Question about Sony Handycam CCD-TRV11 8mm Analog Camcorder
Camera wont play or record has message c:31:23
I have an error message C:31:23,did you ever find a solution for the problem? I am having the same problem, if you would let me know, my email is egas1985@yahoo.com i have a sony handycam plays or records just for like 2 seconds and then shows error message
thank you, lacey
  • morrislacey Oct 21, 2008
    My camera does the same thing
  • 320 Answers
Basically, the error message indiactes the reels are not turning, either because of a defective tape or a fault in the mechanism. Try a new tape. If the problem persists, you will have to have the camcorder serviced. please be sure to rate this solution. Thanks!
Posted on Oct 23, 2008
  • Any Guy
    Any Guy Oct 23, 2008
    I don't understand why this was rated "thanks for trying" I answered your question.
GENIUS DVR-FHD590 UNABLE TO PLAYBACK SOME FILES
I HAVE THE SAME CAMERA AND THE SAME PROBLEM?
COULD YOU REPARE IT?
Jan 05, 2014 | Computers & Internet
Sony HDR-xr 150 is showing data error whenever I play back the recorded videos
Connect the camera with pc and try to check for error with any program like tune up or other online utilities... or if you have data card in it and you can open it in PC than simply copy your recorded videos so that you have a backup first. than you can freely show camera to any service center..
Sep 16, 2012 | Sony HDRXR150 Camcorder
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
The vids on my Sony DSC-T90 won't play and I can't record. The camera says' "file error"
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files.
Not able to record or play :
This error may occur in any of the following circumstances:
-The Memory Stick® media is not inserted properly.
-The Memory Stick media is not supported for use with the camera.
-The Memory Stick media may be faulty.
Mar 13, 2011 | Cameras
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
"MOVIE RECORDING DISABLED"
Breanna,
Unfortunately, it looks like it is a problem with the disc you have in the camera. If you have another disc, put it in and see if the error message remains. Obviously, the new disc won't have your original video on it, but it will help determine if the cause is the disc.
Please also see this post on FixYa: http://www.fixya.com/support/t413486-dcr_dvd108_problem
Mar 21, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
My video camera wont let me record or play
Greetings bianca50,
There is a known issue with a small button that becomes stuck causing your camera to display this error message. I would suggest ensuring this button is not stuck on your camera by putting the battery on a bit forcefully. This should eliminate the error.
Thank you,
Agent Dort
Go Ahead. Use Us.
Apr 08, 2008 | JVC Cybercam GR-DVL805 Mini DV Digital...
Problem with reading and playing dvds
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 07, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Cannot play tape nor record on tape
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
Sony Handycam CCD-TRV11 8mm Analog Camcorder Logo
407 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
