Question about SanDisk Sansa m240 MP3 Player
Charged, now it will not turn on. what do i do
I was charging my sansa mp3 player and now it will not turn on. i dont know how to remove the battery to try and fix it.. please help...
  • jennypig Oct 13, 2008
    if anyone can help, it will be greatly appreciated... help!!
  • 8,596 Answers
Not a removable battery.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 10, 2008
I dont know how to charge my mp3 player and its dead
Plug one end of the supplied cable into the slot in the bottom of the Sansa. Plug the other end into a USB port of a computer. Make sure the computer is turned on, and it should start charging.
Mar 27, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
It wont turn on!
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
Feb 04, 2009 | SanDisk Sansa Clip MP3 Player
Mp3player
sansa fuzzmp3 player,wont turn on or charge up,what happened? I did nothing to it but put it in my pocket as usual...Help please
Oct 04, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip Mp3 Player
format it
by connecting to computer
Jun 11, 2008 | SanDisk Sansa Clip MP3 Player
It wont turn on
before you turn it on be sure to slide the hold button at the top so you dont see the orange part then turn it on
May 11, 2008 | SanDisk Sansa e200 MP3 Player
E260 4gb sansa not turning on
some may be due to low battery power or due to software problem...while charging stop once the charge gets full,...dont overcharge the battery,,,,,,the battery life gets reduced
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
I can't turn on my Sansa e250!! Help!
Check the battery connection(s) in the back. Remove the 4 screws, remove the battery an re-connect it. Charge the device for a few hours. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
Charge batteries...
My M230 uses a AA battery that is replaceable, just remember to power it off BEFORE removing the battery.
Sep 26, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
