Question about Alpine Car Audio & Video
Cda-7893, i can't adjust the bass and treble levels.
Duncan
  • 218 Answers
SOURCE: Troubleshooting on Adjusting Treble/Bass
Look in your owners manual and make sure you are turning the right knobs or pushing the right buttons once you have the adjustment screen for the bass/treble showing. It could be that they use different knobs/buttons than the volume control. If you are using the right controls, then you have a problem that only a shop can fix. You might reset by taking away all the power (acc and bu) for a couple minutes and then reconnect, but if that doesn't help then it time to go to the shop.
Posted on Aug 10, 2007
  • 1019 Answers
SOURCE: I just purchased a new
Theres 2 Models Listed.
Try Here:-
http://www.pioneerelectronics.com/PUSA/Products/HomeEntertainment/AV-Receivers/PioneerReceivers/VSX-517-K%7CS?tab=D
Hope This Helps.
Mike @ compurepair.
Posted on Mar 23, 2008
SOURCE: Alpine cda-9815rb
I solved this problem by calling Alpine Electronics customer services.
Posted on Apr 22, 2008
jyackle5
  • 8197 Answers
SOURCE: finding treble and bass adjustments on my stereo
Here is a manual for the radio. If you go to page 14 it will tell you how to set the EQ.
http://vault.alpine-usa.com/products/documents/OM%20CDA-9835.PDF
Good Luck Please Rate FixYa!
Posted on Dec 19, 2008
  • 21 Answers
SOURCE: New car, no manual
There is no straigt forward bass and treble adjustment. You must adjust in either the (x-over) or (users EQ) function. It is a bit tedious but performs the bass and treble adjustments at multiple frequencies.
Posted on May 21, 2009
I am suddenly unable to adjust the base, treble, volume, etc on my Alpine CDA-7940 stereo. Is there a lock or setting for this?
press the mode button, which is the audio knob repeatedly to choose the desired mode and rotate the knob until desired sound is obtained. as you press the mode button, the option will go from these followings: volume, bass, treble, balance, fade
Jan 13, 2015 | Alpine CDA-7940
Need to know how to adjust bass, treble, fade, etc. on Alpine model CDA-7862
Press the MODE knob to choose between bass, treble, balance, or fade.
Turn the MODE knob to change each setting as it is displayed.
Mar 15, 2011 | Car Audio & Video
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
BASS,TREBBLE,MIDS SETTING
Hello 1rocknroller,
Press the mode button repeatedly to select BASS, TREBLE, SUBW, BALANCE, FADER, DEFEAT, AND VOLUME. When subwoofer mode is set to off, it's level cannot be adjusted. If DEFEAT is set to ON, the player returns to factory defaults. Turn the volume control to adjust the setting. If no adjustment is made within 5 seconds after selecting, the player returns to normal mode.
Hope this helps.
May 29, 2009 | Alpine CDA-9856 CD Player
Can not turn the bass and treble up or down on my alpine CDA-9827
ok i cant see your entire question but to adjust bass and treble on an alpine, you see the knob (the one which u use to turn volume up and down), push it in (itll click) then a screen/textt will come up and say bass or an option once it says bass, turn the knob up or down, then press in again and it will say treble or fader or something else, once again, adjust it and keep pressing in the knob until u reach the volume again. does it work? is this what u wanted?
Apr 11, 2009 | Alpine CDA-9827 CD Player
Adjust
I have an Alpine CDA-9813 and to access bass, treble, fade, and balance, you need to press the volume button. This button is usually rotated to adjust the volume but on mine, if you press it in, first time accesses bass, second press accesses treble, 3rd press accesses balance(left to right), and 4th press accesses fading (forward to rear. Press it a 5th time and it either brings you back to volume or back to the main screen. I think it is volume tho. I would assume that the 9853 would work very similar, if not the same.
Mar 21, 2009 | Alpine CDA-9853 CD Player
Finding treble and bass adjustments on my stereo
Dec 19, 2008 | Alpine CDA-9835 CD Player
New car, no manual
Aug 24, 2008 | Alpine CDA-9833 CD Player
Turning the bass level down
I could not find an owners manual for the CDA-9853, but I did find one close to it and it should be able to guide you to where the bass and treble levels are It is the CDA-9820. here is where you can download it from for free: http://www.alpine-usa.com/images/products/product_downloads_pdf/cda-9820xm_ptg.pdf Good Luck
Jun 03, 2007 | Alpine CDA-9853 CD Player
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
