Question about Panasonic Audio Players & Recorders
Ac power adapters differnt ampage
I'm trying to get a replacement for my ac adapter for my laptop. I have a toughbook cf-w2 and the ac adapter cord to recharge the battery has a short in it and wont work. I can't seem to find an exact replacement for the adapter. the computer calls for one with 16V at 2.5 amps. the closest adapter i can find is one with 16 V at 3.75 amps. Will this adapter work or do i need something with 2.5 amps.
Thanks
Darrell
5 Suggested Answers
  • 143 Answers
SOURCE: Harmon/Kardon SoundSticks 2, Power adapter?
If you go to the Harmon/Kardon website, you can find where to buy replacement parts.
http://www.harmankardon.com/
Select product support on the front page, then go to parts.
Then select your product as Harmaron/Kardon SoundsticksII and select your country.
Hope this helps,
Nathan.
Posted on Apr 14, 2009
SOURCE: Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Posted on May 07, 2009
SOURCE: Need the specs on adapter for JUSTer dc-691p speakers.....
Model: PPI-0930-UL
INPUT: AC 120V 60Hz
OUTPUT: DC 9V 300mA
Polarity: Neg.outside, Pos.inside
Posted on May 19, 2009
SOURCE: adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Posted on Jan 14, 2010
kc5uzd
  • 13 Answers
SOURCE: need ac adapter for speakers
If you're in the US, go to Radio Shack and buy a plug in transformer that puts out 12VDC at 1000mA.
The polarity is negative (-) on the outside and positive (+) on the inside.
Posted on Apr 28, 2010
LENOVO G770 LAPTOP NO POWER NOT CHARGING WON'T START
The most common issue identified with the G770 is with the charger/ power adapter - If you can get your hands on one try it should do the trick
Oct 22, 2013 | iTEKIRO Laptop AC Power Adapter Notebook...
Connecting charger and letting charge for sometime...charging light doesnt turn on and laptop doesnt turn on...any advise?
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-65w.html
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-3-95a.html
Nov 07, 2012 | Toshiba Satellite C655-s5140 Laptop
Cannot find power adapter for mms171w philips system. Needs AC/AC adapter with 10v ac at 1.8 amps output. Cannot find aftermarket counterpart either. Help. Lost adapter while moving.
What does the other end of the adapter look like?
Is it a conventional circular one or is it a special port like it's thin square like or USB like maybe?
If it's conventional any 10v 1.8amp or 2 amp output should do and a lot of them are available in e-bay or if there's a Best Buy, Staples, Etc near you can just drop a visit purchase one and it should work like a charm.
However if it's not a conventional adapter you may have to contact philips and purchase one that is compatible from them.
Hope this shed some light on your problem!
May 31, 2011 | Philips MMS171 Computer Speakers
I am looking for a power cord for JBL on stage II speakers. Part no. 700-0042-001. Model no.TEAD-48-180800U
The following power cords will work with your speakers
You can purchase the power cord from the following site if you are in the UK:
http://www.power-adapters.co.uk/jbl-7000042001-acdc-18v-power-supply-adapter-p-7165.html
You can purchase the power cord from eBay if you are in the US:
http://cgi.ebay.com/AC-Power-Supply-Adapter-Charger-JBL-700-0042-001-/350422898000
Regards,
sjstore2
Dec 18, 2010 | JBL CREATURE II Computer Speakers
I only need the AC Adapter Campanion 2 for my Bose spearkers. How can I find just the adapter?
Look where the AC adapter would plug in.
Look for "rating", e.g., 'DC' or 'AC',
and '6V' or '9V',
and look at the size/shape of the plug.
Then, go to a "Dollar Store" or "Thrift Store", and try to match the ratings and the plug-layout with the available inventory.
Or, contact BOSE, and see if you can buy it from their web-site.
May 28, 2010 | Bose Companion 2 Computer Speakers
The charger for my laptop will not charge it. I used the charger from another Gateway laptop that I know works and yet it didn't on the 1st laptop. It appears that the male section which is inside the...
No, you can remove the battery, if the AC adapter is supplying power to the laptop.
Since _two_ AC adapters do not work, it's most-likely that the problem is your laptop.
Take the laptop to a qualified technician; they can try to disassemble the laptop, and fix the "bad" connector.
Apr 18, 2010 | Audio Players & Recorders
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
Feb 11, 2009 | Bose Companion 2 Computer Speakers
Video upload....
well, the connector that comes from the 2nd speaker goes into the speaker port in the back of the first speaker.
The wierd cord possibly fits into the 12v dc slot in the back.. and the other end would go to a power adapter..
Seems you are missing a power adapter,, like you said earlyer.
Basically you would need a standard power adapter which fits into the speaker.
You could get some universal power adapter for it like
http://cgi.ebay.com/UNIVERSAL-DIGITAL-AC-ADAPTER-ADJUSTABLE-VOLTAGE-NEW_W0QQitemZ150275118131QQcmdZViewItem?_trksid=p3286.m20.l1116
Or
something to this direction
http://cgi.ebay.com/UNIVERSAL-AC-TO-DC-POWER-SUPPLY-ADAPTOR-ADAPTER-CHARGER_W0QQitemZ230275174536QQcmdZViewItem?hash=item230275174536&_trksid=p3286.m14.l1318
If you want to make sure you get the right kind of power apdater
Try contacting jbl directly
http://www.jbl.com/home/product_support/JBL_contactus.aspx?ProdId=PLATINUM%20SERIES&ProdName=COMPAQ:%20Platinum%20Series
I was looking around ebay, found this
http://cgi.ebay.com/NEW-JBL-Platinum-Series-PC-Speakers_W0QQitemZ260266345340QQcmdZViewItem?hash=item260266345340&_trksid=p3286.m14.l1318
Theres the power adapter in the middle, I think the odd cord goes to the back of the first speaker and the other end would go to a power adapter.. try contacting jbl they should be able to get you what you need.
Seems you have everything else you need except for the power adapter.
Jul 26, 2008 | HP JBL Platinum Computer Speakers
44 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
