Question about Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX4216 MF
When copying printing is faded down left hand side of page. This does not occur when printing. Any clues?
Called in a Samsung technician to fix/replace scanning unit
Posted on Oct 14, 2008
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
The right hand side of the page is printing clearly. How ever the left side is faded and streaky.
this problem is shown if you need to renew the drum unit of the printer, some samsung technical shops have refresched one on stock for half of the new price.
May 17, 2011 | Samsung CLP 300 Laser Printer
Was told need new "drum assy" because of faded
sir/mam drum do go bad after so many copies and prints. normally machine will indicate when that is needed.
Mar 04, 2011 | Samsung Office Equipment & Supplies
Right hand side of print outs are faded. The machine is a cannon mf 4150
Most of the time when you have faded copies it is due to the processing section of the copier. An number of things can cause this:
  1. Dirty optics
  2. Copier not level from to back
  3. Dirty charge or transfer corona
  4. Bad drum unit
  5. Contaminated developer section
  6. Dirty Laser unit
  7. or Worn fuser unit
These should be taken care of by your local Authorized dealer.
Sep 17, 2009 | Office Equipment & Supplies
Samsung CLX Printer printing unevenly
it is possible that this is a fuser prob, fuser works applying heat and pressure, if the roller, either the pressure roller or the fuser roller is defective this is most likely will happen too, you might want to  check the number of copies or prints made
Mar 22, 2009 | Samsung CLX-2160N All-In-One Printer
Faded on left hand side
If it only happens with the black then you need to change out the black toner cartridge. The good news is isn't doesn't happen with color so it more than likely not the printer but the toner.
Jan 09, 2009 | Samsung CLP 300 Laser Printer
Samsung color fading-light on lft side to dark on rt side
i want to download the driver softwere of samsung clp-300 series vista ultimate supported
Jan 05, 2009 | Samsung CLP 300 Laser Printer
Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Apr 22, 2008 | HP LaserJet 4350 Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
114 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
