Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Err 02 When you turn the camera on it says err 02 and won't do anything else.
  • 1 more comment
  • cheruk Nov 08, 2008
    I have a canon eos 300d . Turning it on produces an err 02. I have tried a different memory card, and also reformatting the original card. Battery has been charged, but still getting the same error.
    Can anyone advise please.
    TIA
    Chrissy
  • designatedd Feb 13, 2009
    When I put the CF card in my cannon rebel, it does not work it gives me err 02 code. When the card is out it turns on. Can someone help me please
  • rikati2ger Feb 23, 2009
    My canon rebel shows the err02 when I turn it on and the CF card is in it.  Also, it won't let  me reformat or even get to the menu.  I tried reformatting the card on my computer and putting it back in, but that didn't help.  When I take the memory card out of the camera and turn it back on, all the functions work and I can access the menu.  I tried the CF Card in another camera and it works fine, so now I know that something is wrong with the CF slot.
    Problem Solver:
I've had the same problem for 3 years. First, take the cf card and turn the camera on. Does it come on? Can you use the menu, etc.? If so, turn it off and look inside the cf slot with a magnifying glass. There should be 2 rows of pins (50 altogether) and see if any are bent. That may be your problem. Mine is actually a bit worse. There are apparently only 48 pins in mine. Two opposite (kittycorner) pins are missing. Don't know where they went. But there you are.
Posted on Nov 23, 2008
  • kisserermig
    kisserermig Jan 03, 2012
    If there is missing a pin, what to do then?
One of the middle pins was bent on mine. When I tried to straighten it, it broke off. The camera is working now and the pictures look fine. I may have had the good fortune of a pin that is not used breaking.
Posted on Sep 03, 2012
Thanks jnupfold.
I will have a look.
Err 02
Have you tried reformatting the card (full, not quick, format) in your computer? This will require you to have a CF reader, but they're so handy you should have one anyway.
Mar 23, 2014 | Canon EOS-20D Body only Digital Camera
Err message with Nikon D70
Is there anything else than the ERR? Hold on I will have to look it up, just a moment.
Oct 07, 2008 | Nikon D70s Digital Camera
The camera say,s , err 02
Err 02
Description: The camera cannot access the memory card.
Resolution:
  1. Remove and re-install the memory card.
  2. Format the memory card as described in the user manual. The user manual for your EOS camera can be downloaded form the Canon Europe EOS camera support page.
  3. If formatting the memory card does not resolve the error please replace the memory card.
Dec 27, 2012 | Canon Eos Digital Rebel Ds6041 6.3 Mp...
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Canon eos digital camera, display err 2 in window. will not take any photos. The battery is fully charged and istalled correctly.
ERR 02 usually indicates a problem with reading the memory card. Remove and reinsert the memory card (check the pins in the camera with a strong light to make sure no pins are bent). If that doesn't work, try another memory card. If it still doesn't work, the camera may need to be serviced.
Jul 24, 2008 | Canon Cameras
Tech help
In the manual on page 127:
Err 02
There is a problem with the CF card. Do one of the
following: Remove and reload the CF card, use another
CF card, or format the CF card.
found manual at:
http://dms.sjmc.umn.edu/Equipment_Guides/Digital_Camera_Guides/CanonRebel.pdf
Jun 23, 2008 | Canon Digital Rebel / EOS-300D Digital...
My camera won't do anything but flash the Err message
Make sure the lens you are using on the camera is set to the minimum aperture setting. i.e. f22,f32 (highest f stop number)
Dec 28, 2007 | Nikon N55 35mm SLR Camera
Err 02
try another Compact flash card or at least reformat it. That might fix it.
Nov 16, 2006 | Canon EOS-10D Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
345 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
