I have a Fujitsu / Siemens laptop with Intel PRO Wireless 2200BG wireless
module. Some time ago I tried to enable wireless module under 9.0, but it
seemed, it would require compilation of some modules, so I banned it for a
while.
Now I installed the 10.0 syste. The wireless module was discovered during
installation, but I was unable make it run. Weather I use kinternet,
kwifimanager, or a command line iwconfig/ifconfig, it looks, that the
interface itself is never activated, never detects any signal and never
gets an IP address.
Has anyone got this interface runnung uder SuSE?
Thanks for your help.
Pozdrawiam,
(js).
Rating: 0%, 0 votes
Since satrtmode is manual, did you start the interface ?
Is WPA or WEP enabled on the WIFI router ? If so, disable it during the
debugging phase. But don't forget it to (re-)enable it when a unencrypted
connection works.
Try to start the networking manually step by step after stopping the network
( with rcnetwork stop) and unloading the modules. And observe the logfiles
after every step
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Yes, indeed. Actuall, it's an Amilo Pro V2000D
Actually, I had to change ipw2100 to ipw2200 in Makefile and *.c. I
have a feeling, I achieved some progress, but my eth1 still does not
obtain DHCP address. :(
Best regards,
(js).
PS. When responding directly, please remove a dash with all the
following letters.
Rating: 0%, 0 votes
This is a switch which disables the radio of the wireless card.
Is this a Amilo series notebook ?
Then you might need an additional fsam7400 module to switch off that kill
switch. Have a look at the Archlinux Wiki
(#) to get
an idea, what to do.
PS:
Rating: 0%, 0 votes
Thanks.
I got some errors during compilation phase... probably need some
headers or module sources to be installed. I'll check it later though
and will let you know.
Best regards,
(js).
following letters.
Rating: 0%, 0 votes
Of course.
# lsmod | grep 2200
ipw2200 171656 0
ieee80211 51140 1 ipw2200
firmware_class 9856 2 pcmcia,ipw2200
eth1 device: Intel Corporation PRO/Wireless 2200BG (rev 05)
eth1 configuration: wlan-id-00:0e:35:34:3f:1d
eth1 Startmode is 'manual'
Oh... there is something interesting, though I'm unable to interpret it:
Nov 2 19:10:35 laptop-jstozek kernel: ipw2200: module not supported by
Novell, setting U taint flag.
Nov 2 19:10:35 laptop-jstozek kernel: ipw2200: Intel(R) PRO/Wireless
2200/2915 Network Driver, 1.0.6
Nov 2 19:10:35 laptop-jstozek kernel: ipw2200: Copyright(c) 2003-2004 Intel
Corporation
Nov 2 19:10:35 laptop-jstozek kernel: ipw2200: Detected Intel PRO/Wireless
2200BG Network Connection
Nov 2 19:10:35 laptop-jstozek kernel: ipw2200: Radio Frequency Kill Switch
is On:
Nov 2 19:10:35 laptop-jstozek kernel: Kill switch must be turned off for
wireless networking to work.
What the h*ll is this kill switch?
Best regards,
(js).
following letters.
Rating: 0%, 0 votes
eth0 is a 10/100 built-in Ethernet interface
- it works, of course
- set up with ifplugd (being turned on, when cable is plugged in)
eth1 is a built-in Intel WLAN interface
- I cannot make work
- it does not associate with an AP
- it does not obtain DHCP address
- set up for manual start
- I have no external means to check, if the radio gets turned on
- It works under WXP, so at least it's not a hardware problem.
eth2 is a pluggable (PCMCIA) Cisco/Aironet WLAN card
- it does work
- set up as hot-pluggable
- it does not set up a default route for some reason
Best regards,
(js).
Rating: 0%, 0 votes
for the wireless card. I wrote detailed instructions on how I did it
here:
Hopefully you'll have the same luck!
Rating: 0%, 0 votes
That's a good point to start. Well, I did not doubt that the hardware is
no working ...
Hmm, maybe I'm lucky because it took a little longer with SuSE 9.3
(where I had to "play" with various options until it was running ...)
For the SuSE 10.0 instllation I did it straight forward:
(1) Do the basic installation with the LAN port (leaving the WLAN port
untouched)
(2) By using YaST I set up the WLAN port *completely* with all the
router/AP parameters required (without using any other tool like
kwifimanager, kinternet, etc.).
Maybe that's the point because after setting up the WLAN port hardware
you will be prompted for the router/AP parameters (like ESSID, WEP or
WPA parameters, etc.,.
Maybe you should start it another time ...
Never give up !
Best regards,
Reinhard.
Rating: 0%, 0 votes
from flipping burgers at the local fast food joint and scribbled on an
etch-a-sketch:
Me, too. (Dell notebook.)
Here's what I found on 10 - which was different from installing 9.3 - The
WLAN worked like a charm during installation. Oddly enough, the built-in
ethernet did not originally work. After install, both worked fine.
I did nothing other than check to make sure DHCP was set on both interfaces
Which port is your wlan? eth1 or eth0?
k
Rating: 0%, 0 votes
Is ipw-firmware-5-6.noarch.rpm installed ?
What says lsmod about the driver module ?
Are there any messages from the driver in /var/log/boot.msg
and/or /var/log/messages ?
Rating: 0%, 0 votes
running WEP right now. I have other wireless devices that will only
do WEP. With SUSE 9.3 I remember I had to enter my WEP key (hex) into
the /etc/syconfig/... file directly. YaST wouldn't do it for me for
some strange reason. I think all of that worked fine in 10, regardless,
editing the file wasn't difficult.
Rating: 0%, 0 votes
pa??dziernika 2005 17:13 napisa??:
It means that at least some of the programs do work, at least some
times... :)
I'm also sure that the hardware works - I have wxp installed on the
same laptop, and its wlan works with my AP.
It's tough to answer, since I was trying and guessig and googling
with it for a number of hours yesterday and today.
It was a clean install. YAST discovered a hardware and loaded a
rexpective module during install. Then it allowed me to configure the
interface in YaST along with an Ethernet interface - I set it up for
a manual start, and the Ethernet for hot-plug, which works cleanly
btw. Then I turned my AP on and tried to run the wlan with kinternet,
but it did not work - it showed 0% signal. Then I started playing
with various parametres; first with gui, and after some time - I
discovered iwconfig and tried to turn it on using cli utils.
I have not yet. I'm still looking for hints. :)
Thanks.
Best regards,
(js).
following letters.
Rating: 0%, 0 votes
Yes, me ...
My notebook has got the same WLAN interface. This worked with SuSE 9.3
pro and it works also with SuSE 10.0 right now.
Question is: What did you do exactly ? Did you use the upgrade option of
SuSE 10.0 ? Or did you do a clean installation of SuSE 10.0 ?
What I did after an installation from scratch was to leave the WLAN port
disabled until all the installation was completed (incl. 1st run of
YOU). After that I enabled the WLAN port. The system is running without
any problem since then ...
Never give up !
Best regards,
Reinhard.
Rating: 0%, 0 votes
Jan Stozek <> wrote:
My IBM Thinkpad has the same wireless card. I didn't do anything
special to configure and use it under SUSE 9.3 and SUSE 10.0. I don't
know how to help you but my advice is: don't give up.
rr
Post a New problem for Intel PRO/Wireless 2200BG 802.11g/b
Email this problem
Can you Help with these Wireless Adapters problems?
I have an Intel PRO/Wireless...
