens. Turn camera on. Camera will work forever.
Aug 28, 2008 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
153 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
