Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52w23 convergence I found this model in my trash. I am an apartment manager and I would like to give it to on of the tenets. The picture is bowed with colored lines at the top and there is red and blue ghost images. I've tried all the manual focuses. I'm told it is a convergence issue. is it worth fixing. Thankyou
  • RCA Master
  • 5,138 Answers
These sets sold for anywhere from 990 up to 1400.00 , so i would say it is worth fixing also when you go to menu in menu go to set up then look to see if convergence is on menu if it is not , then you have a open fuse located next to flyback transfomer, fuse FL231 . you can order rebuilt Deflection board for 179.00 plus shipping 50.00 dud fee when old board is returned 129.00 call union electronics
1-800-648-6657 First let me know if convergence is on menu, if it is listed on menu in setup then try this turn tv off , then press and hold vol- and ch - at the same time some times tv will reset convergence automaticly
Posted on Oct 17, 2008
Projection tv has 3 versions of what is on tv instead of one
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 26, 2010 | RCA D52W23 52" HDTV CRT TV
Bowed Picture; Still have access to convergence. HELP!
The convergence power supply board is usually the cause of that problem. You can get the replacement Convergence power supply board from www.tvrepairworld.com
Apr 01, 2010 | RCA D52W23 52" HDTV CRT TV
Rca model d52w23 picture bowed, a red,blue, agreen line running across the top picture looks 3d mainly in red,blue,green
It is possible that the CRT is shorting to the convergence Yoke, pretty likely actually considering the new one lasted 15 minutes.
To fix this you must use RTV or silicone and put it all around the suction cups that are on the CRT, this is usually where the voltage develops a leak and can short out various components.
Silicone or RTV those up, then replace the fuse and see if it fires up.
If it fires up and the picture is bowed again (convergence) then you will have to replace the board again :(
The other possibility (very unlikely) is that the CRT centering is so farr off that the convergence chips have to do extra hard work to align it, this usually only happens after a CRT replacement or Yoke replacement.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2009 | Televison & Video
RCA D52W23 52in HDTV red and green ghost and bowing lines
Ur convergence it dead,need convergence kit,use what in that kit,U know to solder? Tries websites Tv Repair World.com,Ebay.com
Oct 06, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence problem
Did you replace the convergence power supply board, or the Convergence board?
Sep 23, 2009 | RCA D52W23 52" HDTV CRT TV
Distorted picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 26, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence amp or board???
Go to this site and leave them an email indicating the model number of your set and the symptoms your having they will be able to help you out with the problem.
http://servicemanuals.vstore.ca/
May 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52937SG Convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
