Question about Pioneer Audio Players & Recorders
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
  • Anonymous Apr 01, 2014
    No audio from pre amp rca's, i have full sound on front and rear but nothing to amp and sub. Ive switched RCA cables as well as my amp, it boils down to RCA pre-out rear/sub on head unit Pioneer AVIC X940BT
    Scholar:
  • 74 Answers
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Posted on Oct 13, 2008
Hook up lanzar 4 channel amp, directions say to use single rca cables with y connectors. my stereo has L/R rca outputs for front, rear & sub total of 3 sets =ing 6. amp has total of 4 one rca...
Well personally i would probably use two channels to run all the highs and bridge the other two channels into one mono to run the sub ..
Jun 02, 2011 | Car Audio & Video
How to hook up a pioneer supertuner iiid
Pioneer DEH-1500 CD Receiver
Wiring Color Code:
Yellow
To terminal always supplied
with power regardless of
ignition switch position
Red
To electric terminal controlled by ignition switch (12 V DC)
ON/OFF
Blue/white
To system control terminal of the power amp
or Auto-antenna relay control terminal (max. 300 mA 12 V DC).
Black (ground)
To vehicle (metal) body
To speakers:
Grey = right front (+)
Grey/black = right front (-)
White = left front (+)
White/black = left front (-)
Violet = right rear (+)
Violet/black = right rear (-)
Green = left rear (+)
Green/black = left rear (-)
RCA connections go to external amp:
Red = right speaker
White = left speaker
This is the basic layout for most all stereos. The ones that have an orange or orange/white, this is the illumination wire.
Good luck.
Sep 26, 2010 | Pioneer DEH-1500 CD Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
2 RCA's coming from amp into radio's single subwoofer output RCA?
You can either hook up the left channel only or buy a splitter that separates one input into two outputs.
Oct 03, 2009 | Pioneer DEH-P690UB CD Player
Hook an ipod to Pioneer DEH-16
The RCA jacks on the rear of the head unit are rear pre-amp outputs. (google it if you need an explination on what purpose they serve or see the installation guide) With that said, I am able to play my mp3 player through them but since they are 'rear' pre-amp outputs my mp3s only play on the rear speakers. see this post for more...
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=45149&query.id=194369#M45149
installation manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/35572505Installation%20Manual%20DEH-1600.pdf
owners manual:
33399012operation%20manual%20deh-1600.pdf
Mar 15, 2009 | Pioneer DEH-1600 CD Player
Need to know what connectors to buy to install my pioneer audio?
You can usually purchase a wiring harness for your vehicle to ease the connection to factory wiring. Two examples would be here:
Toyota Into Car Harness
Toyota Into Radio Harness
Feb 01, 2009 | Pioneer DEH-P3000IB Connect an iPod nano...
Connecting an ipod
Just press the bottom ipod in your player and start browse your ipod lists from your player
Jan 06, 2009 | Pioneer DEH-P3000IB Connect an iPod nano...
Pioneer DEH-P3000IB problem.
I know this is an old post but just ran into the same problem with my brother in laws Pioneer Radio. Well, it turns out that the head unit has to be OFF before you try to change the subwoofer setting. THen press and use the Multi-Control knob to select SubControl and change this to REAR SP: FULL (this gives you full range sound) or REAR SP:SUB W (this is for only low, subwoofer frequencies). His radio was set to sub, which is dumb because it was installed with a 4 channel amp and 4 full range speakers. Not sure why it was setup like this in the first place but oh well...
Aug 24, 2008 | Car Audio & Video
511 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
