I have a Dane Elec 256MB Flash Drive which gives me an error message that "The disk in drive E is not formatted. Do you want to format it now?" I do not want to format this drive because I have data on it that I really need. Can someone please assist with this issue? Thanks Sunil
I don't you can solve this at home. You need expert that have hardware and software to retreive your data for you.
The reason you get this message is because your flash drive lost the header to tell the computer how to retreive your info.
Posted on Oct 13, 2008
Refuses formatting
Depending on operating system you are running, you should not need to load any drivers for a zip drive to install. Have you changed the disk in the drive, just like the floppy format, zip disks can fail too.
Oct 21, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My Dane-Elec 8GB will not format. I have tried two different jump drives and I keep getting the same message. Unable to complete format.
WHAT A PAIN IN THE A_S_S.
DID EVERYTHING DESCRIBED, & MORE,
& I'LL NEVER WASTE ANOTHER PENNY ON
ONE OF THESE F_U_C_K_I_N_G PIECE OF
S_H_I_T DANE-ELEC 8GB .
I'M GOING BACK TO TARGET STORE & JAMMING
THIS NIGHTMARE RIGHT UP THE STORE MANAGER'S
STUPID A_S_S .
Sep 12, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My usb device was working fine until yesterday when I plugged it in and I kept getting an Unknown device error with the following message: "Windows has stopped this device because it has reported...
Code 43 errors are nearly always caused by a driver issue. However, since you have tried the device in several different computers with the same result, I believe that your flash drive has gone bad or become damaged. Unfortunately this is not an uncommon problem with flash drives. Like any storage device on the computer, make sure you are backing up what is on your flash drive.
I hope this is helpful to you
May 28, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Put in my dane elec 16 gb flash key on my computer window ex and other computer window 2007 not recognized its malfunctioned. light is out... need to get all my important files out..
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htmwww.CardRecovery.com
Apr 20, 2011 | Dane-Elec DaneElec 4GB USB Drive Blue Hard...
I have a Dane-Elec 4 GB Flash drive. I used it successfully one time, but the next time I put it in my computer (or any computer after that) the computer recognized the new device but told me "Please...
1) Instead of double-clicking, right-click and choose "explore." I hope it's that simple. Once you're in, look for a file called autorun.inf. Delete it.
2) If it won't let you explore, see if there is a "format" option instead. This will possibly solve your issue of access, and will solve your issue with your confidential data (of course, your data will be gone, but I'm guessing you're OK with that).
3) Try using another USB slot, sometimes there could be an issue with specific slots, especially if you are using hte front USB ports on a desktop
4) I know this may seem silly but turn off the computer, and then unplug the computer from the wall. Leave it unplugged for 30 seconds, plug it in and then boot up the systems. Plug in the USB drive.
5) Finally if the unit still is not being seen, it may need a low level format, contact the manufacturer and see about getting a replacement. I found their e-mail at onlinesupport@dane-memory.com
Feb 27, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Hi, My 2gb red flash drive has all of my info on it, but it keeps malfunctioning---as in: the computer opens it, and then keeps opening it, until finally I get a message which says "Potable device...
Scan the device for Virus's first.
Secondly use CMD to copy off file(s): Make a folder on C: called USB. Then in command type: cd xcopy C:\USB /E /H /Y
Format the Device.
Dec 28, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Tenho um pen drive Dane-Elec de 2 Giga quando conecto na entrada de USB aparece uma mensagen deseja formata-lo, quando digo sim, vem outra mensagen o Windows não conseguiu formata-lo meu...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Sep 26, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
How do I reformat it?
To format a USB Flash Drive, follow the steps below for your OS:
A. Windows PC
1. Power on your computer. 2. Insert the USB flash drive. 3. Click on the "Start" menu and click on "My Computer". 4. Right-click the drive letter that corresponds to your USB flash drive. 5. Select "Format" from the context-menu. 6. A new window will open, input the following information in the correct fields:
File System: FAT32 Volume Label: "Give your USB drive a title" (optional)
7. Check the "Quick Format" checkbox. 8. Click "Start" 9. Upon completion, your USB flash drive will be formatted.
B. Mac OS
1. Power on your computer. 2. Insert the USB flash drive. 3. Double-click on your Macintosh HD. 4. Double-click on the "Applications" folder. 5. Double-click on the "Utilities" folder. 6. Double-click on the "Disk Utility" application. 7. The program will open, select your device from the left-hand pane. 8. Click on "Erase" on the main page. 9. Input the following information in the correct fields:
Format: MS-DOS Label: "Give your USB flash drive a title" (optional)
10. Click on the "Erase" button. 11. Upon completion, your USB flash drive will be formatted.
Aug 15, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
MY DANA ELEC 4GB THUMB DRIVE WILL NOT FORMAT
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 05, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
