Question about Dell Dimension 4600 PC Desktop
Speaker not working
Thanks for your response to my inquiry. Is there suppose to be a power source for the speakers? If so, think that might be the problem. Any suggestions where I can get battery or plug, whichever is needed.
  • Dell Master
  • 4,338 Answers
Yes, Most PC speakers require an ac adapter. The speaker with the AC connection on it should have a diagram of what power is required. It is usually 9 volts. You could buy a universal one @ Best Buy or buy another set of speakers. The AC adapter will probably cost almost as much.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 13, 2008
Why have i not gotten a response to my question
Hello Dustin
Because sometimes there is no answer! As I understand it, your Alero speakers in the back of the car don't work?
You put another speaker on the end of the wires and they worked.
You put another sound source into the car speakers and the speakers worked.
Stumped. That is an enigma. I would redo the connectors to the speaker.
Jan 21, 2016 | Cameras
Can active speakers work with tv volume
Yes you can do this if you source your sound from the headphone source. If you uise the headphone source you will lose the TV sound since the headphones mutes the speakers. But if you choose to use to use the AV jacks then you don't mute the sound and you can still control the speakers supposing that you have a brand of Television that has got all these facilities. Or otherwise if this is not what you are asking for please send the details of the TV you are using.
Nov 12, 2011 | Altec Lansing Multimedia Computer Speakers
Hi! I have purchased a JAMO S608 HCS 3 and a SUB 650 using an OKYO TX-SR508 Receiver. I can't set it up correctly. When I played music I've heard a lot of bass, I think there are some high...
The TX has speaker setup and test tones for setting the balance and distance with test tones and proving the hardware works. If that all works the difference is probably external or settings.
What is different between the music source(s) audio and the HD movie source(s) audio? Ask yourself, how would a sub make high frequencies go missing? It can't.
Your other speakers are responsible for conveying the high frequencies.
Sep 08, 2011 | Jamo SUB-650 Subwoofer
I need specifications about the power supply for for the Maxell FPS-1 2 speakers ...
Input Voltage: 110 V AC
Power Source: Power Supply
Frequency Response: 70 Hz to 18 kHz
Mar 04, 2011 | Maxell Flat Speakers With Subwoofer and...
Need a driver for advent speakers
These speakers should not need a driver. They may need an external power source, or the one you ahve may not be working. Also check the settings on the volume control and sound system software.
Nov 03, 2009 | Audio Players & Recorders
Power in amp but no sound to speakers
you need to make sure youre getting a signal from the source, RCA's I suppose. Check for loose connections or broken wires. make sure to have 12v+ on power and remote inputs at amp...proper ground too. Lastly, check your ohm loads at speakers, maybe one is about dead. make sure crossover settings are correct.
good luck!
Sep 17, 2009 | Pyle BZDBP212 Car Subwoofer
No sign of life in external notebook speakers
  1. If the powerlight is turning on some times and off sometimes, Then it may be a problem with the powersupply connected to the speakers. Check it.
  2. If the speakers are on and are not playing, Then try playing some music through alternate source like ipod,walkman etc.If the speakers are playing with alternate music source, The try reinstalling the audio drivers of your note book.
  3. If not then your speakers might have fried up due to some reason.
Feb 01, 2009 | Audio Players & Recorders
Seems to be no power to speakers.
Disconnect green speaker jack from computer and see if you get a green power light on speakers. If the speakers indicate they have power, your sound card or circuit is shorting out the speakers. If you still have no power to the speakers when disconnected from computer, then no green light means no power to speakers. Either you’re A.C. adaptor is bad or the speakers are shorted out. You have 2 options:
1) Replace A.C. adaptor.
2) Replace speakers.
If you buy new speakers, make sure that they have their own power source (A.C. adaptor).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 19, 2009 | Dell A215 Computer Speakers
Same as before
That is correct.  I would solder if you cant make the connectors.  they should have two diff sized spades on them.(usually)  I would definately get a crimp kit with crimpers and asst connectors to start.  Also make sure your amp has adequate gnd and large enough power wire with an inline fuse right off the source.  I can make a diagram for that too if you need.
Sep 10, 2008 | JBL LC-S960 Car Speaker
LEDs don't light
??????????????? only on fixya would we get a complaint that speakers that are supposed to make sound work great but some lights on them dont work.... ugh.. ok with most of the spealers that have l.e.d.s typically have a seperate connection for the lights. The red wire goes to a switched 12 volt power source, the black goes to chassis ground... if they have power and ground but dont light up then they are junk...
Sep 08, 2007 | Blitz BZX462 Coaxial Car Speaker
Dell Dimension 4600 PC Desktop Logo
Alun Cox
