Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis 110.6703 is BEEPING!!! ARGH!
My dryer has been beeping all day.. I used it yesterday and it ran normal cycles. Today it is flashing CF then 01 and sometimes 02. I have flipped the braker box and it still is happening. Can you help?
  • marchambault Dec 22, 2008
    The dryer was working fine. Then it started beeping AF, I cleaned the filter and plugged it back in. Now that it has been plugged back in, it beeps and flashes an oF message.
  • 116 Answers
Repl./// user interface board stuck button common problem
Posted on Nov 30, 2008
I have a Kenmore Elite dryer. Model # 110.67082600. The dryer has not been used in two days and I noticed it beeping. I unpluged it and plugged it back in. It did the same. It seems to run but after...
If you have a little bit of knowledge mechanically you can unplug the dryer and pull the top off by removing the 3 screws across the back at the very top, slide it back and lift it off. Inside of the dryer, at least in mine, there was a plastic folder on the inside with tech instructions that list the fault codes and it also tells you how to run a diagnostics mode on your dryer. Hopefully this will help you at least determine if it is something you need to call a tech to fix.
Aug 06, 2010 | Kenmore Elite HE4 Electric Dryer
Cf code on testing the dryer (kenmore elite oasis canyon dryer)
The "C" codes are usually just indicators used during a test mode to tell what parts of the system are engaged but are usually followed by 2 numeric digits. (eg. C:00, C:01, C:02, etc.) I've never heard of a "CF" but what it means may depend on *exactly* what the machine is suppose to be doing at the time. You could see if you can locate the appliance's 'tech sheet' that may list such codes which should be with the unit's wiring diagram either inside the machine's control console on inside the washer's cabinet in a small pocket, pouch or envelope stuck to the RH side panel. Maybe it will give you a clue as to what is transpiring? You'll need to probably take of the panel to find it. As far as i know tho- after hitting the test it should actually come up with a c:01-c:08 meaning the test is complete. As loong as it only does this after hitting test you are ok, but double check the tech list inside the panel of your dryer. Hope this helps!
Sep 14, 2007 | Kenmore 67082 Electric Dryer
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
May 10, 2009 | GE Dishwashers
Need 5C01 Code for 07/05/2009
00 = AA B7 D1 D9 CE 8E 83 AF
01 = 8E 80 D7 EF 44 93 02 2B
NTL 54 01] 07/05/09
00 = 5C 2C 26 36 CF 81 AB 66
01 = 2C 10 35 AC 06 57 BE 6F
May 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Codes update
NTL 54 01] 07/05/09
KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. This model is manufactured by Whirlpool, so maybe you can locate your model's failure codes.
http://www.repairclinic.com/0078.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 21, 2008 | Kenmore 67082 Electric Dryer
Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore Oasis Dryer - CF codes 01, 02, 03
Remove the top console (plastic control panel) of the dryer ( 3 screws on the back, tip and slide forward). Inside the console or taped under it should be the tech sheet for the dryer (unless a previous service person did not put it back).
Read over the tech sheet. In there there will be a section on how to initiate the computer's diagnostic routine. This is typically activated by pressing and holding any button on the console (other than the stop button) for 2-5 seconds, seven times in a row. When activated all the LEDs (lights) on the console illuminate, and then the console displays the actual “F” error/failure codes. In many cases with these Oasis Dryers (model 110.67082600) and similar models the typical one which will be displayed will be F-02 code (even if you got CF 01, 02 and/or 03 before activating the diagnostic routine. F-02 indicates that a button (or possibly several) on the front (user interface) console is simply stuck. If this is the code you get, simply press each of the buttons on the main console and to find which button is indeed sticking (i.e. the one that doesn't work will be the culprit). Save the Stop button for last as that button exits the diagnostic mode, if it is not the one that is sticking.
The tech sheet (which again shold have been right inside the console housing) explains step by step how to remove the console interface board from the console housing (3 screws and 3 plastic clips). Sometimes simply plaing with the button on the board will get it unstuck, but a simple spray with electronics contact cleaner (which can be purchased at any Radio Shack or other electronics parts store) into the base of the stuck switch on the board, and pressing it quickly a few times will usually do the trick. Once the button is unstuck, no more error code, and the dryer will work fine again. If you can't seem to get the button unstuck (or if it is really damaged), you can either replce the button switch yourself (if you have the electronics and soldering know-how), or buy a new console board from one of the many online parts houses for around $100.
Again you will need to locate the tech sheet inside the console housing or order one from Whirlpool or Sears for you model for under $10 if yours is missing. Some models vary in what each code means so you will need the tech sheet to be sure.
Best of Luck Everone...
Oct 08, 2007 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
264 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
