Question about Insignia Digital-to-Analog Converter for Analog TVs
Dtv converter box
Can i get a signal for my box or do i have to wait until feb
  • goodwinp3 Jan 23, 2009
    on my tv screen it says weak signal what do i do?
You can plug your converter in and use it now. I still have a few related problems and questions about the impact the converter box has on my TV and other devices (DVD, VCR, etc.) but it does work and the picture is very good!
Posted on Oct 15, 2008
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
NO SIGNAL on Magnavox TB100MW9 converter
Rabbit ears are not strong enough to pik up the digital signal. You need to buy a DIGITAL antenna. You can pick a powered one up at Wal-Mart, or any retailer for around 20 bucks. Once you have the proper type of antenna, go through the setup sequence again and then you will be in the "digital age". You will wonder why they didn't do this sooner!
Jan 13, 2009 | Insignia Digital-to-Analog Converter for...
DTV Compatible
If you do not have cable or satellite then you will need a converter box for Antenna only those who will be using antenna for signal will need box.
Oct 30, 2008 | Sanyo DS20930 20" TV
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Feb 2009
hi there
wouldn't a set top box work attatched to the unit, the spec says it will ?
beergut707
Oct 14, 2008 | LG Electronics LRM-519 Digital Media...
No, unless you are receiving over cable or satellite. You will need a DTV converter box if you are using an antenna to receive Over The Air television signals. The Proscan has an analog only tuner, so the ATSC (digital) signals will not be visible.
tom
Jul 20, 2008 | Proscan PS27123 TV
TV Converter Box
the coupons are only good 90 days after they mail out so yes i whould bye them now. as for needing them now to hook to your tv you have till next feb 2009 till you need them but if you have a good tv signal on your stations the dtv box will make them come in almost like dvd picture.real clean and sharp
Jun 23, 2008 | GPX KCL8806DT 7 in. Portable Television
Dtv ready?
Usually on the back of the set there will be a hookup for digital tuner. To get the converter box before Feb 2009 go to http://www.dtv2009.gov
Mar 15, 2008 | Orion STV2763 27" TV
Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Feb 29, 2008 | Sanyo DS31590 31" TV
Insignia Digital-to-Analog Converter for Analog TVs Logo
63 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
