Question about GE Dryers
Not heating also exhaust fan on dryer is not woeking screen show a problem has been detected with the model selection connection
  • chuhunghuang Oct 13, 2008
    We removed the front and rear panels and it appears that the blower fan is not working properly in addition to the following error message...
    "A problem has been detected with the model selection connection. Please call GE Service at 1 (800) GE CARES"
    I suspect that there is no heat because a sensor or control module detects that there is no movement or very little movement from the blower fan for safety.
    Thanks for trying but I think we will need to call a GE technician.
  • 750 Answers
Hello chuhunghuang
Welcome
You said, your not heating also exhaust fan on dryer is not working screen show a problem has been detected with the model selection connection
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
Let me know how it goes!
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Oct 13, 2008
Cannon ir 3025 photocopier displays error code 805-000.
E805
There is a fan error.
0000
Failure in heat exhaust fan (front) (FM2)
When lock signal is detected for 5 sec while the fan is stopped.
- Replace the heat exhaust fan (front) - Replace DC controller PCB
0001
Failure in rotation of heat exhaust fan (front) (FM2)
When lock signal failed to be detected for 5 sec while the fan is driven.
0002
Failure in heat exhaust fan (rear) (FM1)
- Replace the heat exhaust fan (rear) - Replace DC controller PCB
0003
Failure in rotation of heat exhaust fan (rear) (FM1)
there are 2 fame in the right door if you just look on the right door you will see 2 square vents
get in there and remove the fans and clean them out with canned air and apply a small amount of oil in the center then flick the fan to make sure it spins softly
reinstall and try it should fix the problem but please go ahead and order a new fan the part number is on the fan itself in the sticker it will say FK2-????-????
Oct 30, 2013 | Office Equipment & Supplies
The dryer runs fine but has no heat. The exhaust and lint screen are clear of debris. It is a Maytag MD3000
The Heating Element may be gone, or you might be real lucky and have a loose or dirty connection.
You might want to throw the Breaker Switch or unplug the unit before you do anything (220!!!).
Jun 02, 2011 | Dryers
Dryer has heat in back but cloths won't dry.
Howdy: Some models have a little fan that blows the hot air into the drum. I do not know what model you have but I would start there. Sorry - Good luck - Doug
Dec 09, 2009 | Maytag Dryers
Dryer heats and turns but no air out the exhaust it is not pluged though
Check the lint screen first. If no luck there, it's possible that the fan discharge itself at the bottom of the dryer is plugged or that there is a problem with the exhaust fan itself. You may have to remove the back of the dryer and check the discharge pipe from the fan back to the fan unit. Turn off the gas first before you pull the dryer out and unplug the dryer.
Mar 28, 2009 | Maytag MDE9316 Dryer
Dryer heat output is 148, but takes several runs to dry clothes
You most likely have a ventilation problem somewhere in your exhaust line. This can be very dangerous and a fire risk. You need to do a thorough check of your vent pipe and make sure it is clear and the exterior trap door is working freely.
Jan 26, 2009 | Amana ALE643RB Electric Dryer
House fuse
If you have a two pole circuit breaker
there will be no fuses
the breaker replaces the fuses mentioned in the manual
Most common cause of dryer running but no heat is a blown thermal fuse. a protective device that fails if airflow is restriced and temperature rises.
the thermal fuse is mounted on the fan body or exhaust duct and looks like one of these
ac65851.jpg ce345c9.jpg wired in the heater circuit
explicit instructions to open the case/body of the dryer depend on make and model which are not stated.
If the thermal fuse has blown the dryer needs to be cleaned of the lint that got past the screen, into the fan and exhaust duct all the way to the vent on the exterior wall 2092f63.jpg thermal fuses are ~$14
Nov 01, 2008 | Dryers
My tumble dryer works ok but theres no heat been told i need a new thermostat but cant find one with my model number
Non-Specific answer - no dryer model given
The thermostat is likely not at fault,
there is on the exhaust duct of most dryers a thermal protector, thermal cutout, thermal fuse (and a half dozen other names for the same thing)
If the air temperature becomes too hot due to blocked exhaust ducts, lint in the fan, lint screen not emptied or someone opened the door in the middle of the cycle then closed it again. the device fails to protect the much more expensive heater coil and thermostat.
Trace the exhaust duct from the fan housing for a device that looks like this 07b92b9.jpg or this fd3277a.jpg with wires to the terminals.
Test with an ohmmeter or bulb and battery, conducts ok no conduct replace.
take the dud one to the local parts store,
there are very few thermal cutouts, common to many dryers, they will be in stock. and cost very little.
While the dryer is apart, is a good time to clear lint from exhaust hood, ducting, fan, fan housing, to prevent recurrence
Sep 08, 2008 | Dryers
Problem with "model selection connection" message on touch screen
GE Dryer - Profile Harmony
DPTGT750GC1WW and perhaps others.
If a screen comes up with "model selection connection". It could be the motherboard that has problems. Most likely not the touch screen.
Possible solution - Before calling for repair.
- First unplug the dryer for two minutes.
- Hand spin the dryer drum one or two turns while unplugged. ( in case motor was over heated)
- Make sure the dryer door is fully closed.
- Plug in (after the two minutes).
- Cross fingers
- Start.
- Let dryer cool between loads when possible.
If this fails you may need to call for repairs. I think GE has one year repair plan unless you bought extended plan. If you paid with credit card, see if it was a paid with a credit card that extends warranty another year. Perhaps look into this "card choice" for your next high end purchase.
Only if this helped...Donations_M.D.,box774,Fairfax,CA - Another try if this fails - If you dare - Unplug, you can remove about three screws holding top panel on (on rear) and tilt top forward. Check to see that all connectors are seating well on motherboard. (White box in center). Hope see works for you!
Parts:
WE04X10105 Display
WE04X10107 Power/PCB ASM-Main (motherboard)
WE04X10127 Power filter (circ) EMC
Aug 25, 2008 | GE DPGT750GC Gas Dryer
My whirlpool dryer has no heat. the drum turns.
Your issue is;
"my whirlpool dryer has no heat. the drum turns."
Based on the information provided above, I am unable to access my database to provide you with exacting information. A valid model number was not provided. However, I have provided some common solutions to help guide you in your search.
This information is for an electric, generic model dryer only!
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
This link shows disassembly of a version 2 Whirlpool dryer:
http://www.repairclinic.com/0100_16.asp
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 23, 2008 | Whirlpool Dryers
E-2 error code on whirlpool duet dryer
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
pushbuttons.
Feb 25, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
74 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
