Sony TV problem--not recognizing remote.
My Sony tv model kv27v42 will not recognize the remote control signal. I have ruled out the remote being the problem. I assume it has something to do with the remote sensor on the tv itself. I live in a very remote area where there are no repair shops. Is there a part I can order and install myself?
At first I thought it was the remote, so I bought a universal remote and programmed in the appropriate numbers. No success. I foolishly assumed I had bought a defective universal remote and bought another. When this also did not work I tried programming it for the other devices (e.g. VCR, DVD) and it works fine. Hence my conclusion that the problem is in the TV, not the remote.
2 Suggested Answers
  • 10594 Answers
SOURCE: my Sony tv model kv27v42
Have you tested your remote? You can test it by using any camera even camera in mobile phone.
Posted on Oct 12, 2008
My magnavox remote is not being recognized by tv it came with. How do I fix this issue.
Try replacing batteries but the remote control may have simply failed.
Oct 03, 2017 | Magnavox Televison & Video
Bravura not recognizing an Apple TV signal
You need to connect using an hdmi cable from the appletv to the tv, and notice which hdmi socket on the tv you use (eg 1 or 2 or 3...) Then make sure the light is on green on your apple tv by using the supplied remote control to power it up. And then you need to make sure you have chosen the correct hdmi source on your tv remote control (eg hdmi1 or 2 or 3...).
Sep 16, 2014 | Televison & Video
Not getting hdmi signal from pc to tv
turn off pc completely(shutdown) make sure hdmi cable is unplugged. plug into tv first, turn tv on, plug hdmi cable to pc then power up, it should now be able to recognize the tv. Try it in projector mode if available.
Mar 17, 2010 | JVC TBC Remote For Pro SVHS VCRs Remote...
Need to reset the tv/remote on a sony trinitron
Make sure you have fresh new batteries and installed correct,point the remote at the tv,make sure nothing is blocking the view of the IR sensor,get close to tv,but not to close,press power.If it still dont work, try the tv itself,press power,you may need to replace the remote,or the IR sensor, hope this helps.....
Mar 08, 2010 | Sony Televison & Video
Hard drive needs format
You need to download below manual... it seems it is all similar, read below as well.
Your remote might be using the wrong "infrared code", so the recorder when in service mode cannot understand it. Sony offers a feature that allows their recorders to operate under three different remote control signals, so if you own more than one Sony the remotes will not interfere with each other. The standard remote code the recorder is set to when new is "3". If by some chance you changed that code yourself, or the store changed it, then your remote is not sending signals that "service mode" can recognize.
You will need to change the remote's control code to "3" before the recorder will recognize it while in service mode. To change the remote code, take the remote to another room away from the recorder. Hold down the enter button, then press the 3 button. Hold both buttons down for 7 seconds, then release. Try the remote on the recorder: it should now be recognized and able to operate the service menu. Upon exiting service mode, the recorder may revert back to whatever code was last set, and the "3" codes that worked in service mode may not work in normal recorder mode. If it does not, do the same as before: try changing the remote control from "3" to "2" or "1".
Feb 26, 2010 | Sony HARD1000
Remote control is lost. Does not recognize Video IN
external dvd only shows up on channel 3 or 4 ...
Dec 10, 2009 | RCA 20F514TD 20" TV
Sylvania tv has stopped recognizing commands from remote.
Use some windex on the pickup on the front of the tv. It's a little dark spot, either round or square that picks up the signal from the remote.
Jan 17, 2009 | Sylvania 6427TE 27" TV
Problems with my Sony TV
check out this link and they will provide you the required part just tell them proper model number of the unit.
Oct 12, 2008 | Sony Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
