Question about Garden
Craftsman 2 cycle leave blower will not start
New plug .025 gap new mixture 3.2 to 1 gal of gas will not start will not start replaced primer bulb [it was broken] new plug which has spark, took filter off no start still
  • 3 more comments
  • donRicarddo Nov 02, 2008
    The blower will start but will only run for a few seconds. The Pull start is not working now, it will return buy not start the engin.
    donRicarddo@yahoo.com
  • bdunlap66 Nov 05, 2008
    have decent spark wont fire even with starting fluid seems to have compression with finger in hole.even tried new plug. Bill
  • AL Turcotte Nov 07, 2008
    Echo Pb - 413t Backpack Blower, will not start.
  • zepiain Nov 18, 2008
    my fuel mixture is correct, replaced spark plug with a new plug (E3.12) .spark plug is gaped correct and still won't start.
  • smedely dean Apr 08, 2009
    while using my 3 year old black and decker blower it just stopped working . i too have purchassed a new spark plug (someone said that spark plug no longer need gaped)??? Anyway i took everything i could off and cleaned it up . still no start .
  • 48 Answers
How much compression - you need a min of 90 lbs if you have that then it sounds like a carb prob
Posted on Oct 17, 2008
2 Suggested Answers
  • 5 Answers
SOURCE: craftsman 2 cycle leave blower will not start
That fuel/oil mix ratio should be 32to1 or 32 ounces gasoline to 1 ounce oil. You will have to make up a new mix and probably clean the fuel system and the spark plug before it will start.
Posted on Oct 01, 2008
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
My craftsman weedwacker 27cc curved shaft wont start and cant figure it out
I need to ask. Did you leave fuel mix in it for a long time? If so then the carburetor will need to be cleaned with a special cleaner. and not the spray can stuff.
Nov 24, 2014 | Craftsman 27cc 2Cycle Full Crank Curved...
Primer bulb on my craftsman leaf blower #358797342 wont prime
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
Dec 30, 2011 | Craftsman Garden
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
I have a John Deere hand held blower. I can't get
Your adjustments to the carburetor may make it worse.
Plus if the fuel mixture is over 30 old, I would replace it.
Manufacturers have told us this year any gas over 30 days old is considered bad gas and needs to be replaced. I would try some fresh gas(from the station) and some new 2 cycle oil at 40:1 Ratio(3.2 ozs 2 cycle oil to 1 gal of gas).
Good day.
Nov 07, 2009 | Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Sep 30, 2008 | Garden
Garden Logo
2,361 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
