HP Laserjet 6P diagram of paper path
Orange light indicates paperjam, but it is not visible anywher I have looked. In addition, there is a green buttoninside the back cover, a release of some kind, but to what?
5 Suggested Answers
  • 102 Answers
SOURCE: HP Laserjet P2015n error
If paper jam light is solid or printer shows paper out light solid all the time,
Then try these suggeted steps:
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Posted on Jul 03, 2009
preachw996
  • 1179 Answers
SOURCE: The orange light keeps blinking and won't go back
This could be signaling that the toner is empty. Replace the toner and see if the light goes back to green. Hope this helps.
Posted on Oct 16, 2009
  • 313 Answers
SOURCE: I have a HP laserjet 6p printer. The only light
it may be you have paper jammed inside the printer, or there is no toner inside it
regards
Posted on Mar 25, 2010
Whispis2
  • 192 Answers
SOURCE: A HP Color Laserjet 3000n has the following errors
Perry,
Usually I have found that there is a scrunched up piece or bit of paper in the fuser.
I am adding a link below that will take you through the step-by-step process and you should find the source of the problem. Be careful when touching the fuser that thing gets HOT!!
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506722
Please let me know if this has helped and if i can help you any further.
Thanks
Posted on Mar 31, 2011
Orange light on SIDE (not top) of HP LaserJet P2015 Series printer won't go out. Have disconnected all leads and re-booted printer and computers (2) to no avail. There are no paper jams and have
Is there any text to indicate what this light refers to?
In general, you might want to remove paper trays, and use a compressed air can to spray inside the printer, especially the paper path. Oftentimes, paper dust will impede a photo-optic sensor, and keep an indicator light lit when there i no real reason for it. It can also give you a paper jam indication when there is none.
So blow out all paper dust to get the printer to work correctly now.
Cheers!
-a.
Apr 10, 2012 | HP LaserJet P2015dn Printer
My hp lasert jet 1012 light keeps blinking there is a new cartridge in there too
Indicating paperjam or cartridge missing most of the cases..check any paper jams if no remove back cover observe there are two sensors left for paper path sensor & right for catridge sensing sensor, check these two sensors flags, strucking/springs out..
Sep 19, 2011 | HP LaserJet 1012 Printer
regards
Mar 24, 2010 | HP Office Equipment & Supplies
Paper jammed in the middle and orange light started blinking. How do i make this print again. tried pressing orange and green button to no avail
canon printer. remove all traces of paper in the paper path. remove the power plug and replace after about 30 seconds. restart the machine and clear the orange button.
Oct 17, 2009 | HP LaserJet 1015 Printer
I have hp deskjet 2300d showing that their is a paperjam. I found no paperjam what do i do
There is a line of sensors along the paper path, if any of these are obscured by even the smallest scrap of paper you will get the messasge, re check the paper path again it only needs a scrap of paper, if you can spot any of the sensors give them a blow with some compressed air (paper dust build up), last but worth a try unplug for 2 minutes to allow residual power to drain and then try power up and see if the message has cleared
Sep 09, 2009 | HP LaserJet 2300d Printer
Light indicating paperjam is on but there is no visible jam!
Carefully inspect the wheels and gears inside for bits of paper. It could be small, but it would be registered.
Sep 03, 2009 | HP LaserJet 5L Printer
Printout does not look nice
Changing the toner cartridge should solve your problem
Apr 01, 2009 | HP LaserJet 6p Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
The top orange light is on
2 possibilities
1 It is trying to make more than 1 copy and the second one is jamming as it's picking up the paper ( clean tires)
2 it's set to legal instead of letter.
Aug 31, 2007 | HP LaserJet 6p Printer
Hp laserjet 6p
The 6p, or at least the ones I?ve seen, have several LEDs so I?m assuming the top one is what is orange. I?ve included the link to the LED codes, however, the three possibilities are top cover open, there is a paper jam or the print cartridge is missing or not installed correctly. LED codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl04061&lang=en&cc=us&taskId=120&contentType=SupportFAQ&prodSeriesId=25477&prodTypeId=18972 I would: - try reseating the cartridge - try replacing the cartridge with a new HP one if available. - try blowing out the paper path, could be dust so something small you can?t see. If that fails then its possible you have a failed sensor or electronics board.
Dec 06, 2006 | HP LaserJet 6p Printer
67 people viewed this question
k24674
jasbo
jasbo
